Question about Samsung HCM4215W 42" Rear Projection Television
Vertical lines and top third of screen is wavy
Model hlp5063wx/xaa. TV started to display "wavy" or "oil on water" apperance only on top 1/3 of screen. Now, in addition to above, tv has very thin evenly spaced white or grey vertical lines over entire screen.
effects are not constant, sometimes there, sometimes not.
  • 1 more comment
  • kickkat1 Aug 11, 2008
    will the bulb or color wheel cause this problem?
    signal feed is from DirecTV HDDVR. Situation is constant regardless of source. Same problem if watching DVD
  • kickkat1 Aug 16, 2008
    I have been told by a local service rep that the light engine may be the problem. Anyone have any experience changing one out for model HLP5063W Samsung 50" DLP?
  • 1,800 Answers
Sir this is Fixe_You i am a professional Repairman fro projection TVs ur problem is the following:
u need to change ur convergence tube its always the part of tv whitch occurs this kinda of problems.
its like an oil liquid that give the projection to that kind of monitors
to change it try this link
Posted on Aug 16, 2008
    Genius:
  • 1,665 Answers
It may be an electronic interference problem or loose antenna connection. Inspect antenna direction and wiring. Does problem exist when playing video?
Posted on Aug 11, 2008
  • Anonymous Aug 16, 2008
    How to Change your Samsung DLP Lamp in 5 Minutes
    Master:
  • 521 Answers
    Master:
  • 623 Answers
Check your picture tube...
  • Anonymous Aug 11, 2008
    try this link
    www.fixya.com/support/t460835-television_hlp5063wx_xaa_model_no - 28k
    goodluck
SOURCE:
How to fix LG TV Vertical lines.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 30, 2015 | LG 47LA6200 47" 1080p 3D Smart TV 120Hz...
RRght 1/3 of screen had vertical lines, now solid black.
that is most likely going to require a new display. what is the model, version, and serial number for the tv? I may be able to help.
Mar 11, 2014 | Samsung LN52A530 LCD TV
1 inch red and green lines in a strip across top third of tv
Id start by replacing the tcon board, its the small board generally at the top of the set. sometimes under a metal cover
Nov 27, 2017 | Vizio Televison & Video
Our Samsung Model HLP5063WX/XAA - dark images
I suspect that you may need to replace the ballast for the lamp and the power supply board.
Oct 30, 2009 | Samsung DLP HL-P5663W 56" TV
Tv keeps turning off
Lamp! Or defective Lamp Fan that cools Lamp, Call Encompass Parts or visit them on their website.
1-800-638-3328
Oct 05, 2009 | Samsung HLR6178W 61" HDTV
Shadows on screen
Try moving a medium powered magnet (not one for picking up heavy objects and not a refrigerator holding one) over the distorted area. If that doesn't work, try a more powerful one. This worked for my Toshiba LCD. Good luck!
Jan 04, 2009 | Sylvania 6626LCT 26 in. LCD Television
My tv has this lines that bend over the front top of the screen and when an object moves through the lines the image appers from the the top of where the line begins...and the tv goes black every once and...
This sounds like a vertical deflection fault. There are some components that are failing in the vertical deflection area that are starting to fail. It is very common in many of the sets that there are electrolytic capacitors in the vertical amp section that are gong out of specifications.
When you have at the top or the bottom of the screen where the vertical axis is compressed, and the picture in the compressed area looks like it is inverted and going over on itself, this is called "vertical fold-over".
An experienced TV service technician should be able to service this for you.
Jerry G.
Apr 18, 2008 | Televison & Video
Dark vertical lines on tv screen
If under warranty then of course use that.
This is a display problem. One solution someone knowledgeable in electronics can try.
This problem can be caused by a bad connection fitting of the flat cables on LCD controller board. Dis-connect the flat cables from the LCD controller(T-CON) and carefully reconnect them. Try the unit before reassembling the back cover. You may have to disconnect/reconnect several times to show improvements if this is the problem.
Sep 25, 2007 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Sylvania 6427FF TV displays wavy verticle lines at top of the screen.
I would suspect defective filter capacitors in the sweep circuits as well as the power supply source voltages.
Aug 07, 2007 | Sylvania 6427FF TV
Samsung HCM4215W 42" Rear Projection Television Logo
140 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
