Question about E-Machines Computers & Internet
Is there a spot on this computer model w5243 to insert a sd micro trans flash adapter
  • 186 Answers
Just checked with the specifications of the computer.
No built in Memory card reader present.
Need to purchase a USB Card Reader.
Posted on Aug 11, 2008
    Master:
  • 397 Answers
You will need a USB card reader that accepts the standard SD cards to use with the adapter.
SOURCE:
I WOULD LIKE TO HAVE A MANUAL FOR INSTRUCTIONS ON HOW TO INSERT MY MICRO SD CARD INTO MY COMPUTER AND WHAT TO DO WHEN I INSERT THE MICRO SD CARD
You'll need an adapter to convert the Micro SD card into a normal size SD card, slot the Micro SD into the SD card adapter and then plug that into the computer.
Most computers then pop up a box to tell you that you've plugged something in, so you can then browse what is on the card.
Double clicking on the items on the card will then enable you to view the images/items.
Aug 16, 2016 | Cell Phones
How do I unlock micro sd flash memory card?
I guess u using adapter & there is small little pin on the side whitch u can move to position lock or unlock
Apr 05, 2013 | SanDisk 2gb Micro Sd Trans Flash Memory...
My micro sd card is locked how to unlock
Hi, i have here a photo that will show you on how to remove write protect on a micro SD.
1. You need to insert your micro SD into an adapter. 2. Unlock the micro SD through your adapter as shown below. 3. Once done, your micro SD is no longer write protected. eibraz_16.jpg
NOTE: The lock switch doesn't lock the micro SD into the adapter; The lock switch doesn't lock the data on the micro SD; The lock switch simply tells the "user" not to write. It just says "please, don't write me."
Aug 12, 2011 | SanDisk 2GB microSD Memory Card
Format micro SD card
Hi, The quickest way would be to insert micro SD card into an SD adapter or plug it into some card reader, then stick it into the computer's usb port. Proceed to "My Computer" right click onto memory card and select "Format".
I hope this helps.
Aug 10, 2011 | SanDisk 2GB microSD Memory Card
When i try to format my micro sd card system shows remove write protect how can i format it
I hope this helps.
Aug 09, 2011 | SanDisk 2GB microSD Memory Card
WHERE DO I PUT THE SD ADAPTER
Hello.
You don't need the SD adapter in your mobile phone. You may use it by inserting the micro SD card into the SD adapter, then insert the SD card adapter in a "SD card reader" and use it in a USB slot in your computer to access files from your "micro SD card".
I hope this helped you.
Thanks for using Fixya!
Please rate my answer.
Aug 04, 2011 | HTC Hero Smartphone
Hi..how do I transfer phone contacts to sd card?
hey you cannot transfer contact in sd card, unlike the picture images etc. but phone contacts you cannot,
Nov 15, 2009 | Samsung SCH-i760 Smartphone
It doesnt work when i insert the card with my micro memory card and asks for a disk
Hi likkle_miss_,
The Micro adapter has no memory in it. It is just an adapter to use so you can plug your Micro SD memory card into a larger (SD) slot. The SD Micro memory card needs to be inserted into the adapter.
Kingston Tech Support
Apr 22, 2009 | Kingston 1GB Secure Digital Memory Card
I dont know where to put this
Hi, First insert the micro SD into its adapter which resembles a SD card itself but has a small opening at the bottom to insert the micro SD. The adapter should not b locked while inserting or removin the micro SD. Now insert the adapter in the card readers slot which should be connected to a PC via a USB. If its a card reader then insert the adapter with microSD in the right side top corner of the card reader with the adapters copper pins facing down. OR if u already have slots in ur CPU to insert the SD card install it there, Now transfer files to ur card happily. NOTE: Rename ur device so that next time when u plug it in the adpter n connect it to PC, u wont get confused. Just right Click on the drive icon in ur PC n select rename n just giv any name as u lik. Rate he soln dude Bye..........!
Jan 25, 2009 | PNY 2GB microSD Memory Card
Computer is not reading my Micro SD, but phone is reading..
What size is the SD card in GBs? If it is larger than 2GB (4 or 8) do you have a SDHC card reader?
Also try formating the card first in the phone and then using it. Using it straight out of the package, while able to be written, my have difficultly with other devices reading the data.
Jul 23, 2008 | PNY 2GB microSD Memory Card
Computers & Internet Logo
80 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
