Question about Whirlpool Microwave Ovens
Concerning Microwave oven Model MH2175XS I am following the installtion instruction phamplet to change the vent fan from inside circulation to outside by removing the two blower screws on the back and lifting up the fan; rotating to upper flue exhaust position and I cannot lift the blower assembly out...it does move slightly but stays put.
  • Whirlpool Master
  • 9,098 Answers
Looking at the pamphlet, it sounds like you're doing everything right.
It sounds like something is a little bent or out of alignment making it stick.
Maybe you can take the tip of the screwdriver, and push against the motor assembly a bit to loosen it?
concerning Microwave oven Model MH2175XS
Posted on Aug 12, 2008
Vent fan filter??cleaning,etc does not seem to pull air out as it runs
If this is a new installation, or if this ove is new to you, the following may apply: on some ovens the vent fan can be flipped to either exhaust air out of the house, or re-circulate it. Could it be in the wrong position? You would have to take the oven down to determine this.
May 25, 2014 | GE JVM1653 Microwave Oven
Microwave vent won't work
may be short circuit at high voltage section replace diode or magnetron
Jan 26, 2014 | Whirlpool MH2175XS Microwave Oven
My microwavedoesn't heat is there a fuse that may be blown
No! the fuse is fine, there are three likely causes, magnetron, "heats food" cracked high voltave diode, or a shorted high voltage capacitor.
Mar 24, 2012 | Whirlpool MH2175XS Microwave Oven
Fan stopped working. I am looking for the fuse.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 10, 2010 | Whirlpool MH2175XS Microwave Oven
We have a sharp 1480 and have to mount it with no outside vent. Can this be done? patqlt@verizon.net
Most of these over the range models come already set up for unvented operation. That is, set up for use with no outside vent. The oven will filter air through the a charcoal filter inside the upper grill and the vent covers underneath. If you ever wish to change the operation to allow the unit to vent outdoors, you need to change the direction of the blower fan assemby inside the top of the microwave oven. These instructions should be listed in the installation manual that comes with your oven.
Aug 16, 2010 | Sharp R-1480 Microwave Oven
Need vent grille for Whirlpool MH2175XS
Go to www.partselect.com and type in the model # you will find it there.
Mar 10, 2010 | Microwave Ovens
Can this microwave be vented to the outside?
Yes, this microwave will vent either out through the top or the back. A damper will be needed if it was not saved when the unit was installed. A list of other items are listed in the installation instructions at this link To GE.
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40409-1.PDF
Nov 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1640 micro wave oven
You can check and / or correct your installation with help from the installation instructions.
You can download GE owner's manuals and installation instructions here.
Feb 04, 2009 | GE JVM1640 Microwave Oven
Fan
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Feb 28, 2008 | Whirlpool MH2175XS Microwave Oven
My microwave is sweating
No. This is usually a sign of poor venting or air flow. It's possible that the coling fan is not circulating the air properly due to a problem with it or maybe the air vents are blocked. Also, there needs to be a couple of inches around a countertop model on all sides - especially the back - to ensure air flow. Look for buildup on the back vent grille. You can listen for the fan to be running and feel the air flow while it's running. If it's weak or not there, it needs inspection / service. A lack of air flow can cause the magnetron to overheat and be damaged. If this is a built-in model also check your air filter, air duct work and outdoor vent flap. Write back if you still have trouble.
Mar 12, 2007 | Kenmore 64282 Convection/Microwave Oven
Microwave Ovens Logo
91 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
