Question about Goldstar Microwave Ovens
Goldstar 1310W built in
Help
My glass turntable middle part broke. I replaced the glass tray but it wont turn now. there is nothing in the middle that makes it turn.
HELP
  • Goldstar Master
  • 9,086 Answers
The following parts are in the turntable system: The turntable motor, underneath the floor of the microwave; the turntable coupler, which is like a small plastic piece; the turntable support, either a three-legged or circular piece with wheels; and the glass turntable tray.
It sounds like maybe your turntable support is missing?
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here. Goldstar owner manuals can be downloaded here.
Posted on Aug 12, 2008
The turntable stopped turning and when I press start, nothing happenes. The clock still works and the light comes on when opened but, nothing else.
Check the turntable guide to make sure it is lined up properly and that there is no debris caught in it. You may need to re-align or clean your turntable guide.
Cleaning and realigning a turntable guide;
Remove your glass turntable cooking tray from your microwave. Gently wash with warm soapy water to remove any debris. Next remove the turntable guide and clean it in the same manner, with warm soapy water. Pay particular attention to the turntable rollers. There could be spilled food particles caught in the rollers, hindering the rollers' movement. Also, gently cleanse the internal cavity of your microwave, paying special attention to the area below the turntable.
With the internal cavity, turntable, and turntable guide completely clean and dry, return the parts to your microwave. First place the turntable guide on the bottom of the microwave. There should be a circular groove in the bottom of the microwave cavity keeping the turntable guide in place. Follow the guide with the turntable cooking tray. Carefully place the glass tray over the turntable guide and onto the drive bushing. The drive bushing should fit neatly into the grooves on the bottom of your glass cooking tray. It may take some adjusting before the tray will sit properly onto the drive bushing.
Test your microwave after this thorough cleaning and realigning in order to determine whether this has solved your problem. DO NOT run your microwave with nothing in it.
CAUTION: Your microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. We strongly suggest you seek the assistance of an appliance repair technician when conducting any microwave oven repair.
Also, Examine the plastic drive bushing the turntable tray sits on. It may have become worn, or even may have split in two;
Drive bushing replacement
Inspect the plastic drive bushing located below your microwave oven's turntable tray. There may be some debris blocking the tray's range of motion. Clean away any blockage you find, and then test your microwave to see if this has cleared up the problem. DO NOT run your microwave with nothing in it.
However, if upon your inspection, you notice that the plastic drive bushing below the turntable tray is worn and/or broken, you will need to have the bushing replaced. Consult with a certified and experienced appliance repair technician. Replacing a drive bushing is a lengthy and involved process that the average layman should not perform.
Regards.
Jan 09, 2012 | Emerson Microwave Ovens
I have a built in convection/microwave oven model AWM540IX, the turntable is not turning, is there anything I can do or will I need to get professional assistance?
Good luck....
Mar 21, 2011 | Whirlpool Microwave Ovens
The turntable doesnt turn. The clock, timer, start/stop and the heating do all work. How can I get this thing removed from the built in unit less than 4 years old
Good luck.....
Mar 19, 2011 | Microwave Ovens
Fuse was blown i replaced fuse then when i tried using oven it made a almost like grinding noise for about a half sec then blew fuse again tried unhooking turntable didnt help
Your Magnetron or High Voltage diode (or both) has failed.
Replace as required but IT HAS VERY DANGEROUS VOLTAGES INSIDE. PROCEED WITH CAUTION!
Nov 03, 2010 | Goldstar MV-1310W/B Microwave Oven
When the glass tray turns it makes a noise. When
This problem is commonly attributed to a turntable motor that has worn out and may need to be replaced. The motor is attached to (and is located under) the center plastic piece (called a turntable shaft or coupler) under the middle of the glass tray that you were referring to. The following link explains how to access and replace one:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
This is a very simple repair, that usually is not expensive. The price range will be determined by the model and manufacturer. This repair can also be performed on an over the range model microwave oven WITHOUT uninstalling it.
You can refer to any of the following websites for comparison:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites listed offer helpful exploded view diagrams to assist you with locating and properly identifying the part(s) you need. If the model number is correct, the part number for a replacement motor is WB26X10135.
If you have any questions, please post back and let me know. I hope this helps you.
Mar 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Plastic piece for turning turntable has partial meleted.
This is a pretty simple, inexpensive fix,
The best place to order parts for this brand is Encompass (formerly Tritronics).
If you don't find the part on their Web site, I would call them with your model number. They are toll-free at 866-779-5835.
Feb 02, 2009 | Goldstar MV-1715 1000 Watts Microwave Oven
I need a copy of the operating manual for a Goldstar oven MV-1310W. Where can I find one?
You can download that here
Jan 22, 2009 | Goldstar MV-1310W/B Microwave Oven
Broken turntable
The owner's manual is online at:
http://www.emersonradio.com/owners/MWO%20manual/MW8992SB-RD.pdf
You can contact Emerson at their number in the manual for a replacement.
I always suggest that people place food (especially popcorn) off-center on the tray (not in the middle) because the heating is better, plus the extreme heat is not always applied to the same spot in the tray each time.
Food placed in the middle will not cook as evenly.
Good luck, and we appreciate your thoughtful rating of our answer.
Nov 17, 2007 | Emerson MW8987B/W Microwave Oven
Microwave Ovens Logo
146 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
