Fuse FL231 I think I found the fuse and it's sodered in. I just can't find a place to buy one or does it go by a differant part number?
  • 8,617 Answers
Its a 400ma 125V fuse. I am not sure of the part number as most places list it as Fuse FL231 for an RCA. But its a small brown rectangle. There will be three identical all in a row and its the center one.
Posted on Aug 11, 2008
Hi I have a convergence issue. Is there a place in NYC where I can purchase these replacement items: (1) FL231 micro fuse (1) DL231 Diode (1) CL230 radial Capacitor I repaired the initial...
This DLP model RCA tv have convergence menu disappearing is very easy to fix just replaced the convergence fuse FL 231 near the FBT also must be resoldering FBT too.U can buy this FL231 covergence fuse at Ebay.com.No,but u must have to have a soldering iron,a desoring pump or desoldering braids and know how to basic soldering?To replaced this FL231 convergence fuse near the FBT and also must resodering the FBT too for protecting the new FL231 convergence fuse.
Mar 02, 2011 | RCA R52WM24 52" HDTV Projection Television
Tv just looks like i folded picture need help on configurance set
The tv have a problems known as a convergence problems,it dead.U have tools,soldering iron,solders.U know how to do solders?Try Ebay.com to buy a convergence Fuse(FL231).The big block of plastic call the FBT.Resolder the FBT.The 3 three fuses caps on (FL231) beside it.The covergence fuse cap in middle is dead,replaced the covergence fuse cap in the middle will solved ur convergence problems.
Jul 17, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My question is.My dodge`s dashboard sometimes doesnt work and bort computer.So is it a problem with fuses or something else? thank you
This is a common problem with the voyager,caravans and Town & Countrys. What the problem is is a cold soder in the interment cluster itself. The problem area is where the plug comes from the van into the cluster. You need to take the circuit board out of the cluster and reheat the soder on the back side of the circuit board were the plug plugs into. This will fix the cold soder permanitly I think its about 16 pins you have to reheat with the soder gun. If you don't feel comfrotable doing that you can just replace the interment cluster and it will be fine but if you buy a used one make sure it was tested. Good luck
Mar 20, 2010 | 1999 Dodge Caravan
RCA R56WH78 picture quality is blurry/3D
rubber cap? i dont feel you have the correct fuse. fl231 is a small rectangular brown fuse next to flyback. I have written detail instructions on the replacement of this fuse. look under willtab profile under tips in tricks section. intitles the fl231 fuse problem. this also help you indetify if this is the problem.
Nov 22, 2008 | Televison & Video
RCA R52WH74 (ITC222A Chassis)
no the board that has the FL231 on is the ITC222 deflection board. The other board is above the chassis in a seperate frame that runs across the set the convergence power supply is the board on the left above the board where the fL231 is. Yes the ITC222 and ITC222A are the same chassis. As for the service manual that site should have the service manual under the thomson category as the ITC 222 chassis is actually a thomson chassis made for RCA.
Sep 11, 2008 | RCA R52WH73 Projection Television
Fl231 fuse compatibility
yes, thats the replacement fuse for your set. However unless you have replaced the convergence power supply also chances are the fuse will blow again, as the power supply shorting is what causes the convergence to get out of alignment and it will then blow FL231 thereby removing the convergence option from the menu.
Sep 02, 2008 | RCA HD52W59 HDTV Projection Television
Fuse fl231
You could possibly get a fuse at a car parts place or Radio Shack, however if you don't want to make a trip to the store I have done this several times with no problems....Take an AC cord and strip the cover back to get to the strands inside and cut out one strand of the copper wires and either wrap it around the old fuse or solder it across the fuse on the foil side. It is equal to about 5 amps. If the wire blows there is a short in the circuit and would require more assistance from me or another expert.....Dennis
Jun 16, 2008 | RCA P52937 52" Rear Projection Television
Adjust projection tv does not appear in the sceen menu
Its right next to the Flyback which is a large transformer about the size of a fist with a large red wire coming out of it. The fuses are located near that they are 3 fuses fuse FL231 is the center fuse.
May 19, 2008 | RCA P52926 52" Rear Projection Television
RCA R52WM24 52 in. HDTV convergence IC location
the rca itc222 chasis uses no stk the convergence is controled with transistors... the convergence amp board is located above the main signal board(green board)... it can be identified as the one with several heat sink fins on it. FL231 is related to convergence.. there has been a problem with this fuse when it blows the processor doesnt know it is a projection set so it turns it into a regular tube tv. Here at the shop we have found number one reason this fuse blows is poor solder connection on the flyback. So replace the fuse and reflow the solder connection on the flyback and around that area also the horizontal transistor and then see if that doesnt fix the problem.. if you have an more trouble ..... willie@fordtv.com
Feb 29, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA 52w59 projection fuse fl231
Instead of taking the board out, I just soldered two wires to the old fl231 fuse on the underside. Installed a fuse holder with a half amp fuse. And I re-soldered all of the flyback points. My tv is working like new. thanks for everyone's help.
Dec 28, 2007 | RCA HD52W59 HDTV Projection Television
Televison & Video Logo
180 people viewed this question
Top Televison & Video Experts
Electro Med Services...
