Question about Cell Phones
Nokia n95 battery does not hold its charge only lasting about 12 hours on standby
  • boppster40 Jan 27, 2009
    Same as above and I have replaced numerous sells and to no avail this is all fuked up im over this shity N95 what’s the point of having a phone if you have to have the fuker plugged in to the wall all the time
    New Friend:
I HAVE A NOKIA N95 MOBILE ANG IT WAS PURCHASED IN AUSTRAILIA BUT WHEN I USED IN INDIA THAT TIME THE BETTERY IS CHARGED ONLY 2HR AND I TRY TO CHANGE MY BATTERY BUT NO SOLUTION SO PLS TELL ME ABOUT THIS.
Posted on Nov 09, 2009
6ya staff
SOURCE:
FOR HOW LONG CAN THE BATTRY LAST BEFORE YOU CHANGE IT
How Long Does the Nokia E65 battery REALLY last?
Ever wonder how long the phone battery actually lasts? For the first use of my Nokia E65, I charged the phone for 24 hours after receiving it (still not sure if this is necessary), then took it off the charger Saturday afternoon. The battery low warning first sounded 54 hours later. This was after
•Calls: Around 15 calls made and about 3 calls received, with almost 40 minutes call duration in total.
•Data: 726kb data sent and 3.96mb downloaded
•WIFI: About 20 minutes of WIFI use
•Applications: Use of Skype and Gmail application as well as a bit of Nokia Maps and Google Maps
The battery eventually gave up after 2 more hourse of standby. The Nokia website says the following about the Nokia E65 battery:
•BP-4L 1500 mAh Li-Po standard battery
•Talk time (maximum): GSM up to 11 hours; WCDMA up to 4h 40 min
•Standby time (maximum): GSM up to 18 days; WCDMA up to 20 days;WLAN idle up to 170 hours
If you are wanting to make comparisons with the Nokia E71 battery life, this is what the Nokia website claims for the Nokia E71. The Nokia E65 and E71 both use the same battery - BP-4L 1500 mAh Li-Po battery but E71 is slightly more demanding on the battery life.
•Talk time:- GSM up to 10 h 30 min- WCDMA up to 4 h 30 min
•Standby time:- GSM up to 17 days- WCDMA up to 20 days- WLAN idle up to 166 hours
If you are willing to help, maybe you can do the same experiment for your Nokia E65. Use the call logs and the data counter under "Connectivity" and measure how long your Nokia E63 battery lasts with "normal" usage. Report your findings in the comments below and someone just as curious as you googling battery life E65 will also benefit from your efforts.
Your mobile habits may not be as demanding as me but I hope this helped you in your battery life calculations for the Nokia E65.
To charge a battery from empty to full, it took 2 hours and 40 minutes
....... If you are willing to help, maybe you can do the same experiment ... It lasts me about 40 hours before I get a battery low warning .... I got my Nokia E65
Jan 05, 2011 | Nokia e65 Cellular Phone
Duration of nokia n95 battery is 4 hours with or without use
try to refresh the battery by drainig the battery until it shutdown and then try to charge it for 12 hours. if the proble is the same after trying this. then you need to replaced the battery of your phone.
Aug 06, 2010 | Nokia N95 Cellular Phone
LG Viewty battery discharges quickly .....
Charging duration does not connect to battery lasting duration in any way.Optimal charging time is 3 to 4 hours.your battery will drain soon if you keep your touchscreen pressed continuously in your jeans pocket.Keep bluetooth switched off. Reduce the brightness of your mobile display. Play music threw headphone rather than using loudspeakers.
Jul 19, 2009 | LG KU990 Viewty
Nokia n95 won't hold a charge
if you bought a new battery but it has made no difference so i think it may b something so you must repair yor mobile
Jul 17, 2009 | Nokia N95 Cellular Phone
Battery Problem for Nokia N81 8gb
I bought new nokia n 81 few weeks ago.its battery finishes very quickly.plz help me
Jul 06, 2009 | Nokia N81 Smartphone
Sudden Battery drainage - from full charge within 14 hours
turn off bluetooth if its on because bluetooth wastes battery life on any phone.
go to Tools > Settings > Personal > Display > and change the light settings. if its on the highest light setting then that would be a major factor on why your battery is draining quickly.
hold the menu button and check if any applications are still open, close any that you don't need open.
Apr 20, 2009 | Nokia N95 Smartphone
My phone nokia n95 losses its battery charge every 3-4 hours
Its time to replace the battery. Also check that the charger is working properly, and the contacts on both the phone and the charger are not oxidised. If they are, try scraping the contacts gently with a sharp object like a jeweller's screwdriver , etc..
Oct 25, 2008 | Nokia N95 Cellular Phone
Battery charging problem
if it have warranty replace it,
else make empty  then charge it.
ur's kishore chowdary.
+919441133420
May 17, 2008 | Nokia N95 Cellular Phone
Dash standby has a maximum of 12 hours
Are you using the factory charger? If you use after market chargers you could basically blow the battery.
Thats kinda what it sounds like.
May 04, 2008 | T-Mobile Dash Smartphone
Cell Phones Logo
91 people viewed this question
Top Cell Phones Experts
Ekse
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
