Backlight fails after 2 mins on Sony Viao laptop. Is there a common fault? where can i source spares?
On dissasembly of the unit, having removed the mains lead from the unit and dropping out the battery, there are very few parts, just the backlight tubes which run around the periphery of the screen and a narrow Pcb at the base of the screen which is the invertor (takes a low input voltage and provides 600volts+ to drive the tube.) I obtained a replacement Invertor which resolved the fault ( cost of repair £50 and 15 minutes work.)
Take great care to ensure both the battery and the mains lead are removed pior to opening the unit as voltages around these components are in the order of 600volts when in a powered state..
Posted on Aug 13, 2008
I have a sony viao all in one desktop model num pcg-252l i replaced the screen and i trun it on and it lights up but it stays all white
A white screen meant the LCD controller was not working - what you saw was the backlight without polarization in front of it. If the cpu fan isn't spinning, that means the system board doesn't detect the right startup conditions. You probably connected the inverter improperly and it may be preventing booting, or you may have damaged a component with static.
Mar 29, 2016 | Sony Computers & Internet
Aspire 5100 laptop every thing looking like working but no display The ram card testing another laptop found good
If you plug the laptops VGA output into an external screen, that will let you know if you have a screen fault or motherboard fault.
If it is screen then look closely at the screen with a light source to see if the screen is working and it has no backlight.
That will tell you the problem and allow you to search for spares on ebay or Acer's web site.
Hope that helps.
Dec 31, 2010 | Acer Aspire One Netbook 8.9" Notebook
My laptop ( sony viao laptop) fell and now once turned on I have a black screen all lights and sounds are good. Could this be a led disconnect problem or a video card situation. What type of video card...
Unlikely to be a vga cable loose, but you can check by removing the switch panel cover and the screen to check it is still firmly housed.
test the laptop first in an external monitor, if you get an image, then the graphics chip is still ok
This then points to the screen, may appear undamaged, closer inspection with a torch, shone through the back of it will show any cracks you do not see straight away.
If the screen will not light up, fault is probably with a damaged backlight or inverter, you are then looking at a new (or 2nd hand) screen
Dec 30, 2010 | Sony VAIO PCG-K35 Notebook
The LCD screen is black.
lcd inverter or backlight went out,,,sounds like,,check sony website for driver downloads and support ,,
Nov 03, 2010 | Sony Computers & Internet
Sony VIAO VGN-N365E. Will not boot up. I have the green indicator lights...and can hear the CD check fire up....and the Fan does come on. But, no image on the screen. Nothing. I have removed the...
Please follow the diagnosis outlined in this article to check whether the backlight lamp or the inverter board are the root cause of the problem or not:
If you connect the external monitor & nothing is displayed on it, then this means that both the backlight lamp & the inverter board are fine. The main indicators in these cases are the sound, and the hard drive LED on the laptop case. If the laptop sounds just like it always does for a minute or two after being turned on, it means it's going ahead and booting the operating system, but the video processor or part of the motherboard circuit for video output has failed. If the laptop just sits there and beeps when you turn it on, or if you hear the fan but not the hard drive chuckling with its active LED flashing away, it means the laptop isn't getting as far as trying to boot the operating system. While this could be due to any number of hardware problems, the most common and easiest to
troubleshoot or repair is RAM failure. If your laptop has two RAM modules installed, try booting with just one and then the other in the primary slot. If your laptop only has one RAM module, you might consider buying one online from a site with a good memory selector, like
Oct 25, 2010 | Sony VAIO VGN-N365E/B Notebook
We have a Sony Viao All in One VGC-JS110J. The monitor keeps going black. The system is still running, and the monitor will come back on after we turn it off for a while. Tthe outage keeps happening. We...
It sounds like the backlight is failing. You may be able to prove this by shining a light across the panel and looking very closely to see if the display is actually still there, just not being lit. If this is the case it can be the backlight or the inverter. You may be able to hook up an external monitor to it and prove that it is a problem with the lcd display and not the graphics adapter but your description is common for a failing LCD/inverter.
Please rate this solution if it has helped you.
Thanks, Gary
Jul 12, 2010 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
I have a Sony Viao NS10E, all working fine and then the screen went dark, took screen out and put in an other laptop and it worked fine, put the screen from the other laptop in mine and still dark. The...
You definitely have a Video Card Error related.
  1. Find Where Your Graphic Card located (asuming your computer has a separate card for video .
  2. Check the connection from your display to your video card (these connections are very thin wires running all the way to the video card or the MB).
  3. If the second step is clarified then have your graphic card checked. or have *********** Board chip set checked for bios and fermware.
Mostly you have a connection problem.
Nov 27, 2009 | Sony VAIO PCV-W20 PC Desktop
Sony viao pcv 6603
check whether your RAM is OK. If the ram is gone then this kind of error could happen
Jul 13, 2009 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
Dead Sony Laptop
If power supply is supplying correct voltage, then you do not need power supply PCB.
Try starting the laptop with AC adapter and no battery, if battery is shorting out you may get same problem.
Test the soldering joint on the AC socket and laptop motherboard, if there is a bad soldering on laprop ac adapter socket, you get same symptoms.
If it is none of the above, and the adapter is fine, then it is usually a faulty motherboard.
Nov 16, 2008 | Sony VAIO PCG-V505CP Notebook
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
