Question about Kenmore 98702 Stacked Washer/Dryer
Dryer door The door to the dryer will not open. Can you help me? Thanks. Paul
  • 4 more comments
  • pmw727 Aug 11, 2008
    I have a Kenmore 98702 Stacked Washer / Dryer (this is a guess - it's a stacked Kenmore. The dryer will not open.
    I have a Kenmore 98702 Stacked Washer / Dryer (I believe it's a stacked Kenmore. The dryer won't open. Maklean says "get a repair kit." What am I supposed to do with a repair kit? Also, how do I communicate with the people who are responding? When I click on "get assistance," I am asked for my credit card info, which I already gave. I do not want to be charged repeatedly. Thank you.
    I have a Kenmore 98702 Stacked Washer / Dryer (I believe it's a stacked Kenmore. The dryer won't open. Maklean says "get a repair kit." What am I supposed to do with a repair kit? Also, how do I communicate with the people who are responding? I got a message from Techexpert12 which seems to refer to a washer. My dryer door won't open - there are no "select" and "speed" buttons.
    I have a Kenmore 98702 Stacked Washer / Dryer (I believe it's a stacked Kenmore. The dryer won't open. Voodoomox (who I do not know how to respond to directly) recommended I unplug it. The washer/dryer is in a small wall space - the power outlet is unreachable unless I move it, which I cannot do. I will need to hire someone to move it, because it's extremely heavy. Is this the most likely solution?
    I still do not know how to respond directly to people who respond to me without clicking get assistance, and being asked for my credit card info again. So I am using this repost each time. Pauman suggests it's the door latch, which sounds right. However, removing the front panel is not obvious to me. If I revove the dryer knob, there are two screws behind it, about a half inch apart. The other knobs don't appear to come off. Are these the two screws that you refer to? Thank you.
    Turning the dryer knob several times around, then giving the door a strong yank and it worked! Thank God I didn't have to pull out the washer/dryer unit from the wall - it is very heavy and would have required professional help. Thanks for your help!
  • 3,037 Answers
The first thing to try is to turn the dial a couple of times in case of a bad connection at the dial. If that doesn't work then what you need to do is pull the whole machine away from the wall and start removing the dryer outer panel. There will be screws on the back that hold this panel on. Once you get this off, you should have access to the switch of the door which then you can remove and replace if found to be faulty. Make sure to have it unplugged when working on it. Please let me know how this is going and what problems or questions that you run into, responding here will be just fine and you should not have to pay multiple times.
Posted on Aug 11, 2008
    Sergeant:
    Champion:
  • 248 Answers
Suspect bad lid latch there is usually a 4-6 delay after washer/dryer stops before latch will release anything much longer proably lid lock ..remove 2 screws bottom front panel front drops and comes off switch is on right remove screw each side of top lift up 2 screws hold latch in place remove wires and screws and replace latch
    Genius:
  • 1,689 Answers
No need to pay again, have you checked on techexpert's suggestion? you may also leave the appliance unplugged from the outlet to reset the possible programming, leave it unplugged for an hour or two.
    Master:
  • 521 Answers
Try: Program the select knob at 6 o'clock position. Speed at 9 o'clock. Press pre-wash and the power button together for 4 to 5 seconds. Hopefully it will unlock
  • tech expert12 Aug 11, 2008
    Did the solutions from all of us experts solved your problem if not then let us know the current updates so all the fixya experts can assist you further.
    Genius:
  • 1,665 Answers
    Master:
  • 623 Answers
Model/make?
Driver side door
Hi Paul, I'm glad to help! Most problems with door handles that won't open the door is broken parts inside the door. Pull the door panel off and move the handle while watching inside the door to see what is broken. Once you've found the broken part, simply replace it. Hope this helps and have an awesome day Paul.
Feb 10, 2014 | 2004 Hyundai Santa Fe
Front Driver side door on2004 Santa fe will not open from inside
Hi Paul, Im glad to help!
Paul, when you can't open a vehicle door from inside the car, it is because either the latch is bad OR the handle is broken OR the rod /cable that goes from the handle to the latch is either off OR broken. Call me Al 314-374-5218 hope this helps and have an awesome day Paul.
Feb 10, 2014 | 2003 Hyundai Tiburon
Where is door sensor miro switch located is it at the top or behind where door is ? regards Paul
Look at the door, there should be a tang on it that goes into a slot on the dryer.
The switch should be behind that slot
Mar 03, 2011 | Hotpoint TDC32 Electric Dryer
Dryer will not start
The temperature of the air being exhausted is monitored by the cycling thermostat and the thermal fuse mounted on the blower housing. The thermal fuse, which is wired in series with the motor circuit, fails when the cycling thermostat fails to regulate the exhaust air temperature. Failure of the thermal fuse results in the motor not running and the dryer not working at all.
Remove the dryer real panel to access the blower housing and check the continuity of the thermal fuse. Grab a volt-ohmmeter and set it to the R X 1 scale then disconnect one wire from the thermal fuse terminals then check the continuity of the thermal fuse. Replace the thermal fuse should it read open.
Indicate the exact model number of the dryer for specific troubleshooting and repair advice if you need further assistance and for the exact part numbers.
May 27, 2010 | Whirlpool LER4634J Electric Dryer
Suspect door handle is broken on Indesit Washer Dryer WD12x
yes u can open door from the inside,take the top off (take plug out first)put your arm down to near the door latch and you will feel the mechinism there just gently push down or up until the door opens,if water is still in the washer then take drain pipe out of the waste pipe and place a bucket on the floor then put the pipe in that to manualy drain it,hope this helps you,ps you can buy a new door handle from any washing repair shop and they are easy to replace just see how the old one comes off,rgrds,paul
Jul 07, 2009 | Indesit W 123 Front Load Washer
Wd63 door
The main cause with this model is water still in machine. Try a spin and look for water in drum. To empty manually lower drain hose into bowl untill empty. Door should then open.
Nov 08, 2008 | Hotpoint Aquarius WD63 Front Load...
No heat 90 series elcetric dryer
the main fuse is located on the blower box it is white,the thermo fuse(heater box fuse) is located at the top of the heater box,if you have a meter you can check it on the omns setting-mike
Aug 15, 2008 | Kenmore 65924 Electric Dryer
Candy CDV262
have you removed the filter/build up of fluff from the compartment just inside the door on the bottom
Jun 13, 2008 | Candy CDV262 Dryer
Locked door
Probably the latch is wedged with the item you jammed in it..
While trying to pull the door open you might try using the palm of the other hand to hit the area next to the latch. When and if you get back in and hopefully without breaking something, take the switch out and bend the metal lever on it so it sets higher and thus allowing the door to make better/earlier contact. It might be possible to get at the latch from underneath if you lay the unit on its back????Not sure, but worth a try. Let me know if you need more help.
Jan 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Door lock , wont light up , therefor wont start washing.
Click on "Candy" (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
You can also go to "troubleshooting" above, you are sure to find some solutions. And dont forget to rate me on this great site.
Jan 07, 2008 | Candy CNW136 Front Load Washer/Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
67 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
