Question about Califone International 1010AV Turntable
Fuse issue My Califone 1010AV began to smoke when I started the player this afternoon. Could this be a fuse issue or something more of an issue that needs special care? Thanks in advance.
  • Anonymous Feb 13, 2009
    What part was smoking? Mine had smoke coming from under the speaker jack. When I checked underneath, and turned it on, then off quickly, it was the IC Amplifier chip. Its part number is TDA2030A and are available on eBay.
    President:
  • 948 Answers
Something more. A fuse is there to prevent damage (smoke) from components. If you smelled smoke, something is likely seriously awry and you should check it or have it checked out.
Posted on Jan 25, 2009
Smoke from fuse box
You have a short somewhere. You might have some wires melted. I would disconnect the battery to prevent more damage. Visually check the fuse box and the fuses. If you find anything burnt or smell something burnt. Have a mechanic trace the short to repair.
Feb 21, 2016 | 2009 Chevrolet Silverado 1500
After hitting a pot hole, I began having electrical issues starting with the tire pressure light coming on then the nav screen and radio cut off. is this related to the collision?
start checking your battery connections, fuses, fuse box connections. all the wiring on the impact side of the car. it sounds like you knocked a ground wire or something loose.
Mar 23, 2015 | 2007 Land Rover Range Rover Sport
Alesis Multimix8 started smoking and now won't turn on. If it is a fuse or something how do i replace it?
A blown fuse will not produce smoke. A component failed and probably fried a resistor, which would smoke. That in turn would blow the fuse.Just replacing the fuse will not cure the problem. Your unit needs repair.
Dec 27, 2012 | Alesis Multimix 8 USB 2.0 - 8 Channel...
Just inherited an old califone 1010av. It turns on, but when I put the record on the turntable and bring the needle down, there is no sound and the arm slides to the center of the record very quickly. I...
SOUNDS LIKE NEELDE BROKEN.TO TELL PUT FINGER UNDER NEEDLE PULL BACK FINGER GENTLEY AND YOU SHOULD FEEL A POINT ON THE END OF THE NEEDLE.IF NOT OR UNSURE SEE IF YOU CAN SEE THE END OF THE NEEDLE THERE SOULD BE A SAFIRE OR DIOMOND IN THE END OF IT THAT SITS ON THE RECORD IF NONE IS SEEN REPLACE NEEDLE.
HOPE THIS HELPS
NORMAN
Aug 23, 2011 | Califone International 1010AV Turntable
Audio system began smoking and quit playing at all.
Hopefully there is a fuse connected to the positive line of the radio. Remove the radio from the dashboard and check for a red wire. There should be a white or black fuse holder close to the radio. Replace the fuse and the burnt wiring and recheck the status of the radio. Hope this helps!
Jun 09, 2010 | Car Audio & Video
Adjust pitch on a Califone turntable.
This one is actually fastened from underneath (inside). You need to open the player up and you will see the usual C shaped fastener on a cleat near the motor assembly. Most old direct drive record players have a C pin around the spindle that you can unfasten (pry with a twist) with a screwdriver. Irealize you figured this out yourself, but I'll take the guess work out for someone else... yeah..l you gotta take it apart!
Feb 15, 2009 | Califone International 1030AV Turntable
Wiring on the firewall began to smoke after the blower motor stop
If the smoking wire is the one you added to the system, likely it is either shorted somewhere or the blower motor is going bad and drawing too much voltage. If the smoking is coming from factory wiring, for the heater? If so, there is a short there (likely the problem or part of the problem you bypassed) this should have blown a fuse. But , you'll need to identify the cause either way before you burn it down!!! PS when adding a hard wire to anything, always use a fuse in the line and be careful where you hook it up to avoid other electrical problems down the road>
Jan 31, 2009 | 1993 Jeep Grand Cherokee
Califone dvd/vcr 200
Hi, you can download the manual from the site given below:
www.retrevo.com/s/Califone-DVDVCR200-DVD-Players-review-manual/id/540dj397/t/1-2/
Hope my info solves your problem, Thanx for using fixya, Good luck.
Sep 29, 2008 | Califone International DVDVCR200 DVD...
Removing turntable
pry the clip off of the center pin and lift
Dec 30, 2007 | Califone International 1010AV Turntable
Califone International 1010AV Turntable Logo
188 people viewed this question
Top Califone International Audio Players & Recorders Experts
Michael Galve
Michael Galve
Michial Gueffroy
Ben Armstrong
Are you a Califone International Audio Player and Recorder Expert? Answer questions, earn points and help others
