Question about Fujitsu Siemens Premium Line P15-1 15" LCD Monitor
Fujitsu-Siemens P15 TFT power/picture problem.
My monitor has recently developed a problem when being turned on.
The power light flashes orange in a steady rhythm (approx 1 second on, 1 second off, repeat) and no picture whatsoever appears.
The PC boots normally, I can "guesstimate" the user login location for WinXP on the welcome screen, and sometimes can hear the startup noise through the TFT speakers (very faintly as the light pulses on).
I have tried 2 AC Leads, 2 analogue cables and my DVI-D cable as alternate inputs, and the mainboard graphics too, but still no signal. The monitor usually puts up a grey box saying "No Signal - Entering Sleep Mode" when no signal is detected, but this has not appeared. A second monitor on the same graphics card, with the same cables shows a picture, as it does on the mainboard Graphics card.
Sometimes, I can jiggle the leads in their sockets, and eventually (after many hours) it appears to solve whatever the problem is (or just wishful thinking after hours of frustration), and return the picture.
Sometimes when this happens, it is a normal start/power-up sequence, but sometimes the screen is totally whited-out, and I have to cycle the power to get a "waxy", striped effect which disappears from top to bottom as the real picture appears.
Any help or ideas would be welcome, but for the meantime, I'm having to buy a new TFT tomorrow, as leaving this one on 24/7 to prevent the problems and frustration, is not really a long-term solution.
Thanks.
  • lone3wolf Sep 24, 2008
    No, not solved.
    I /think/ it could be the LCD "initiator", or something to do with the power (either the socket in the rear, or the little PCB board for the buttons on the front...). Other than that, I'm not sure.
    I bought a second screen in the meantime.
  1. No start-up. Clicking sound from speakers
  2. solution
  3. Replace C922 and C923 (both 1000uF/16V). Also replace C924 and C925 (both 470uF/16V). on powerboard
JK electronics
Den Helder
document.getElementById('showwaitmessage').style.visibility = "hidden";
Posted on Sep 11, 2010
I have problem too
Posted on Sep 23, 2008
  • tm1344 Sep 23, 2008
    Hi
    Did you solve this problem with your monitor yet? Because I have the same problem and I don't feel like buying a new one at this moment.
2 Suggested Answers
  • 52 Answers
SOURCE: Fujitsu-Siemens P15 TFT power/picture problem. it take time to turn on.
It does indeed sounds like the capacitors, I had this problem last year with a Medion monitor where it would turn on and off, when I spoke to Medion they did say that it would need a repair but at the time I wasn't enclined to pay the repair fees for something that may happen again!
Personally I would stick with your plan of getting a new monitor because my view on monitor hardware issues is that if it's happened once it will happen again even if you do repair it resulting in a lot of hassle!
Posted on May 27, 2009
OSD locked
OSD MAIN CONTROLS REMAIN UNLOCKED ON MONITOR 170A PHILIPS SERIAL NO AU 015240
Nov 24, 2012 | Fujitsu Siemens Premium Line P15-1 15" LCD...
Fujitsu siemens primergy rx 300 server orange led flashing and no start
What light is flashing? Here's the manual: http://manuals.ts.fujitsu.com/illustrated_spares/content/RX300_S3/pdf/ba.pdf
Oct 09, 2012 | Fujitsu Siemens Siemens PRIMERGY RX300...
There is a problem in LCD, when become ON so start flickering continuously
Need more information. Does it switch on / off intermittently or the screen brightness is varying ? Refit / Replace signal cable.
Samir.
Feb 07, 2011 | Fujitsu Siemens Premium Line P15-1 15" LCD...
FUJITSU SIEMENS CSS LED FLASHING
Orange CSS LED bulb is light what does that mean
Dec 27, 2010 | Fujitsu Siemens Siemens PRIMERGY RX300...
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 12, 2010 | Fujitsu Siemens Premium Line P15-1 15" LCD...
Fujitsu Siemens 19 W LCD monitor: no image
Temporarily connect a different monitor to your computer, to see if your video-card is the problem.
Temporarilyh connect your monitor to a different computer (desktop/laptop), to see if your monitor is the problem.
Try a different "data" cable between your monitor and your video-output port.
Jun 12, 2010 | Fujitsu Siemens Premium Line P19-1 19" LCD...
My Fujitsu Siemens Esprimo V5545 laptop won't start up, I have a green flashing light and a orange flashing light.
well my only take is that first, check if the vga still works secondly, check memory and lastly, the monitor so you really have to seek an legitimate laptop techie.
thanks and god bless!
Mar 29, 2010 | Computers & Internet
I have a problem with my fujitsu siemens scaleo p, when i turn it on, only the orange light turns on, it sounds like the computer is doing something, but nothing on the screen, maybe it´s on...
Might as well try to access it thru safe mode with networking if it s working fine , if not try to connect an external monitor / or better yet if you can access safemode with networking try to disable some of the start-up programs thru msconfig.
ERNZ
Feb 08, 2010 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
May 27, 2009 | Fujitsu Siemens Premium Line P15-1 15" LCD...
Fujitsu Siemens Premium Line P15-1 15" LCD Monitor Logo
912 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
