Question about Lands Phones
Wires from the wall are 2(orange/white), 2(blue/white) 2(white/orange and 2(white/blue) my phone outlet which is wired has 1(black), 1(blue), 1(yellow) and 1(black. How are my wall wires to be attached to the outlet?
  • 18 Answers
Take a look at this image:
wires from the wall are - 0d5b58e.jpg Notice that the Line 1 will typically present on pins 3&4 and Line 2 on 2&5. I would think in your case Black/Blue is Line 1 (3&4) and Yellow/Black is Line 2 (2&5).
If you have a 1 line phone and only have 1 line active, then typically blue and blue/white can be connected to the Blue and Black of your Jack. If this doesn't work, switch with the Yellow and Black.
Please let me know if you have further questions. Good Luck!
Posted on Aug 11, 2008
6ya staff
SOURCE:
I have two phone lines one for phone and one for fax is there any way i can connect my fax machine to the fax line only and not have to use an adapter
You can have the single out jack replaced with a dual outlet jack. To rewire it yourself, use the Blue/Blue White wires for Line 1 and use the Orange/Orange White wires for Line 2. If you older wiring then the colors are Green/Red for Line 1 and Yellow/Black for Line 2.
Jul 08, 2014 | RCA 25201RE1 Corded Phone
Dayton 3 speed switch 34g191 has no wires or diagram. how do I hook it up.
2a5da9a5-aac3-42c6-abd8-aafc5120b40f.jpg205419c3-0ab0-44b2-af3d-75ca1d7c5061.jpg30a6a9a2-5d9a-485b-aa23-85f37da6902a.jpgDayton fan motor 6C539A Grainger switch number 34G191. Luckly I have two fans. So when the one I went to pull out fell apart before making anything I pulled the other one apart. Okay, on the white plastic there are numbers l(1), ll(2), lll(3). Orange wire l(1), nothing in ll(2), blue wire lll(3). Now on the black plastic, the outlet wires go here: black wire L, white outlet is 180degrees (by orange wire) NEUTRAL SPLICER. Now, white wire from motor goes into the other side of the NEUTRAL SPLICER next to the black wire on the black plastic. This is just above the ll(2) on the white plastic. REMEMBER - NOTHING GOES INTO THE ll(2) ON THE WHITE PLASTIC.
May 02, 2013 | Dryers
Wiring a TPH553 Surface Mounted Jack by RCA.
TPH553 T568A T568BPin 1 - BL White/Green White/Orange Pin 2 - OR Green Orange Pin 3 - BK White/Orange White/Green Pin 4 - RD Blue Blue Pin 5 - GR White/Blue White/Blue Pin 6 - YL Orange Green Pin 7 - BR White/Brown White/Brown Pin 8 - WH Brown Brown
REF: wikipedia
Feb 17, 2010 | Computers & Internet
For the Clarion DXZ945MP CD Player for car audio, I do not know the the wire harness color wire diagram? The wiring harness on my Monte Carlo 2000 reads what color wire goes to what, on the side of the...
3amp yellow battery for deck
15 amp yellow is another battery wire
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
red accessory
hope this helps
pls rate cause people arnt rating
Nov 05, 2009 | Clarion DXZ945MP CD Player
Wiring on a RCA RJ-45 wall jack
the RJ45 wallplate is not meant for ethernet. It's an 8P8C connector for a phone. Will it work as a network jack? Maybe. I wouldn't use it, but if you really want to try, wire it thusly:
1 Blue --- Orange/White
2 Orange --- Orange
3 Black --- Green/White
4 Red --- Blue
5 Green --- Blue/White
6 Yellow --- Green
7 Brown --- Brown/White
8 White --- Brown
I'd still recommend a CAT5 wallplate with a CAT5 jack.
Apr 11, 2009 | Computers & Internet
Replaceing phone wall plate
Hi Leanne!
Normally the conductors in phone cable are colored green, red, black and yellow in older style wiring. Green and red are used for a single line, and black and yellow are for a second line. Newer systems use wires that have conductors twisted together in pairs. White with a blue stripe paired with solid blue or blue with a white stripe is line 1. White with an orange stripe paired with solid orange or orange with a white stripe is line 2. (At least this is true in the US. You said "cheers" so maybe you're not in the US and the color coding's different.)
Chances are your line is using the blue and white wires.Residential telephone equipment isn't polarity sensitive so it really doesn't matter which wire you hook to L+ and L-. Try the white/blue combination first. If you don't get dialtone then try red/black. If still no luck you only have two more combinations to try.
Before you start with the wiring, take another phone on the line off the hook (if you have another one). This will prevent an incoming call from ringing the line, which can give a shock if you happen to be touching a bare end. The ringing voltage is much higher than the normal phone line voltage which won't bother you.
Apr 11, 2009 | Lands Phones
Wire a phone jack that has 2 phone line outlets
red green to blue white blue
yellow black to orange white orange
Apr 06, 2009 | Philips Lands Phones
Ethernet cable
568-B Wiring
Pair Wires RJ-45 pins
1-White/Blue White/Blue 5
Blue/White 4
2-Wht./Orange White/Orange 1
Orange White 2
3-White/Green White/Green 3
Green/White 6
4-White/Brown White/Brown 7
Brown/White 8
568-A Wiring
Blue/White 4
2-White/Green White/Green 1
Green/White 2
3-White/Orange White/Orange 3
Orange/White 6
Brown/White 8
RJ-45 Pins are with the spring tab down and read left to right. Do you have an RJ-45 Crimping tool?
Just use 568-B or 568-A on both ends of the same cable.
Jul 05, 2008 | Computers & Internet
I have a Philips wall jack model number ph69636. and i need to know how to wire it up with a cat5e cable
Pin Std Phillips
1 White/Orange BLUE
2 Orange Orange
3 White/Green Black
4 BLUE Red
5 White/Blue Green
6 Green Yellow
7 White/Brown Brown
8 Brown White
May 16, 2008 | Computers & Internet
Lands Phones Logo
381 people viewed this question
Top Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
