Question about Timex Watches
My timex indiglo watch beeps on the hour. How do I take it off so it does not beep on the hour?
  • 109 Answers
Thwat is the chime. Some how it must have been turned on. Somewhere on the watch you will see a little bell or wave figure )))) There is 1 of 2 ways that you chime can be turned off. The first way to try is to push both buttons on the right hand side at the same time that should turn off the chime or the alarm, but if you do it more than once it will turn off whatever wasn't turned off the first time you pushed the button, and if you push them again, it will go back to the configuration you started with. The second way would be to go to your alarm modeand push the button that is NOT your light button or your "mode" or "adjust" button and push that button, that should cycle through the charm and alarm as went through before. If you find that neither one of these ways work, send me the model # and I will get you the information you need. PLEASE if you still have problems let me know!! Good Luck!!!
Posted on Aug 11, 2008
  • Jeffrey Huffman
    Jeffrey Huffman Aug 22, 2016
    Marathon wr 50 I've tried all of them and it won't work
I have a Timex Ironman model CR 2025 and I just want to turn the sound completely off but don't know how
Posted on Aug 13, 2008
4 Suggested Answers
SOURCE:
  • 6 Answers
SOURCE: how do i make my watch beep by the hour
Press and hold SET, then press START/STOP. This should turn the chime on. Press it again to turn on the alarm.
Posted on Mar 09, 2009
SOURCE: I can't stop hourly chime in my Timex Indiglo
1-Place watch on hard flat surface.
2-Hit repeatedly with large hammer.
If you should need further assistance just ask.
Posted on Oct 21, 2010
SOURCE: timex expedition indiglo wr 50m
I had the same problem, and could not find any answers on timex.com. After you place the battery in and it begins to beep, push all four buttons in at the same time. This should "reset" the watch -- at least it did for me.
Posted on Sep 28, 2008
My first easy reader timex watch beeps every hour
mcdevito75 here, The beeping may mean the battery is weak, even if the watch is new. Look for a small watch repair shop in your area.
Jul 21, 2010 | Timex 27191 Wristwatch
Hourly chime
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Feb 25, 2010 | Timex Indiglo Analog Watch
Jul 24, 2009 | Timex 27191 Wristwatch
Timex Expedition watch beeping continuously please solve
Try to get solution here:
http://www.timex.com/gp/node/n/255235011/190-2521384-6105829?ie=UTF8&timexBrand=core
Rate, please.
Jul 18, 2009 | Timex Expedition 84601 Wristwatch
How do i make my watch beep by the hour
Dec 27, 2008 | Timex 1440 Nylon watch
TIMEX IRONMAN TRIATHALON DIGITAL WRISTWATCH
ANALOG TIME
Pull CROWN and turn to set HOUR and MINUTE hands. TIME AND DATE A. Press and hold SET. SECONDS digits will flash. B. Press SPLIT/RESET to set SECONDS to zero. C. Press MODE to select HOURS. D. Press SPLIT/RESET to advance hours digits. Go through 12 hours for AM or PM. E. Press MODE to select MINUTES, press SPLIT/RESET to advance. F. Repeat to set MONTH, DATE, DAY, 12- or 24-hour time display. G. Press SET when done. BASIC OPERATIONS Press MODE to cycle through CHRONO, TIMER, and ALARM modes. Press INDIGLO to illuminate watch face. In any mode, press MODE to view time display. Press any button to stop alarm or timer beeps. INDIGLO INDIGLO CHRONOGRAPH A. Press MODE until CHRONO appears. B. Press START/STOP to start. C. Press SPLIT/RESET to record lap time. Display pauses. D. Press MODE to resume display of lap and split time (automatic after 10 seconds). E. Press START/STOP to pause chrono. F. Press START/STOP to resume. G. Press START/STOP to stop. H. When timing is stopped, press SPLIT/RESET repeatedly to recall last eight lap and split times. I. Press and hold SPLIT/RESET to reset chrono. MODE MODE START/ STOP START/ STOP SPLIT/ RESET SPLIT/ RESET SET SET CROWN COUNTDOWN TIMER A. Press MODE until TIMER appears. B. Press SPLIT/RESET to select timer operation (Countdown and Stop; Countdown and Repeat; Countdown and Start chrono). C. Press SET. HOURS digits will flash. Press SPLIT/RESET to advance digits. D. Press MODE to select TENS of MINUTES. Press SPLIT/RESET to advance. E. Repeat to set MINUTES, TENS of SECONDS, and SECONDS. F. Press SET when done. G. Press START/STOP to start timer. H. Press START/STOP to pause, press again to resume. I. When timer is stopped, press SPLIT/RESET to reset timer. Watch will beep when countdown reaches zero. ALARM AND CHIME A. Press MODE until ALARM appears. B. Press SET to select HOURS. Digits will flash. C. Press SPLIT/RESET to advance digits. Go through 12 hours for AM or PM. D. Press MODE to select TENS of MINUTES. E. Press SPLIT/RESET to advance. Repeat for MINUTES. F. Press SET when done. G. Press START/STOP to turn alarm on or off. H. Press SPLIT/RESET to turn chime on or off. When alarm time is reached, watch will beep for 20 seconds, or until any button is pushed. Alarm will repeat every 24 hours until deactivated. INDIGLO® NIGHT-LIGHT WITH NIGHT-MODE® FEATURE A. Press INDIGLO to activate light. Patented (U.S. Patent Numbers 4,527,096 and 4,775,964) electroluminescent technology used in the INDIGLO® night-light illuminates watch face at night and in low light conditions. B. Press and hold INDIGLO for three seconds (beep will sound) to activate or de-activate NIGHT-MODE® feature. C. While in NIGHT-MODE® feature, press any button to illuminate watch face for 3 seconds. Chime on Alarm on If your watch is water-resistant, meter marking or ( ) is indicated. Water-Resistance Depth p.s.i.a.* Water Pressure Below Surface 30m/98ft 60 50m/164ft 86 100m/328ft 160 *pounds per square inch absolute WATER AND SHOCK RESISTANCE WARNING: TO MAINTAIN WATER-RESISTANCE, DO NOT PRESS ANY BUTTONS UNDER WATER. 1. Watch is water-resistant only as long as lens, push buttons and case remain intact. 2. Watch is not a diver watch and should not be used for diving. 3. Rinse watch with fresh water after exposure to salt water. 4. Shock resistance will be indicated on the watch face or caseback. Watches are designed to pass ISO test for shock resistance. However, care whould be taken to avoid damaging crystal.
Oct 27, 2008 | Timex Watches
Timex Expedition, beeps very quietly and indiglo doesn't work.
To clarify... Replace the cover with the arrow on the back pointing directly at the stem. The Indiglo backlight, alarms and chimes should all work when the back cover is in this position.
May 04, 2008 | Timex Expedition 40141 Wristwatch
How to set
in order to unset the military time on the watch you must hold down the two top buttons until the the 12 hour format comes back. in order to turn off the alarm you must hold down the two right buttons until they beep..and then the alarm will go off
Jul 12, 2007 | Timex 1440 Sports Aggressor 56014 Wrist...
Watches Logo
2,185 people viewed this question
Top Timex Watches Experts
Janelle Schoonover
Janelle Schoonover
pacdave
 Mikey
Mikey
Are you a Timex Watch Expert? Answer questions, earn points and help others
