Question about Saeco Magic De Luxe Espresso Machine
I have a Saeco magic and ventilate comes up. I just did a descale and reset but comes up descale again.
  • 515 Answers
Push the button to make a cup of water.
Posted on Aug 11, 2008
SOURCE:
If descale not function, how can I do?
Try reading the user manual. You can find it at: http://www.cerinicoffee.com/saeco-user-manuals-28/ or there is a video on how to do it at: https://www.youtube.com/watch?v=k6iGAQ5C8hs
May 05, 2015 | Saeco Royal Digital Espresso & Coffee...
Cappuccinatore and steam does not work
Does water come out of the wand when you press the hot water button (top left)? Try ventilating and descaling the machine. More details about each can be easily found by googling.
How to descale:
https://www.youtube.com/watch?v=W20FJlKKCO0
How to ventilate:
https://www.youtube.com/watch?v=7sZWJ9z9xTA
http://www.purebean.com.au/office/coffee-machines.nsf/office-coffee-machines/saeco-royal-cappuccino-ventilate-message-showing
Jul 24, 2014 | Saeco Royal Professional Espresso Machine
Descale prompt stays on after descaling?
in the menu just after descal go to signal descal then press enter and reset the counter.
May 01, 2013 | Saeco Magic Comfort Plus Espresso Machine
Magic Comfort Plus Espresso Machine: how to descale saeco magic comfort...
  • The first thing you need to do is go to your menu. Scroll down to water hardness and push the enter button. Use your up arrow and move the number to 4 if it is not already there. Push the enter button. Once it is on 4, then scroll up to descale machine and push enter. Have your solution (NOT VINEGAR) Citric Acid dissolved in solution and put into water tank. Now open the knob for steam and let the machine do its thing. When it is all done it will say "Finished descaling". Rinse out the water tank and put in fresh water. Close the knob and then reopen it again. When it finished rinsing scroll down to "Reset Descale" Push enter and choose "Yes" with the arrow and push enter. This will bring up a message when it needs to be descaled again. You can also see how many coffee’s you have made. It’s just above the Descale Machine in your menu. Descale more often than Not Enough will keep your machine working well into the future.
May 07, 2010 | Saeco Magic Comfort Plus Espresso Machine
Saeco Magic Comfort plus: Despite descaling the machine twice, the Descaling notice remains lit on my screen. Brews great coffee but what gives?
Hi
In the menu there is a program below the descaling program that says Reset descale. Enter this program and choose "yes", and make sure that you push the enter button to lock your answer. If you don't it will still be there.
Also go to your water hardness and move it to the #4. This will prevent you from having to replace the boiler sooner than needed. Descale when told to by the machine.
Jan 09, 2010 | Saeco Magic Comfort Plus Espresso Machine
Saeco Magic Comfort Plus not dispensing coffee
Try setting the grind to the coarsest setting, if you still have the same problem, then descale machine.
Jan 09, 2009 | Saeco Magic Comfort Plus Espresso Machine
Ventilate message stays on
ventlate means run water through the steam pipe
like make water for a cup of tea
Sep 21, 2008 | Saeco Magic Comfort Plus Espresso Machine
No steam and ventilate
When you try to get out water, can you get a full cup of water or just a half cup?
How often do you descale your machine?
/Mirran
Aug 17, 2008 | Saeco Royal Professional Espresso Machine
Saeco Odea Giro descaling problem
Ok first check if the machine is in greenlight state when you press and hold the water button, as it will not work when the red exclamation mark blinking.
also check if the button work at all flipping back and forth to hot water and steam.
I have never had this problem that it dident work.
But remember this, you dont have to do the descaling again as that has nothing to do with the reset.
You can even reset the descaling alarm with out having done the descaling.
If that for some reason wouldent work I would think its the CPU card is not working.
Jul 14, 2008 | Saeco Magic De Luxe Espresso Machine
Electonic display will not change on a Siemens Expresso machine
I have had this problem with our coffee machine as well some how the machine has sucked air into the system and needs to get it out.
To ventilate the machine turn the dial on top of the 'magic comfort' sign (the one for the froth) and place a glass underneath. Keep the dial turned till the sign ventilate goes away then close the dial.
This process has always worked for me...
Thanks
Coffee Fix
Nov 13, 2007 | Saeco Magic Comfort Plus Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
214 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
espressofixr
Level 1 Expert
Ray Murphy
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
