Question about Canon EOS 400D / Rebel XTi Digital Camera with 18-55mm Lens
Canon XTi built in flash
The flash on my XTi won't stay closed. It won't stay closed when I push it back down-any suggestions? Thanks
dr syn
  • dr syn Sep 01, 2008
    I'll give it a try. Thanks
  • 81 Answers
With the flash in the up position and looking at the flash housing, there should be a small, metal hook. Make sure it's not bent or distorted. I should be straight and spring loaded all the way towards the front of the body. Check for freedom of movement also.
Posted on Sep 01, 2008
The built-in flash on the Canon Rebel XTI won't flash.
i am having the same problom try this i just found this ... http://www.fixya.com/support/t1021194-flash_not_working
Aug 20, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Close Flash On Xti
Turn off the camera and remove the batteries. Then try to close the flash by pushing it down lightly. If it still won't remain closed, your camera is faulty and you should bring it back for a repair/replace.
Hope this helps,
/Chris
Jan 17, 2009 | Canon Rebel XT / EOS 350D Digital Camera
I have a canon rebel xti with an 18 to 55 lens .. I recently bought an external flash to sit in the hot shoe .. now when I removed the flash from the hot shoe .. the cameras own flash will not pop up and...
I had the same problem.
Look closely at the hotshoe. Inside it, way over to the side, under one of the tabs on the side, is a tiny metal strip. When you attach an external flash, the strip is pushed down and holds down a tiny button that deactivated the pop-up flash. The strip can get bent so that it doesn't let the button come up even when the external flash is removed.
Very gently take a fingernail or a jeweler's screwdriver and run it underneath the metal strip. I had to do it a couple of times to get mine working again, but it's working great now!
Dec 30, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Built-in flash does not work
DO NOT MESS with a new camera (or any other new equipment).
Take/send it back to the vendor, The purchaser has rights also. Number one it must work.
I don't know your location but in UK (& Europe) we have very strict consumer legislation.
Mar 30, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
XTi 400D flash
It appears that the small hook that holds the flash down is not latching properly and perhaps needs replacement. If your camera is still under warranty, call Canon Customer care. Even if the warranty has just expired (like 1 or 2 months), they generally honor it and get the service done free of cost.
Mar 27, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon XTi Built in Flash
I found the answer and fixed my flash. Look on http://photo.net/bboard/q-and-a-fetch-msg?msg_id=00ODWf
This will describe how, if you have been using a speedlite alot, than the little tab under the shutter release side of the hot shoe can get bent down thus constantly pressing down (toward the bottom of the camera) the small button which deactivates the pop-up1.gif flash even when the speedlite is not attached. Just bend the tab up a little with a jewler's screwdriver, turn the camera off and on and voila!! Fixed!!! Dan describes pushing the tab down, but on the xti, the tab needs to be bent up to release the flash deactivation switch and fix the problem. Thanks to Dan D on photonet for saving me a service call.
Feb 09, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Xti rebel 6 mths old - flash will not pop up
This will describe how, if you have been using a speedlite alot, than the little tab under the shutter release side of the hot shoe can get bent down thus constantly pressing down (toward the bottom of the camera) the small button which deactivates the pop-up flash even when the speedlite is not attached. Just bend the tab up a little with a jewler's screwdriver, turn the camera off and on and voila!! Fixed!!! Dan describes pushing the tab down, but on the xti, the tab needs to be bent up to release the flash deactivation switch and fix the problem. Thanks to Dan D on photonet for saving me a service call.
Feb 03, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Flash
Jan 24, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Xti and Speedlite 200E
The only way to solve the problem I see is to turn the flash into non-TTL one. It can be easy done by opening four screws at the connector side of the flash, unsoldering or cutting the BROWN line and closing the connector back. The AF assist led will work.
That I did on my 200E with Canon 400D camera and all works file.
Enjoy!
Jan 06, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Flash doesn't work
Dec 02, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon EOS 400D / Rebel XTi Digital Camera with 18-55mm Lens Logo
182 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
