Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Not cooling The frige has power but lost all cooling ability to both the frige and the freezer. fridge & freezer warms up. we adjust controls it is fine for  couple days then warms up again. Is this just a therostat?
  • scottmaynard Aug 11, 2008
    thanks for the help confirming my suspicions.
    Master:
  • 521 Answers
It is quite possibly the thermostat but also check the compressor if its not working then replace the relay .
Posted on Aug 11, 2008
    Genius:
  • 3,422 Answers
HI,
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
  • Please don't forget to accept the solution as fixya.
    • 594 Answers
    It could be a thermostat or it could be the relay on the back of the fridge. the relay on the compressor may be bad. pull the fridge out and see if you can feel the compressor. and see if it is hot and if the fan is blowing... if not replace the relay.
    Temperature playing up going up not down
    Refrigerator Not Cooling Enough - GE Appliances
    products.geappliances.com/appliance/gea-support-search-content?...
    If the refrigerator is running, but not cooling at all or is not cold enough, several ... To view a short video on adjusting the temperature on set point models: Play ...
    How To Fix A Refrigerator and Freezer That's Too Warm ...
    www.partselect.com/Repair/Refrigerator/Refrigerator-Freezer-Too-Warm/
    If your fridge and freezer is too warm, don't give up - we can help. ... The cold control is a temperature controlled switch that supplies power to the compressor ...
    Nov 21, 2015 | Refrigerators
    Samsung Fridge Freezer (Freezer on top) Model SR-52NXA Freezer is cold but fridge is not cooling ?
    remove evrything from bottom of freezer. take out the shelves . You will see a panel on the back of the unit with screws holding it on take these off . under it is the freezer exchange coils they got froze up,
    and frosted full so now no air is circulated between the cabintes, refridge and freezer do not use any sharp object to clear it use a towel and blow dryer to thaw it even a spray bottle with warm water, but don't pick at it!!!! you can puncture the coils . take your time and you will save your unit. also while your at it pull it away from the wall remove that small panel from the back, and the grill from the front and with your long reach nozzle vacuum the heat ex changer coils under the unit. put back together carefully and it will run for a while longer i have one that is a 72 model still runs great Oh any change you find is mine!
    Sep 06, 2012 | Samsung Refrigerators
    I have a ge frige that the freezer works but frige is warm
    Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
    Refrigerator not Cooling or Fridge not Cooling
    How to Defrost Refrigerator Defrost Timer Problem
    Water Running in refrigerator from Freezer
    Refrigerator or Freezer not Cooling or Getting Cold
    heatman101
    May 01, 2011 | GE GTL18JBPBS Top Freezer Refrigerator
    My frige is not cold, just cool, turn the T stat to coldest & no good. The freezer seems fine & I looked in the back & the fan is running. It doesn't seem to be blowing cold air or...
    Two thoughts. If the fan is running... and you can here it in the freezer when it is on. Then the fan is fine and it is the mixer control. IF the fan is not working, then fix the fan.
    The mixer control is in the top of the fridge where the air comes out on the wall between the fridge and freezer.
    I think maytag calls this a cold control / damper.
    Basically it controls the air flow rate between the fridge and freezer. When it is opens it allows air from the freezer into the fridge and cools it off.
    Hope this helps.
    Jun 17, 2010 | Maytag MSD2756G Side by Side Refrigerator
    Lg fridge code er ff does not cool in fridge
    ER FF is freezer fan motor failure code. this directs air into the fridge compartment from the freezer room. dead fan=warm fridge.
    Jun 04, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
    Our freezer seems to be working fine, however, the fridge part doesn't seem to be cool at all
    all you have to do is defrost the frige the freezer sometimes will freeze up with ice in the back of freezer where the air flows into frige
    Mar 13, 2010 | Haier HTE18WAA Top Freezer Refrigerator
    Freezer cold, refrigerator warm
    The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
    Sep 10, 2009 | Refrigerators
    Freezer and frige not that cold
    The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
    If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
    check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
    You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
    How to check everything
    http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
    Aug 30, 2009 | Neff K3965XO Side by Side Refrigerator
    Freezer is working good but the frige is 52
    OR
    Aug 17, 2009 | Refrigerators
    FRIDGE NOT COOLING
    Your damper and controls are on this diagram. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=MFD2560HES&productCategoryId=0161000&brandId=3048&modelName=MAYTAG-REFRIGERATION&diagramPageId=00006&componentDescription=CONTROLS&documentId=M0412077&backToLink=Return%20to%20Sub%20Components%20list
    Jul 13, 2009 | Maytag MFD2560HES Bottom Freezer French...
    Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
    158 people viewed this question
    Top Kenmore Refrigerators Experts
    Sal DeAngelo
    Jim Goldsmith
    Jim Goldsmith
    Arnel
    Arnel
    Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
