Thank you for replying,
As per the diagnostic LED's, it is an issue with Video initialization failure. Your computer has onboard Graphics which is built into the Motherboard.
Video Initialization failure could happen if there is :
Unseated AGP card
Bad AGP card
Bad motherboard
As per your Svc Tag your system doesn't have AGP Graphics Card, Probable issue with MOBO.
This computer doesn't have a AGP Slot (Graphics Card Slot) to try connecting Graphics Card.
Need to repair/replace MOBO.
Try this website..this is a manual for Dell Dimension 2400 PC Desktop it includes how to remove the cover of your tower. Check it out.. http://www.andovercg.com/datasheets/dell-dimension-2400-series.pdf
If it's an older 2400 series and you suspect it doesn't have a good signal going to it, I would try the monitor on a different tower to see if it's the monitor. If it isn't, I would recommend that you try to disable and change the VGA card in the Dell, if possible to a known good VGA card.
Also, try wiggling the connections at the monitor and graphics card, if this applies.
Or else, it might be a lost cause for that tower.
Good luck on getting the Princeton monitor working with your Dell Dimension 2400 series.
open the casing of the system. at the lower part, you will see 2 slots. you can insert it in one of them. put on the system and then install the driver for the card. pls rate me. thanks
