Question about Gateway 975 Rackmount (gtwy975) Server
System fault indicator is blinking orange
Why is system fault indicator blinking orange?
    Guru:
  • 829 Answers
You need to check this site to help you.
http://support.taylor.k12.in.us/reference/Network/Dell/1750/5w862c10.htm
Posted on Dec 17, 2008
Orange light blinks 8 times
These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 18, 2013 | Philips 32PFL5322D Television
How to stop my tv from blinking orange 8 times
Dec 18, 2013 | Panasonic Televison & Video
How to fix
Orange light flashing
These blinks [Flashes] are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 14, 2013 | Toshiba REGZA 47HL167 TV
Alarm deactivates but car wont start,orange key on dash
Whenever this warning light or any other stays on in the dash it is indicating that the systems control module (or the system sensor in the case of lights like low oil pressure, door open indicators etc.) has detected a fault, it then disables the system (this applies to ABS,TCS, TCM, SRS, TPMS, MIL, CEL and BCM faults and others) as long as the light is on. You must now have the dealer hook up a special electronic diagnostic tool and "scan" the system for the fault code that is stored for the problem(s)
Legend of Abbreviations. ABS Anti-lock brake system. TCS Traction control system, TCM Transmission control module, SRS Supplemental restraint system, BCM Body control module. TPMS Tire Pressure Monitor System, MIL Malfunction Indicator Lamp, CEL Check Engine Light.
Nov 11, 2012 | Cars & Trucks
1992 Pajero 4wd system attempts to engage randomly, 4wd indicator lights blink
Whenever this warning light or any other stays on in the dash it is indicating that the systems control module (or the system sensor in the case of lights like low oil pressure, door open indicators etc.) has detected a fault, it then disables the system (this applies to ABS,TCS, TCM, SRS, TPMS and BCM faults and others) as long as the light is on. You must now have the dealer hook up a special electronic diagnostic tool and "scan" the system for the fault code that is stored for the problem(s)
Oct 31, 2012 | Cars & Trucks
05 chev impala airbag icon blinks
This light blinking indicates the Airbag system has been shut off due a fault being detected in the controls system. Have the system scanned to see what fault is in memory
Sep 04, 2012 | 2000 Chevrolet Impala
My computer has an orange persistant blinking light indicating battery is not charging. I believe the battery is still good because i have only had 142 cycles on it and the power managemnt system indicates...
try it and see how much will last ..The fact that it only had a few charging cycles it is not a warranty that it is still good or working ..It may be damaged or never been formated proper when was new..or overcharged ..or damaged by temperature ..and so on ..Try it in another system to be sure it is the battery ..and after that change it if it seam defective ..
try to reinstall your operation system ..and this way eliminate any thing that may cause this on the software level ..and if it does not hold the charge ..it either has a battery fault or the fault is physical ..and is not capable to charge the battery ..(maybe something wrong with the wiring)
Dec 08, 2011 | IBM Lenovo ThinkPad X61 Notebook
Dimension 3100 turns on the power button has a steady orange light there is also an orange light on motherboard cpu and power suplly fans working but wont bot up
Blinking amber (orange) indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this could indicate a problem with the power connections for the CPU on the system board (see "Power Problems" in your Owner's Manual).
Mar 06, 2011 | Dell Dimension 3100 PC Desktop
Battery light won't stop blinking green-orange-orange-orange-orange. Battery works fine, and the blinking keeps going even when plugged in.
Impending battery failure. System has detected a fault (May have weak cell or something) so eventually, a new battery
Sep 05, 2009 | Dell Latitude C400 Notebook
Gateway 975 Rackmount (gtwy975) Server Logo
524 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
