Question about Nor-Lake Freezer Norlake Refrigeration 6' x 6' Kold Locker Walk-In Freezer - 6' 7'' High w/Floor
GE GSS22JFMCWW I have a few problems with my side by side. Probably related to the same thing. The freezer will get cold ice will be solid and then it will start to defrost. The fridge section will be somewhat cold and then warm up. I noticed this last time that frost was building up on the back wall of the freezer. I am not sure if the problem is with the thermostat, the heater or the motherboard. (Or I could be way off base) HELP!
  • mikeyras Aug 11, 2008
    The temperature difference is about 15-20 degrees. I am guessing, I didn't get a reading. The butter in the fridge would get really soft and the ice cream would start to melt.
    The temperature difference is about 15-20 degrees. I didn't take an actual reading but the butter in the fridge gets soft and the ice cream in the freezer does too.
  • 481 Answers
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
these are the usual suspects.
heater in the back wall of the freezer:
thermal switch also in the back wall of the freezer
Posted on Aug 11, 2008
    Master:
  • 521 Answers
For sure the problem lies with the thermostat.call a proper technician to replace it.
    Master:
  • 623 Answers
Try to defrost first then turn it on
  • ritchie dempacco
    ritchie dempacco Aug 11, 2008
    could be a bad condenser
    Master:
  • 555 Answers
What is the temperature difference between these cold and warm periods?
Freezer side not freezing
Check for ice / frosting inside the freezer .... If present you probably have a defrost problem.... This causes the freezer coil to ice up and block the air flow ... the causes could be a bad defrost heater , defrost timer, defrost sensors, or control board. Also make sure that the condenser coil is clean. remove ALL dust with a vacuum and a coil brush .the coil is located either on the bottom or on the back side of the unit... You didn't give the Make and model #
Apr 04, 2014 | Freezers
IHave a ge side by side refrigerator not cold enough and freezer has frost on back wall and some items are not frozen
your GE self defrost is not working. 1. clean the ice and look for the heater element and your lemi switch. If you have a GE profile, they have a motherboard at the back of the ref. if all i the part i mentioned are working, just replaced the motherboard. at searspartdirect.com
Apr 06, 2013 | Kenmore Freezer 20.3 cu. ft. Frost Free...
I have a GE GTS 221C fridge/freezer. The fridge is working fine. All of a sudden, the freezer is not freezing. Just cold, but not enough to keep food frozen. The fan on the freezer is working.
remove the rear cover inside the freezer if it has a lot of frost on it,then the evaporator coil is frozen up and you cant blow cold air over or thru a solid block of ice,defrost it,then check the defrost heating element,defrost thermostat and timer or defrost circuitry for no power or defective components,you can use a hand held hair dryer to defrost it quicker
Jan 08, 2011 | GE Freezers
I have a GE side by side freezer/refrigerator. The
When you say "The items in the freezer are cold with some ice on them. I have tried emptying the ice tray, but that does not help." Is there literally ice from the ice bucket dripping on the food and refreezing, or is there a layer of frost on the food? the noise you are hearing is most likely due to the evaporator fan motor running at alternating low and high speeds. This is a variable speed motor, but there could be quite a few reasons why the motor is not rotating at regulated speeds. the fan motor itself, a faulty thermistor, you could also have an issue with your main control board, or least of all a wiring issue.
You would be wise to have it inspected by a reliable refrigerator repair service, to at least determine what the problem is for certain.
Mar 31, 2010 | GE 13.7 cu. ft. General Electric Upright...
GE side by side refrig/freezer Mod. TFH24JWTA WH. Ice maker stopped working, stop/start wire is down (on). Get water through the door, but not sure if it goes to the ice maker. Ice maker is empty of water....
usually yes if no water to icemaker could be water valve solenoid. . first you can remove cover on icemaker and put the unit thru a test mode. find the plastic or medal cam in center of icemaker head when cover is removed., theis is a flateblade screw center get a small screwdriver and turn screw counterclockwise for about a 1/4 of a turn , icemaker will start cycling if icemaker ok then it will go througha cycle let it do its thing usually a few minutes for it to cycle, if fills you may have a bad icemaker, if no fill then valve may be bad. make sure you have good water pressure from your water supply that can cause icemaker problems.
Sep 17, 2009 | Freezers
Amana BR18 Doesn't get cold
Mine is doing the same thing
Jul 05, 2009 | Amana Freezers
Not cold enough. ice on back of freezer but not making cubes
sounds like you might have a deforst problem or your drain is blocked not allowing the water to drain when the fridge goes into defrost.
Apr 24, 2009 | Freezers
Freezxer dosn't work
Is the fan inside the freezer working? If the fan isn't working the freezer will never get ice cold.
Nov 23, 2008 | Frigidaire 12 cu. ft. / 340 liter Upright...
GE GSS22JFMCWW
try this link
www.fixya.com/support/t325008-ge_gss22jfmcww_side_side_refrigerator - 28k -
Aug 11, 2008 | Nor-Lake Freezer Norlake Refrigeration 6'...
Freezers Logo
859 people viewed this question
Top Nor-Lake Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Nor-Lake Freezer Expert? Answer questions, earn points and help others
