Question about Hotpoint Aquarius WF000 Front Load Washer
Not finishing the wash cycle
Our Aquarius wf350 starts as normal but at some point during the wash cycle, it will suddenly stops before it completes it's wash program. When it stops, all lights are illuminated and the door remains locked. W then have to switch it off, put it on a spin and drain cycle and switch it back on again. When it completes this cycle, we can then open the door but the washing inside is wringing wet, as though it is not draining properly.
  • Anonymous Mar 25, 2014
    door not opening after wash cycle complete
I have now solved the problem with our WFxxx washing machine. I was moments away from doing the same (dumping it and buying a new machine), but thought I would take the back off and look to see if I could find anything obvious first.
I am not very technically minded so I was well pleased with myself when I fixed the problem and saved myself a small fortune on a new washer. I was also amazed that it was something really simple that nearly cost me loads of money. The problem cost me nothing to repair but I got a bit wet (a small price to pay).
The problem was caused by a blockage in the sump Assembly.
I removed the small cover plate at the bottom of the back cover (held on by just 2 screws). This gives access to the drain pump and sump assembly. Using a flat bladed screw driver I removed the hose clip securing the sump assembly to the main drum outlet. I also removed the clips securing the sump assembly to the drain pump and the clip securing the pressure sensor sender tube to the sump assembly.
All clips removed I then removed the sump assembly from the main drum. At this point a got a good soaking as trapped water gushed from the main drum outlet!!
Inside the sump I found about £2 in loose change and several paper tissues. (Someone's not emptying their packets before doing the laundry!!!). This blockage was preventing the water from draining away from the drum effectively.
After removing the coins and the rest of the gunge that was causing the blockage (not a very pleasant job and a bit smelly!!), I washed out the sump Assembly in hot soapy water and re-assembled the whole thing. The machine has worked perfectly ever since. The whole repair process took me about 40 minutes and saved me a fortune!
Sump Assembly complete with small-bore pressure switch tube. (Below)
Not finishing the wash cycle - f16e905.jpg Pressure Switch (Below)
Why did the blocked sump assembly effect the wash cycle?
As I said earlier, I am not technically minded so this is simply my theory of what went wrong.
When the washing machine is draining, water entering the sump is forced up the small bore tube to a Pressure Switch. While there is water pressure pressing against this Pressure Switch, the machine knows that there is still water in the main drum and will not move on to its next part of the wash cycle until the water pressure on this switch is released. Because of the blockage in the sump, the pressure was not released from the pressure switch causing the wash cycle to come to a stand still.
I hope this helps other people experiencing a similar problem with the WFxxx models. A very easy fault to fix (once I discovered what was causing it) and It's certainly cheaper than buying a new machine!
Posted on Sep 19, 2008
Same problem here. We dumped it and bought a new machine. Seems to be a common problem with WFXXX models.
SOURCE:
Washing machine Hotpoint Aquarius WMF740
Its normal for the door not to open with water in the machine this is a safety feature the door will not open immediately after the wash cycle completes their is a delay before it can be opened.
May 04, 2015 | Washing Machines
Washer stops during normal wash cycle for a minute or more, and then continues. Would replacing the timer fix it?
If it actually goes on and finishes the cycle and that really bothers you replace it. If not leave it alone and allow a little more time to complete its cycle. The lid switch only keeps the spin cycle from going with the top open.
May 23, 2014 | Whirlpool Washing Machines
I load the clothes into the washing machine, I turn it on select cycle and the door locks and will NOT unlock. The door will however unlock after the cycle is finished.
Not sure if you're unable to open the door AFTER you stop the cycle. That may be normal operation as a safety measure (won't open until after your cycle has completed). However, if your model DOES allow for opening the door during cycle operations then your electronic door lock may be defective.
Mar 08, 2011 | LG WM-2277HW Front Load Washer
WATER IS COMING OUT FROM THE BOTTOM OF THE WASHING MACHINE ONCE THE WASHING HAS STOPPED, IT DOES NOT LEAK DURING CYCLE AND IT SPINS AND DRAINS FINE..
i would inspect both the hoses on the pump
no leak during cycle is explained because water is moving through them to fast to leak when the machine settles it starts to leak
Oct 15, 2009 | Hotpoint Aquarius WD63 Front Load...
Drum doesn't really rotate on wash cycle.
No solution, but I have the same or similar problem - bootom agitaor works, top doesn't. Also softner spots clothes during spin cycle - help - I can't afford a repairman!
May 17, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Water left after finishing wash
I have a Bosch Dishwasher and the E-Nr is SGS4362EU/03. The machine is approximately 4 years old, in good condition and has been working very well. Suddenly, there is water remaining after it completes a 50 degrees C wash cycle. This is also evident with the pre wash cycle and the 65 degrees wash cycle.
I have checked and cleaned the filters. I have loosened the internal pump white cover (Torx T 20 screw) and checked for any physical blockage - none. I have also checked for any drainage hose kinks - none.
I have tried a series of empty washes and the machine drains the water during the wash cycles. The dishes are also have a dull colour and show show signs of not being properly rinsed during the wash cycle.
Please assist.
Reagrds,
Brian
Dec 27, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Stops mid-cycle
Hi SaviorSound,
I'm Harvey the Master Plumbr.
Your question is: You have a MDB7100AWB that has been working fine for the last 7 years. Now all of the sudden it will not complete a wash cycle in any mode (including auto clean). It consistantly stops at 85 on normal wash & at 65 on light wash and then clicks/buzzes about every 3 seconds, like it wants to continue - but never does. Any clues as to what to try? Is 7 years all I can expect to get?
Perhaps. Your d/w is stoping at the point where it should be turning on the 'heat dry' phase. This can be expensive. At this point I would be compairing the cost effectivness of repair verses replacement. Wish I had better news for you.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 10, 2008 | Maytag MDB7100AWB Dishwasher
Hotpoint WD420 Washer/Dryer - Not completing cycle
I WOULD FIRST CHECK THE COLD WATER VALVES ONE COULD BE INTERMITTEN
Jun 25, 2008 | Hotpoint Aquarius WD63 Front Load...
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Hotpoint Aquarius WF000 Front Load Washer Logo
204 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
