Question about E-Machines Computers & Internet
Need a new motherboard for my T3958. Order from gateway or is there an after market for new motherboards? Called e machines and received no help from them. This is a machine not used everyday and mostly for email communication. I never heard of a motherboard stop working with so little hours on it.
    Genius:
  • 1,056 Answers
You can use an aftermarket board. Just find one that will accept your processor and memory type.
That machine should have a Intel Celeron D 2.93GHz
with PC2700 RAM
There are a number of boards that you can use that will be a lot cheaper then ordering from Gateway.
Posted on Aug 11, 2008
  • Coss Aug 12, 2008
    The CPU socket is an LGA775, the PC2700 RAM is 184 pin.
    Might make searching a little easier.
Emachines t3958 wont power on
The green light means there is standby power to the motherboard.
Power button may be broken, does it 'click'?
With the case open, do any of the fans start, then stop?
If yes to the above, you may have a bad power supply. Can you borrow one to try?
Last test before it's the chip or mother board:
Remove the connectors for power from drives, video card, all but the motherboard (Do NOT disconnect small connectors on the motherboard, just POWER from the drives and video card)
Remove any expansion cards except video. Note where they go.
Try again. If it starts and fans run ok (video may not work but fans go normally.), shut it off, reconnect the video card. Try again, power off, connect or install one thing at a time until it stops running again. The last item plugged in is the culprit.
Always one item, power on, try it, then power off, try the next one.
Apr 02, 2010 | E-Machines T3958 (827103050974) PC Desktop
I have a emachine t3958 it will not turn on
Your power supply has gone out. This could have been caused by a surege, dust or bad power outlet.
You can purchase a replacement off eBay for under $25.00.
Jan 30, 2010 | E-Machines T3958 (827103050974) PC Desktop
NEED TO REPLACE THE dc CONNECTOR ON A MA7 GATEWAY LAPTOP
You will need to First Order/Receive a New Replacement DC Jack...
Then The Laptop Needs To Be Disassembled Down To The Motherboard.. let me know if you need full instructions on the steps involved in the DC Jack Repair..
Nov 24, 2009 | Gateway Computers & Internet
Motherboard of my T3958 E-machine was destroyed by a power surge. Want to replace it with a stronger more effiecient one, but don't know the measurements of the first one.
simply replace it with a motherboard of micro ATX form factor. that should fit most system chasis. Most mother boards these days come in that size
Sep 26, 2009 | E-Machines Computers & Internet
Upgrade mother board t3958
to upgrade a motherboard... you would need to replace it with another one, on a motherboard you can upgrade memory, cpu, video card, hard drive, parts that are connected to it, but you don't really upgrade the motherboard itself..
May 10, 2009 | E-Machines T3958 (827103050974) PC Desktop
Ram
Part Number: 2511451 Intel (Fedora) motherboard Pentium III - 667-MHz
The motherboard will support a minimum memory size of 16-megabyte (MB) and a maximum of 512-MB. The BIOS automatically detects memory type, size, and speed. The memory type, size, and speed can vary between the sockets. The memory modules do not have to be installed in a certain order or in a specific socket. Bank 0 or the DIMM1 slot is located toward the rear of the motherboard.
Gateway Support Document for your motherboard:
http://support.gateway.com/s/MOTHERBD/INTEL/2511451/2511451nv.shtml
http://support.gateway.com/s/MOTHERBD/INTEL/2511451/251145101.shtml
http://support.gateway.com/s/MOTHERBD/INTEL/2508226/250822604.shtml
Note: The individual part number for this motherboard is 4000684. This number helps technicians locate the motherboard in the CRM. Some invoices list the motherboard separately and not as part of the sub-assembly, which includes the motherboard and processor. You cannot use the individual part number to replace this motherboard. Use the sub-assembly number at the top of this page.
Note: Before adding, removing, or reseating any hardware, verify that the computer is unplugged. Then, either wait 30 seconds or press the power button to discharge the motherboard. The motherboard maintains power even after the computer is turned off.
A bios update is available for your system here:
http://support.gateway.com/support/drivers/search.asp?st=pn&param=2511451
This may, or may not, correct your problem.
Available on the Web at www.gateway.com/support are the following: technical support for Gateway products, live chat with a Gateway Trusted Guide, files for downloading, and e-mail support. Additional technical support can be obtained using Fax on Demand system at (800) 846-4526 and Automated Troubleshooting System at (800) 846-2118.
Jan 28, 2009 | Gateway (4000684) Motherboard
Gateway 40000287 Motherboard Intel Pentium ---- Manual? anywhere?
try tom's computer hardware on line or go to intel .com its probably a intel board surf the web under motherboards . when I was building machines thats what i used to find out about boards i would pickup at computer flea markets. Over clockers . com
Dec 31, 2008 | Gateway Computers & Internet
Emachine front panel power switch
Here's the Support Link for your desktop. Look under User Guides, Hardware Reference. Also look on the motherboard for markings such as PW or PS and an indicator to where the wire goes.
Nov 23, 2008 | E-Machines T3958 (827103050974) PC Desktop
Gateway Computer
CVI error is a visual interface error, most likely a graphics card built onto the syetm board. However the motherboards are no longer available but there are a number of ways to upgrade this pc if all else in in good order.Contact for further support
Oct 18, 2008 | Gateway (4000811) Motherboard
Startup
Sounds like a new power supply needed...could be motherboard, but a power supply is $29 and a new motherboard could be up to $250 from GW. Good luck.
Aug 28, 2007 | Gateway GT4016 (6528) PC Desktop
Computers & Internet Logo
37 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
