Question about Ricoh Aficio CL2000N Laser Printer
Card Stock/Thick Paper is not Fed From the Bypass Tray
The paper starts to feed, goes in about 1/4 - 1/2 inch, then twists a slight amount and the paper jam message comes on. We've tried everything. HELP!
  • ddar Aug 11, 2008
    Do you have any other suggestions?
  • 446 Answers
Either the feed roller is slipping pls clean with moistened cloth, ensure that you have selected the right paper size in the properties once you have selected the print file pls
Posted on Aug 11, 2008
My office has the bizhub c360, and when I put paper into the bypass tray, it prints from the main tray instead of the bypass tray. The settings on the printer are for bypass tray, the settings for my...
Hi the machine could be defaulted to print from the main trays if you have the same type paper being fed from the manual feed same size paper then it will automatically take it from the default trays
IF you take the paper out of the trays and put it only in the manual feed will it print and take it from the manual feed also you have to tell the machine when you use the manual feed what size and type of paper is in the manual feed once you tell it what paper and type of paper like card stock you then need to make sure when you go to print that it is set on your computer with manual feed and type of paper must match what is set on machine
Mar 09, 2011 | Konica Minolta Bizhub 222 Black and White...
When printing in color, the color runs
Specifications state the following:
Plain paper (16 lb to 24 lb),
thick paper 1 (24-1/4 lb to 40 lb),
thick paper 2 (40-1/4lb to 55-1/2 lb),
thick paper 3 (55-3/4 lb to 68 lb),
thick paper 4 (68-1/4 lb to 72 lb), OHP transparencies, postcards*, letterheads,
colored paper, envelopes, label sheets, banner paper (24-1/4 lb to 55-1/2 lb)*
Duplex: Plain paper (17 lb to 24 lb), thick paper1/2/3 (24 lb to 68 lb
*Can only be fed through the bypass tray.
These specs are directly from the user guide.
Is the paper running through the bypass tray
Jul 13, 2010 | Samsung CLX-2160N All-In-One Printer
Paper feeds crooked
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 10, 2009 | Epson Stylus CX6000 All-In-One InkJet...
My HP Deskjet 882C no longer pulls paper from the feed tray
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Jan 07, 2009 | HP DeskJet 882c InkJet Printer
HP LaserJet 5550DTN jams at transfer unit
Jan 06, 2009 | HP LaserJet 5500dtn Color Printer
Paper feed problem
Jan 04, 2009 | Office Equipment & Supplies
Card Stock is Not Fed from the Bypass Tray
Check the inside of the printer, ensure that there is no paper or foreign object stuck, sometimes they go undetected and they can affect normal printer feeding.
Try pulling out the paper tray and check the paper feeding mechanics underneath the printer.
Usually feeding problems are mechanic, if you cannot fix them in this simple way you will need to take printer apart and check feeding traction mechanics, this is usually a job that is better done at a repair shop.
Aug 11, 2008 | Ricoh Aficio CL2000N Laser Printer
Printing faded color text on my color paper...
That stock might be too heavy for a bizhub.
thick paper 4 (68-1/4 lb to 72 lb)*, OHP transparencies*, postcards*, letterheads,
colored paper, envelopes*, label sheets*, banner paper (24-1/4 lb to 55-1/2 lb)*
Is the paper running through the bypass tray?
Jun 09, 2008 | Office Equipment & Supplies
Automatic Paper feed
Check the feeder roller inside the printer for any foreign substance stuck to the roller, this may cause it not to grip properly. You can also try a few sheets at a time and make sure the paper tray is gripping the paper, but not too hard. If this fails, the roller may be out of place somewhat, try to reposition it. Let me know how you get on.
Sep 06, 2007 | Samsung ML 1210 Laser Printer
Can't print onto thick card
Have you tried specifying the paper type and weight INSTEAD of the tray. Set the tray properties first, then print. If you leave it on auto tray it will use the tray that matches your paper type and weight.
Jan 09, 2007 | Konica Minolta bizhub C351 All-In-One...
Ricoh Aficio CL2000N Laser Printer Logo
234 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
