Question about Compaq Computers & Internet
My brother's computer's internet connection isn't working. This happened to my computer awhile ago, and it turned out a switch on the side was turned off. I can't find a switch on my brother's compag laptop. Is there one?
  • a732 Aug 11, 2008
    Thanks, I found the switch, but I geuss that wasn't the problem. My computer is even farther away from the router but it's connected fine. His computer says that there are no networks in range.
  • Compaq Master
  • 3,051 Answers
On my compaq i dont have a switch i have a button on the top part of the keyboard regards mike
Posted on Aug 11, 2008
SOURCE:
Monitor says "No Signal" when trying to wake it up
I had that problem awhile ago, but the issue was a loose connection.
If you test your PC with another good working monitor/cable and still receive a no signal message, then the problem is with your PC.
The solution could be as simple as dust inside the unit interfering with the signal, and needs to be blown out, or try removing the power cord and hold-in the 'on button' for about 30 seconds to a minute; then reconnect the power cord and turn it back on.
Other solutions: open up your PC and take out and put back in the video card; remove the ram memory strips, rub the end gold colored strips on a clean cloth and put them back; or maybe you have a bad video card.
Mar 23, 2015 | AOC Computers & Internet
Wont connect to internet
Make sure that the modem/router is up and running. Turn the player off and unplug from wall socket for 1 minute. Then plug in and switch on. This might help.
Jan 30, 2018 | Magnavox NB500MG9 BluRay Player
Beeps that it is warm
bad weld unlikely part with leak that should have been replaced more likley
freezer way to warm sounds like the charge they put in took about 6 months to leak out the hole that was never repaired
need a servicer
Mar 29, 2017 | Viking 48 in Built In Professional...
I bought my netgear WGR614 box 6 months ago. Everything was working fine until yesturday. It picks up an excellent connection but wont connect to the internet. I tried turning it off for awhile, resetting...
This has happened to me before. I had to unplug my router, then unplug my modem aswell (if you have one) and I waited for a good 10 minutes. Then plugged my modem in and let it boot up all the way, then plugged in my router, and it worked fine after that.
Hope this helps, Nathan Taylor
Jul 18, 2011 | NetGear WGR614 Router
Toshiba satellite a350 laptop stopped connecting to internet
Do you have the wireless switch on on the laptop??? its easy to accidently turn it off, i think its in front or on the side, it should slide up and then that should turn it on.....sometimes this happens.....there should be a light indicating whether or not the its on on the computer.....hope this helps....
Jan 06, 2010 | Computers & Internet
Got a new computer tower, hooked up my previous printer to it, but it isnt hearing th commands, it turns on, but nothing comes out...mfc-240c by brother
You might want to try Belarc Advisor (freeware) which will characterize your system in great detail so you can examine what may be missing. You will need to have Internet Explorer installed since they use this for displaying the results of the system scan.
Belarc Advisor
I save an updated copy of the resultant report at random intervals of a few weeks to look for changes made.
Apr 27, 2009 | Brother Multi-Function Center MFC-240C...
Laptop wont connect to internet, keyboard tweaks
Sounds to me like fabreez got on some components as well as sticking the buttons together underneath. Take it to a shop to get cleaned, and hope thats all it needs. May have fried the network adapter.
Mar 14, 2009 | Computers & Internet
Computer not detecting
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
THEN, do the "Repair" in the Philips Device Manager
Jun 01, 2008 | Philips HDD1630 MP3 Player
Computers & Internet Logo
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
