Question about Garmin GPS
AFTER DOWNLOADING 2009 MAP UPDATE, WHEN I PLUG MY GARMIN INTO DC IN CAR THE GARMIN DOE NOT OPERATE THE SCREEN SHOWS THAT I AM CONNECTED TO A COMPUTER AND I CANNOT USE GARMIN OR TURN IT OFF OR ON. ALTHOUGH I THINK IT DOES CHARGE. MY GARMIN IS A NUVI 350.#107329715. I ALSO HAVE ON MY COMPUTER A GARMIN SET UP SINCE INSTALLING THE NEW MAP UPDATE I ASSUME THE UPDATE IS INSTALLED ON MY GPS. DONALD DUNCAN,duncantax@earthlink.com 951-734-5879
  • duncantax Aug 13, 2008
    SOLUTION DID NOT WORK duncantax@earthlink.net
    Master:
  • 521 Answers
All the procedure is not completed so this shows probably.try one more time uninstall the old one and install the new one with proper attention it will definately work.
Posted on Aug 13, 2008
  • 446 Answers
Reset the unit, if you cannot turn this up, go back to your PC once more go back to your previous state of procedure be sure to complete all sessions, so as not to interrupt your downloading .
removed your gps correctly pls, not just unplugging the device
cheers
Posted on Aug 11, 2008
    Genius:
  • 3,422 Answers
Please reset your garmin.
1)Raise the antenna
2)Press the reset button.
  • Garmin Master
  • 13,433 Answers
Have you tried pressing the small reset switch with a paper clip or similiar?
Garmin Nuvi 1350LMT Nuvi 1350 W map update error
Run the Garmin WebUpdater once more and apply any updates. Consider downloading and installing the lifetime map update to the computer and then use the Garmin Mapquest or Basecamp computer program to send the map data to the nuvi. Overall, it takes a little longer, but is better than trying to download directly to the GPS itself. If you're not having luck, it will probably be wise to contact Garmin Tech Support. It would be wise to mention the funky "once / month" GPS reboot issue with Garmin at this time too.
May 10, 2012 | Garmin Nuvi 1350LMT
Corupted map after update? How to correct?
Perform the update again. I think was an error on the first update.
Try the below procedure:
1. Plug one end of the USB cable into your GPS and the other end into your desktop or laptop computer. The GPS device will load the appropriate driver automatically, and a message on your GPS tells you that it is connected to your computer via USB.
2. Open your Internet browser of choice and type in the following web addres: "http://www8.garmin.com/support/collection.jsp?product=999-99999-27 "
3. Download the appropriate version of the software for your computer (Windows or Apple) and Install the WebUpdater by following the wizard (accept defaults).
4. Click "Start," "Programs," "Garmin" and " WebUpdater" to update your firmware and your maps. Periodically check and make sure your software is current.
Jan 06, 2012 | Garmin Nuvi 760 Car GPS Receiver
No problem. just trying to download updates. 1 year
Garmin periodically releases updated maps for its GPSdevices. The my Garmin website offers convenient access for managing yourGarmin devices and finding the map updates you need. Garmin offers threeoptions for map updates: free download, single-purchase download or lifetimesubscription. Regardless of which option you choose, the process to downloadmap updates to your Garmin is the same.TOOLSAND INTRUCTION NEEDED TO SOLVE THE PROBLEM1 Connect your Garmin GPS to your computer. Locate theUSB ports on your computer and on your GPS. The GPS ports are typically on theback of the device and may be hidden by a protective cover or rubber cap. Plugone end of the USB cable into your computer and plug the other end of the USBcable into your GPS. Power on the GPS.2 Sign in to my Garmin(see Resources) with your username and password. If you do not have an account,click the Create New Account link to register your Garmin devices.3 Click the my Maps tab to display a list of yourregistered devices and their associated maps. Click the Map Downloads link todisplay a list of available map updates for your devices. Select PC Download orMac Download link.4 If you are alerted to run the Garmin CommunicatorPlug in, click Run. When the Plug in has detected your GPS and is ready todownload the map update, click the Launch Download Manager button.5 At the Save As prompt to save the map update, notethe location or select a new location to save the file. Click the Save button.6 When the Map Update file has finished downloading,click the Launch button.7 At the "Welcome to the Garmin Map Update"screen, click Next.8 After the Map Update USB Driver Check finishes, clickNext.9 Follow any instructions on the Map Update SuccessfulInstallation screen. Click Next.10 At the Software Data and License Agreement screen,select the checkbox to accept the agreement. Click Next.11 After the update installation finishes, click Finishto exit the program.12 Disconnect your GPS from your computer.Thanks.
