Question about JBL - MR4W Am/Fm with CD Player White
JBL MR-4 CD doesn't eject
I push the eject button and it flips over to the radio but the cd doesn't eject.
  • trillium441 Aug 11, 2008
    Thanks Guru, I did both resets, soft and hard.  No luck.  The unit only holds one CD so I'll be taking your advice.  Tomorrow, I'll pull the unit and take it to the local stereo shop.  I'll let you know how it goes.
    Trillium441
    Novelist:
  • 108 Answers
The unit probably doesn't think there is a CD inside. Possible doing a soft reset will fix this. Do so by powering the unit and putting a ball point or other pointed object into the reset button opening either on the face of the radio or behind the face. A hard reset can be done by disconnecting constant power from the unit for approximately 15 seconds.
If either of these methods fail, then your unit has a bad CD mechanism or more than 1 CD inside the player. In that case, the unit will have to be serviced by an electronics repair or a local stereo shop. This is a Marine radio, and if installed on a boat, this problem is not too uncommon. Moist air can cause damage to the unit as well as the bouncing on the water that boats do.
Posted on Aug 11, 2008
SOURCE:
Stuck CD in JBL 4 disc CD Changer / Navigation
before you press the cd on button keep holding the eject button while you press power on, I know this works for computers etc.
Feb 13, 2016 | 2013 Toyota Highlander
Won't eject CD
well the owner manual says to press button 9 and then flip down the face of the radio and it eject the cd. not just flip the face down . here is a link to the eject instructions..how to eject the cd on a miami beach cd51 have more questions email me at [email protected]
Oct 28, 2013 | Blaupunkt Miami Beach CD51 CD Player
ERROR 03 WHEN PUSH CD BUTTON
Two solution proposed on other forums:
1. Hold 'eject' button for 10 seconds. The system should eject the cd.
2. Slide a credit card back and forth on the cd opening. Push eject, the cd should be ejected.
Hope it works.
Oct 14, 2009 | 2004 Mitsubishi Endeavor
JBL MR-17.2 not recognizing Sirius satellite receiver.
I have the exact same issue. I have swapped with two identical MR17.2 radios and swapped out the sirius receiver. No change. I even bought a remote thinking I had to have a remote installed to get it to work...still no diff. Have you ever found a solution?
Jul 13, 2009 | JBL MR-17 Sirius-Ready AM/FM/CD Receiver...
Won't read the CD's now
have you ever cleaned the lazer lens? goto any CD store and pick up a CD cleaner CD, it is a CD that you place a drop of cleaner on the brushes on the bottom of place it in the CD player and let it play, it will clean the lens that reads the cd, you might have to run it a few times if you have never done this before. that should fix the problem. the CD cleaners are not that expansive, can find them under $20...... hope this helps you..........
Jun 01, 2009 | JBL MR-4 AM / FM / CD 180 Watts Marine...
I have a JBL MR-17.2 Sirius Ready stereo
To get your Sirius ID number from you MR-17 JBL stereo, select the Mode button until it displays "Sirius". Then push and hold the Mode button for a couple seconds and it will chirp and display 3 blank spaces. Enter three zeros, "000" in these 3 spaces. The Zero is the loud button labeled "LD". When you do that, it will display your Sirius ID number. :)
May 13, 2009 | JBL MR-17 Sirius-Ready AM/FM/CD Receiver...
Koss car radio,cd,mp3
I'm not familiar with that particular brand/model, but a lot of the models with the flip down face will actually have the eject button behind the face. So when you flip down the face, you can then hit eject.
May 11, 2008 | Koss MS547
JBL - MR4W Am/Fm with CD Player White Logo
381 people viewed this question
Top JBL Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Dalynn Turner
Marvin
Marvin
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
