Question about Symantec Winfax Pro 10.03 (winfax10.03) for PC
When trying to install error number 106. file group: liveadv file:lrsetup.exe
  • dcauf May 04, 2011
    Hi Tried copying the disk but would not copy data 1 i think it might be the disk is bad and i manually deleted all files in registry and ini and still would not install
    Master:
  • 395 Answers
Hello, There are two things you might want to check. First: make sure you have more than 50MB available on your hard drive for the installation. If not, try to free up more disk space and try the installation again. If the installation went half way through, you might need to manually uninstall and reinstall. Second: If the installation process immediately failed when started and you have lot of disk space available on hard drive, you might want to copy entire installation CD into your hard drive and start the installation from hard drive (not from CD) Let me know if I can further help.
Thanks
Posted on May 03, 2011
  • Blue Chip 999 May 04, 2011
    Sorry to hear that. It now appears the CD is bad. You might need to clean the CD. Does your CD look in good condition? Try to clean it to see if it works. If not, you can download your winfax pro 10.03 ISO from the link below and install to see if it works. You might have to register with the site for free access to download page.
    Or you can call Symantec, or chat with them to request for access to symantec link to download your winfax pro since you own the product and CD is bad. I do it all the time for my users at work.
    Do it so you can get a clean and working software for your PC.
    If you prefer to contact symantec, here is the link
    http://us.norton.com/support/contact/con...
    Let me know how it works.
    Thanks
SOURCE:
Getting an error 106 while installing adobe photoshop 7
Error Number 106 indicates that the installer cannot decompress a file. This can happen if the CD-ROM is dirty or damaged, if hard disk space is insufficient, or if the installer conflicts with an application or device driver.
Please clean your install disk with a lint-free cloth. If that still does not work, check to make sure you have the 280MB minimum hard disk space available.
Feb 15, 2011 | Adobe Photoshop 7.0 for PC
Error 106
Error 106 (net::ERR_INTERNET_DISCONNECTED): The Internet connection has been lost.
The error "ComponentMoveData...Error Number: -106..." indicates that the installer cannot decompress a file. This can happen if the CD-ROM is dirty or damaged, if hard disk space is insufficient, or if the installer conflicts with an application or device driver.
((this is what I'm not exactly clear on))
You could try copying the contents of your CD-ROM (or the essential folders) to your HDD or a network drive. You will soon find out of there is dirt or damage on the CD, and if not, you can easily then install from your HDD or network drive.
try installing the photoshop in safe mode......
Oct 13, 2010 | Google Chrome
Error code 1713. Computer will not install office 2010
When you attempt to install Microsoft Office 2010 suite by double-clicking an .msi file you receive the following error message:
Error 1713
MSI_package_name cannot install one of its required products. Contact your technical support group.
You cannot install an Office 2010 suite or individual program by running an .msi file that is provided in the Office suites.
To solve this issue, you need to run the Setup.exe file for installation.
This should resolve the issue
Sep 06, 2010 | Computers & Internet
Error code 106
do this
Dec 01, 2009 | Ingenico 6770 Capture Pad Signature...
Photoshop 7.0 installation fails with the error message: "An error occurred during the move data process : -106" Upon install process it makes it to about 1% then gives the following error code....
one problem that could cause this error is lack of administrator rights,
right button click the setup.exe or whatever it called and select run as administrator,
Or if it's Vista try the compatiblity help , right button click the app, select properties and select run as XP service pack2 etc
Regards
gewiz.co.uk
Nov 30, 2009 | Computers & Internet
Error code 106, how to correct?
have you try to reinstall the software ??
You do it in this way, uninstall the software, reboot the computer and then reinstall the software.
If it still not work then return here :O)
have a nice day
please rate my answer
Oct 24, 2009 | Adobe Photoshop 6.0 for PC
ERROR CODE 106
restore your system to previous date where its working fine then check
Nov 05, 2008 | Adobe Photoshop 7.0 for PC
Installing error code -106
I suggest go to Start/Settings/Control Panel/Add remove programs.
Check and see if the program is in list and remove it. While in control panel go to system/Device Drivers check non have a yellow mark on them if so reinstall drivers or upgrade Reboot and try again.
Jul 22, 2008 | Computers & Internet
what this suggests is that the files cannot be transfered to the hard drive because of either you havent the latest version of .net http://www.microsoft.com/downloads/details.aspx?FamilyID=0856eacb-4362-4b0d-8edd-aab15c5e04f5&DisplayLang=en, or you are low on hard drive space or afaulty disc. download from the above link first, then if still not installing try copying all the installation files across to your pc and try again, but check you have enough hard drive space.
Aug 24, 2007 | Adobe Photoshop 7.0 for PC
Symantec Winfax Pro 10.03 (winfax10.03) for PC Logo
Top Symantec Computers & Internet Experts
Peter Dragonetti
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
