Question about WYSE Winterm 3150SE Network Terminal
Reconfigure winterm I have forgoten the user name or password, any of the posible ones I can think off I've tried but no luck, so how can I reset the winterm terminal without right password???
Try holding down the 'g' key when booting -this just worked for me.
Posted on Dec 20, 2008
Press and hold "s" momentaly after boot-splash. This is reseting to default settings of the WYSE-thinclient
Posted on Dec 21, 2008
How do I reset the Admin password on a H.264 Hexaplex 4ch network DVR
try to log in with user name admin and password ttvvtthuanyuan
Mar 03, 2015 | Home Security
Can't find password for my router. tried: user name - admin , password - admin user name - admin , p...
Reset the device to default settings, then reconfigure the device's SSID and Security Key. Try here for support, you didn't post the Edimax model number: http://us.edimax.com/ You can use this procedure to reset: http://compnetworking.about.com/b/2009/03/11/the-30-30-30-hard-reset-rule-for-routers.htm
May 17, 2013 | Edimax Computers & Internet
I messed up my login passwords how can I reset?
I think you should try to reset the router to factory default settings and reconfigure it manually.
Press and hold the reset button on the router for 30 seconds. Release the reset button and wait for 30 seconds. Power cycle the router and reconfigure it manually.
See how to reset Linksys router
See Linksys router setup
Jan 16, 2012 | Linksys Wireless-G WRT54G Router
I am unable to locate the key code for the WRT160N. when I try to go through the ipaddress admin as user and password will not work.
If you have not changed the password previously, leave the user name blank and use the password "admin".
If you have changed the password, you will have to reset the router and reconfigure it.
To reset the router using the reset button, use these steps:
  1. Look for the red reset button at the back of the router.
  2. Press and hold the reset button for approximately 5 seconds.
Thi will set it back to the factory defaults. It will need to be reconfigured.
Mar 23, 2011 | Linksys WRT160N Wireless Router
I forgot my password and cant get on the internet how do i fix
If you can remember your password,reset the linksys router.
Resetting the router to the factory defaults will delete any changes you have made to the router, including any security settings.
1.Look for the red reset button at the back of the router.
2.Press and hold the reset button for approximately 5 seconds.
To acces the router configuration panel -open your browser(Internet Explore,Firefox..)
Type http://192.168.1.1 to acces your pages. Enter user name and password,leave user name blank and enter admin as the password.
Good Luck!
Jan 21, 2011 | Linksys WRT160N Wireless Router
How can i reset my user name & pasword ??
If you don't know the user name password of the router then try the default one. For D-link routers the default user name is admin and password is blank (means nothing, leave it empty). If this doesn't work or if you have changed it in past then to put it back to factory settings you need to reset the router.
To reset the router please try the following steps:
1. At the back of the router you will find a reset hole. 2. Press and hold down the reset button for 15-20 seconds with the help of a pen or a paper clip.
Note: Router should be turned on while doing the reset. Also, after reset you need to reconfigure the router means the internet and wireless settings.
Please revert in case of any issue. :)
Regards,
Rashish
Aug 02, 2010 | D-Link Computers & Internet
Will not let me into router. only have an option for password and nothing works. tried resetting to default and it still doesnt work
are you trying to access the router set up ?
First make sure that your computer will be connected to the router with the ethernet cable.
Now check the IP address and Default gateway on the computer. Default gateway will be the IP address of the router.
When you try to access the router it will always ask you for the password.
Try the default user name = admin and password = admin
or try user name = blank ( do not type anything), password = admin.
if that is not working then the password of the router must be changed.
try some different password that you use most often.
If that doesn't work then you will need to reset the router and reconfigure the router.
once you reset the router , you will loose all the settings on the router.
Reset the router for 30 seconds. unplug the power. plug it back in. wait for 1 minute and try to open the page again.
Click Here to know more about how to reconfigure the router
Nov 17, 2009 | D-Link GamerLounge DGL-4300 Router...
D-LINK ROUTER DIR 300 USER NAME AND PASSWORD REQ
There posible ways you can but you have to save your strenght by reseting your router using the reset button so that you can you can reconfigure it afresh
Sep 30, 2009 | D-Link DI 514 Wireless Router (DI-514)
USER NAME AND/OR PASSWORD
There is no way to obtain your username and password. Not an easy way anyways.
Your best bet is to reset the router, and reconfigure it. Good Luck.
Jun 20, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
I have problims with my password i think i forgoten my password
You could restart your system and just before the Vista logo (after your manufacturer's logo screen) - tap F8 a few times and you should get to advanced OS menu. Select SafeMode and see if you get a user named as 'Administrator', try to login to that user. If you are successful - you can reset the password for the other user / create a new user for login.(Goto Control Panel > User Accounts) - [Legally, you can't / should not hack the system - though there are ways to achieve this with enough resources :) - Google is your best bet]
Jan 11, 2009 | Computers & Internet
WYSE Winterm 3150SE Network Terminal Logo
1,287 people viewed this question
Top WYSE Computers & Internet Experts
Nicholas Bannister
Sunday Ojelabi
Sunday Ojelabi
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
