Question about HP LaserJet 8000n Printer
HP LASERJET 8000N
Hi . on every paper printed there is a black line on top of the paper like about 1 inch wide its not very dark i can see it thru but for example when ill fax it they wont be able to read it, the line is going in the direction the paper is moving in the printer. how do i know if the problem is the fuser/drum or what else can it be?
  • 34 Answers
The 8000n is not a color printer, not an ink jet machine. YOur problem can be only one of two things: bad toner cartridge or bad fuser.
Start by removing the cartridge from the printer. Pull back the drum door on the cartridge. Do you see dirt on that glass drum which corresponds with your print defect? If so it IS the cartridge.
If NOT, then it IS the fusing assembly, easily replaceable, no tools necessary. HP printers our only business.
Posted on Mar 17, 2009
  • 446 Answers
There could be a problem in one of your drum, (4 pCS) to isolate w/c is w/c pls do this:
-print one of each color, M,C,Y,K(black)
- once you have identified that one of each is giving you problem pls replace the affected drum
- IF you printed all colors and still having the same line the problem is in the fuser section most likely the fuser roller or the pressure roller is either dirty or damaged.
-if it is dirty clean with alcohol while it is hot, gently rub (be careful it is hot) or cloth damped with oil will removed sticky toner adhered on its surface
cheers, dont forget to mark this pls
Posted on Aug 11, 2008
Hp 8000n is ghosting excess toner on prints. Why?
Perhaps, but first clean up the exposed parts of the printer where the toner may travel before it makes contact with the paper. Also, the fuser may need to be cleaned or replaced. Post your problem directly with HP on the HP website.
Feb 16, 2013 | HP LaserJet 8000n Printer
Black line on left side of paper
I forget the terminology but I believe there's either dirt or a sheet of paper on an internal roller.
You might try here for HP help.
Aug 12, 2012 | HP LaserJet 1300 Printer
My HP laserjet 3015 puts thick dark line down the copy
Put paper in the manual feed tray(tray 1). Print something. When the paper gets about 1/2 way into the printer, open the top cover. Pull out the toner. Look down at the paper in the printer. Do you see a thick dark line? Replace the toner. No thick dark line, check the fuser for damage.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
When you print each page has a gray/black line running down the page from top to bottom about 2.5 inches from the edge of the paper. Sometimes it is darker and other times it is lighter. We have tried...
While the line is showing up on the output pages.
Stop printing and put paper in the manual feed tray (tray 1).
Start printing again. As a page gets pulled into the printer about 1/2 way open the top cover.
Pull out the toner and look at the page inside the printer. If it doesn't have the grey/black line, get the fuser replaced. It is defective.
Jun 09, 2011 | HP LaserJet 1300 Printer
Have vertical cyan lines 1 inch wide on same side
Don't know about your "primed" toner, but go to Diagnostics and run the PQ test. See what that looks likes. Go to Disable Cartridge Check and swap the black and cyan toner. Run another PQ test. Are the lines still there and are they black or cyan? If they are cyan, the cartridge is bad. If they are black it's not the cartridge. It going to take a tech to look at it.
Feb 02, 2010 | HP LaserJet 4650 Color Printer
Dark band the length of the right side of the printed page
Hello sir; I suggest you go to replace a new cartridge, see what's happen.
Apr 07, 2009 | HP LaserJet 1020 Printer
How can I make my laserjet prints look as dark as my designjet pr
It si not possible because the %darkness of the black ink and the black toner. The first is near 93% black and the toner even at ***** eye looks dark gray less than 90% black.
Jan 12, 2009 | HP DesignJet 4000 InkJet Printer
Hp laserjet 4250
try this
1.when the printer start print turn off the printer after the paper go on side the printer to make paper jam
2.open the printer and pickup the paper out slowly
3.see the print area on the paper if the black par appears on the paper that mean the drum unit faulty if not the fusser unit faulty
May 14, 2008 | HP LaserJet 4250n Printer
Print is missing along a one inch width patch for the entire lengh of mdocument
try a new toner cartridge
if it doesn't fix your problem then you willneed a new fuser
it is probably delaminated
Dec 22, 2007 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 8000n Printer Logo
112 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