Sep 18, 2011 | Garmin nuvi 255W GPS Receiver
I bought a refurbished Garmin 660 and the screen comes up to needing a map update and won't go any further. I am charging but have no idea how long that will take. Tried to downlaod a map update using a...
The unit should still operate even though the map is old. If you press the OK button and nothing happens, most likely the touchscreen is bad and needs to be replaced. An old map should not stop you from using the device.
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Apr 22, 2011 | Garmin Nuvi 660 GPS Receiver
I received a Garmin Nuvi 255w as a gift back in October 2009. I am a Realtor and use this almost every day. Yesterday I was driving around, and I did have the Garmin charging with the car charger. In the...
The unit should still operate and turn on even with a dead battery when connected to an external power source such as the DC car charger, AC wall charger or USB cable (connected to a PC).
Please try the reset procedure listed here:
http://www.sharc.net/discus/messages/6/313.html?1269314749
- Jim
Mar 26, 2010 | Garmin nuvi 255W GPS Receiver
Computer can't locate connected nuvi 270
Are you using the latest Garmin program called WEBUPDATER Version 2.9.1.0 that was released about December 2009??
Try again:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To download the latest unit software visit Garmin website: www.garmin.com/webupdater
After installing WebUpdater once from the Garmin website, perform all future software updates from your computer. Simply connect your compatible Garmin device to your computer, then run WebUpdater from your computer's "Start Menu" by selecting "Start", "Programs", "Garmin", and finally "WebUpdater"
REMEMBER: It takes hours to do a complete a map update.
Unless you bought the Lifetime maps you may have to pay for current maps.
Does this help? Let us know. Thanks.
Aug 22, 2009 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 5000 wont turn on. I can plug up the usb up to the computer and the screen shows garmin logo with a gps connected to a computer like its charging. But when i press the power button weather it...
Your nuvi 5000 does NOT have a internal battery and that means that you cannot operate it unless it is connected to a 12 volt power source. Connecting it to your computer via USB allows you to install map updates, check for firmware updates, etc, but you will not be able to use it as a gps while it is connected to the computer. There is nothing wrong with your gps.
To use your gps in the home you need to purchase a 12 volt adapter, there are several types, plug the adapter into your wall outlet and connect your gps to it. If you can sit near a window it will help in picking up the satellite signal. Just keep in mind that you cannot connect the 12 volt power supply and use the usb cable at the same time. Enjoy your gps.
Jun 11, 2009 | Garmin nuvi® 5000 Car GPS Receiver
Maps don't show after downloading upgrade.
sounds like you might not have the new map set selected
settings -> map -> map info (make sure the NT 2009 map is checked)
Mar 17, 2009 | Garmin nuvi 350 GPS Receiver
2009 map update not loading
Fixed. Called Garmin. It seems that version 4.90 FW on the Nuvi 350 (which came shipped on my 350) has a bug where it cannot communicate with the Garmin software either to update maps or update FW. Tech from Garmin e-mailed me a patch that I copied into the Garmin folder on the Nuvi itself, via USB and Windows Explorer. I then rebooted it; the patch installed itself which then allowed the unit to communicate with the map upgrade software and all is well. 2009 map update is now installed and the Nuvi is working fine again. Haven't tried upgrading to newer FW yet; will probably leave well enough alone.
Jul 01, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin 660 wont operate on power lead
Are you using the Garmin AC adapter or the Garmin car adapter? Using the wrong cable and the Garmin will think that you are trying to connect to a computer. Not all USB cable are alike.
When connected to your computer it thinks that you want to upload or donwload information.
Jan 26, 2008 | Garmin Nuvi 660 GPS Receiver
GPS Logo
223 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
