Question about Maytag Refrigerators
MAYTAG SIDE BY SIDE MSD2356AE. FREEZER NORMAL TEMP. FRIG. 60 DEGREES.
  • MWMORTON245 Aug 11, 2008
    NO AIR BLOCKERAGE, COMPRESSOR IS RUNNING, FREEZER IS FREEZING, FRIG. 60 DEGREES
  • 594 Answers
Make sure that there is nothing blocking the flow of air coming in. the fridge is cooled by the air in the freezer. also you might think about replacing the relay on the compressor. it may be going out.
Posted on Aug 11, 2008
  • Cameron Viseth
    Cameron Viseth Aug 12, 2008
    ok than i would more towards the thermostat. it is controlleing the freezer but not controlling the tempature in the fridge.
Whirlpool Frig/Freezer - Frig side too warm at 60 degrees
Check for another fan to cool the fridge side. It could be bad.
murf427
Aug 01, 2012 | Whirlpool Refrigerators
Freezing problem in maytag frig
the probe from the temp panel is not sensing correct temp or the panel itself is bad...call a tech to check it out
Feb 04, 2010 | Refrigerators
My frig. in the garage.. The freezer works great in summer months but in winter months it doesn't. Why is that?
Good day,
That is normal. The thermostat that runs the whole machine is located in the refrigerator compartment.
When it reaches normal temperature, it shuts off. In winter months that may mean as long as 12 hours or more. Thus not enough running time per day to keep the freezer near it's normal temperature.
Engineers design domestic refrigerators to be in an area comfortable to humans. Normally 70 degrees or higher. Thus your problem.
The only solution is to bring the machine inside.
Sorry.
Thank you for using FixYa
Dec 29, 2009 | Refrigerators
Freezer works, frig doesn't
there is a fan on many newer units that blows cold air from the freezer side to the frig. If that fan is not working, the frig will be cool, but not 34° like you want it.
Nov 25, 2009 | Frigidaire Refrigerators
Everything in my frig is frozen
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .. I don't know what he was doing with the putty unless he was stopping up the vent which won't work because you have to have the air circulation for the fridge section to work. The fridge temp control may be the problem.
Aug 14, 2009 | Maytag MSD2456G Side by Side Refrigerator
Fridge is not cooling
You probably need an adaptive defrost control which is located in the back right hand corner of your fresh food compartment. You have to dismantle the overhead controls to get to it. If you had to defrost your coils, and the heaters test good, then you probably need the above control.
Apr 06, 2009 | Maytag MSD2454G Side by Side Refrigerator
Frig does not stay cold enough
you are either low on coolant or the fan inside the freezer compartment is stuck or defective.
Mar 25, 2009 | Kenmore 55203 Side by Side Refrigerator
FREEZER NORM TEMP. FRIG. 60 DEGREES.
DEFROSTED COIL WITH HAIR DRYER BEHIND FREEZER WALL BELOW FAN,
REPLACED FRIG. THERMOSTAT.
Aug 11, 2008 | Maytag 21.6 Cabinet Depth Side by Side...
Frig not cooling and now freezer is frosting
Val sounds like a defrost problem..go ahead and defrost your freezer again... check your evaporator drain your fan motors let let me know and I can help you Krazytech
Mar 27, 2008 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
140 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
