Question about Kenwood KVT-617DVD Car DVD Player
Dual dvd stereo bypass
Just need to figure out bypass to be able to watch movies while driving for kids in back
  • 1,586 Answers
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On my Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Posted on Aug 11, 2008
Try to bypass the pink cable
It is a safety feature on the stereo to bypass hook to the ground . The makers of the stereo don't want you watching movies an driving.
Jan 29, 2013 | Audio Players & Recorders
Tip
How to watch pyle plts76u car dvd whilst driving and how to bypass parking brake...
If you want to use your dvd player whilst driving then i will tell you the best way to go about doing this but please read these warnings first.
WARNINGS.
1. any work you do at your own risk
2. it highly illegal to use any dvd or telly whilst driving
3. if caught using dvd whilst driving you will get a big fine and points on your license for driving whilst distracted.
4. if you have an accident whilst the dvd player is driving you wont be insured and you will be liable and charged with dangerous and reckless driving.
5. any short due to work carried out can cause you to destroy the stereo and in some cases cars have been set on fire, so if you are unsure what you are doing then please dont go ahead with this work as you could end up in a right mess.
Ok now the warnings are out of the way.
I take it you dont want to watch the dvd whilst driving but a passenger does i dont reccomend this work be carried out if the driver is planning on watching the dvd whilst driving, its not worth the risk its just to dangerous.
How To Bypass The Parking Brake To Watch DVDs'
the best way of doing this would be to get hold of the instruction manual to install this stereo you might get this off the net but if not you can contact the makers and they will be able to send you one for free, just the cost of postage to pay.
Now to actually bypass the parking brake witch dont let you play dvd whilst driving what you need to do is locate the wire that goes to the parking brake now this wire should be a brown wire unless somebody has re wired the stereo to fit other cars, once you are sure you have located the correct parking wire thats brown you then need to remove this wire from the parking brake. Now you need to earth this wire out to any metal on the car and secure it to that metal part this should then bypass the parking brake system for you.
You do this at your own risk you can destroy the stereo and in some cases set fire to the car so if you have never done this type of work before then please leave this to somebody who knows what they are doing.
Take your time, make sure you have the correct earth wire any other wire and you will short the stereo out destroying the stereo and possibly your car, so be warned.
on Mar 03, 2010 | Car Audio & Video
Clarion 745 vd dvd says audio only
It has a parking brake wire......usually pink. Will say on it what it is.....If you want to bypass it, just ground it to the stereo itself.....after grounding it, it will show picture.....safety feature so you're not driving and watching a movie at the same time
Nov 13, 2012 | Car Audio & Video
Linear phase uv8 and letting my kid watch movies while i drive
You can let your kidwatch DVD but not while your driving unless the screen is out of the view of the driver
Feb 17, 2010 | Phase Linear UDV9010 Car DVD Player
Dual xdvd 8625 double din emergency brake bypass
you can ground it,then enter the code 26604 after u insert a dvd real dvd then press stop twice then enter the code it should work
Jun 06, 2009 | Dual XDVD8170 Car DVD Player
Kenwood DDX514, bypassing the parking break wire for video
Just hook up the parking brake safety switch from the unit to ground. That will do the trick. Hope this helps
May 23, 2009 | Kenwood DNX7100 Car Video Player
Can I watch movies while moving?
There is a wire that goes to the park brake switch. That will need to be permanently grounded to bypass the security feature, but if it's a factory player, it may be integrated into the car's electrical system and may give you a park brake light on the dash if you do this. Prolly best to remove the wire from the park brake switch, and move it to a switch you create on the dask or something, that way you can turn it onn and off at will.
Apr 26, 2009 | Car Audio & Video
Dual problems
Ground the parking brake wire to any bare metal area on the van this should allow you to watch well in motion.
then do the following.
** Insert Audio CD
** Press Play
** Hit Stop Twice
** Use remote to enter 26604
** Hit OK
** Take out Audio CD and Insert a DVD
Aug 26, 2008 | Dual XDVD8181 Car Video Player
Ptid-5300
Its illegal to watch a dvd/tv when the vehicle is moving so the manufacturer disables the function.. Usually by connecting a cable to your handbrake indicator or to your vehicle speed sensor VSS.
Youll have to find out which one it is. You can then find out how to disable it. JVC's normally ground the H/brake cable
Apr 04, 2008 | Power Acoustik PTID-900 Car DVD Player
No Audio through the radio
turn off the dual audio..by pushing the 3 and 5 button on the radio unitwhere the small headphone light on the radio is off and you should get dvd sound on the radio....that puts it in single mode not dual mode..also play with the mode button on the back of the center console ...
Mar 26, 2008 | Myron & Davis ADM169GY 7 Inch Flip Down...
Kenwood KVT-617DVD Car DVD Player Logo
262 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
