Question about Philips Televison & Video
I wish to connect my dvdr610 to a new tv can i get the first installation sceen so i can set it up
Done it
Posted on Aug 12, 2008
I have a dynex tv model dx-l40-10a i have no picture on the sceen i test with a flahslight and i see the menu on the sceen i dont see the backlight because is no vent hole on the back of the tv
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 21, 2017 | Dynex Televison & Video
Black horizontal line on sceen mitshubishi tv md73737
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Line, faults & possible causes to TV screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 21, 2014 | Televison & Video
Philips dvd manual .for model dvdr610/05
Try these links.
If you feel any difficulty in downloading the manual, inform me bu Fixya comment, alongwith your email address. I'll send a copu of the manual to you by return mail.
Mar 08, 2012 | Televison & Video
My tv is set to wide sceen and is cutting off some of the picture. how do i set it to full sceen
You should have a setting in the menu's to change the picture size. May have to dig up the owners manual to find it though. I'm assuming the picture you do see is clear.
Jul 10, 2011 | Philips Magnavox 51MP392H Rear Projection...
Tv Vizio VX37L HDTV 10A
Normally new screens run about 100.00 less than a new tv costs and then you have to get it installed! There is now easy way around it. You would be better off just to get a new one>
Jul 19, 2010 | Vizio VX37L Television
Can you put a phillips dvdr610 onto a television with built in freeview and then record from it. If so how?
If your TV has an OUTPUT MONITOR Output Jacks, Yellow, (Video) Red (Audio) & White (Audio) FEMALE RCA Jacks.Then these will output WHATEVER is showing on the TV screen. And can be used as an Output for any Recording Viewing device. There will be other, FEMALE RCA Jacks,AV, Yellow, (Video) Red (Audio) & White (Audio) and possibly also The Composite Video, Red, Green, Blue, all Video, These are INPUTS, they will be there also. Make sure.
Feb 16, 2010 | Philips DVDR610 DVD Recorder
Hi, I have a Philips DVD recorder which since
My connections were fine, I just hadn't retuned the DVD player into the right extension hence the (no signal) sign.
Nov 03, 2009 | Philips DVDR610 DVD Recorder
If you just purchase a new universal remote control. You need the manual that came with remote. Inside you should be able to find your brand of DVD player and the codes to activate it. Since all Universal Remotes are different there's no set procedure that will work for all of them. You will need the manual and go through each step to set up correctly. If you don't have or misplaced manual, you might need to contact manufacturer to either replace manual or receive the codes. Good Luck
Oct 19, 2008 | Philips DVDR610 DVD Recorder
It was working fine then no picture dark sceen sound work fine
More information is required. Your backlight is lit (screen not dark) but I need to know what you have connected to the TV (your sources) and how they are connected. Does the menu/OSD (on screen display) work?
Oct 19, 2008 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Philips DVDR610. When in standby switches on briefly
Hide all remotes from the line of sight of the unit and see if this helps....accordianman
Feb 22, 2008 | JVC XV-N212 DVD Player
Televison & Video Logo
42 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
