Question about Toshiba Satellite M35X-S349 Notebook
Toshiba M35X-S349 (Freezes Periodically)
Here's what I know:
Hard Drive is good
Memory is good
Laptop freezes up periodically. When this happens the screen stays on but you cannot move the mouse or push ctrl, alt, delete.
Here's an interresting thing though. I can duplicate the problem by pulling the hard drive out.
When it is running, it runs really well. Sometimes it's after 2 min, 12 min, or even 2 hours. Very periodic.
Any Ideas? I'm pretty computer savy: A+, MCSE, but this has me stumpted.
  • Anonymous Aug 30, 2008
    Having the same problem, one time got a HD failure error. I have checked memory and HD both good. I reformatted HD and it freezes while trying to reload OS (XP-SP1).
Update: I looked at the plug connecting the HD to the PC and pulled it about 1/2 way back off and reinserted into machine. I then pulled the HD back out and noticed that it was not all the way pushed back on and it wasnt parallel to the HD. Basically I am thinking that the HD is not sitting properly in the bay for some reason or another, but I have been running 10+ hours with no problems as of yet. I did reformat the HD so I am going down that road of reloading and letting run awhile, reboot, repeat. Not sure if solution, but looking real good at this point.
Posted on Sep 01, 2008
SOURCE:
Grey screen freezes computer
Most of the time, PC freezes by lots of reasons. Corrupt registry, unnecessary applications, too many start-up items as well as virus infection would be the major reasons contributing to this problem. Many PC users simply utilize PC yet never consider how to maintain and optimize PC performance. I would suggest you to download reliable program RegInOut to avoid your PC from freezing.
Nov 18, 2013 | Toshiba Satellite P205D-S7436 Laptop DC...
RAM upgrade
(1) flip the Notebook/Laptop PC over - see Fig.1 below
(2) find the memory cover - it really easy to find in this photo.
Fig.1 Toshiba M35X bottom view - the memory cover is seen at center left and secured by a single screw.
(3) remove the (1) screw securing the memory cover.
Fig. 2 Toshiba M35X laptop shown with memory cover removed and HDD (Hard Disk Drive) removed, and with the HDD cover flipped up.
The RAM (SO-DIMM boards) are visible at center left.
The HDD cover is seen at the bottom of the photo.
(4) Using proper anti-static/static control techniques, clip alligator clip or your anti-static wrist strap to a frame ground of the laptop at an I/O connector or frame ground under the HDD cover.
(5) carefully remove (2) old 256 MB SO-DIMM DDR333 memory modules.
Store old memory boards in the anti-static plastic baggie in which the new memory boards were shipped.
(6) install (2) new 1GB SO-DIMM DDR333 boards, for total of 2GB of system RAM.
(7) reassemble system, and boot OS (operating system).
The laptop's ROM BIOS will auto-detect the new RAM and begin a standard POST (Power-On Self Test).
(8) If OS is MSWindows, it will also auto-detect the new memory, and allocate it to application software.
The technology of the Toshiba Satellite M35X-S349 memory module is called
DDR333, meaning DDR (Double Data Rate) SDRAM (Synchronous Dynamic RAM), at a memory bus speed of 333 MHz.
The Form Factor of the DDR memory card is SO-DIMM, which stands for Small Outline DIMM (Dual In-line Memory Module) (see photo).
Reference: http://en.wikipedia.org/wiki/DDR_SDRAM
Reference: http://en.wikipedia.org/wiki/SO-DIMM
Fig.3 Each 1GB SO-DIMM DDR333 memory module will look like this one.
The Toshiba Satellite M35X-S349 supports a maximum of two SO-DIMM memory modules.
Each memory module can hold (a) 256MB, (b) 512MB, or (c) 1GB,
in the SO-DIMM Form Factor compatible with the Toshiba M35X-S349 Notebook PC.
Dec 03, 2011 | Toshiba Satellite M35X-S349 Notebook
My toshiba laptop does not turn on
Try removing the battery for about ten minutes. Try that and if no go hit me back and we will go from there.
If my answered help give me four thumbs as thanks!!
Aug 28, 2011 | Toshiba Satellite M35X-S349 Notebook
Turn on screen is black windows will not come up
If screen is totally off (black because of it's off) - screen is dead. If it's black, but you see it's working - could be hard drive or memory fail.
Mar 14, 2011 | Toshiba Satellite M35X-S349 Notebook
Satellite M35X-S349 PC Notebook: How do I speed up my toshiba pg 35 laptop...
RegTOOL can helps you scan your PC, safely clean the errors & invalid entries cause system slow, freezing and crashing, and repair registry problems to speedup your computer performances. It is easy to use.
http://www.keep-pc-clean.com/
May 18, 2010 | Toshiba Satellite M35X-S349 Notebook
Computer crashes when turn on Wireless switch
problem:sounds like polarity is switched on wireless card
Solution: remove cover plate on bottom and make sure black wire runs to Main and white wire runs to AUX
Aug 02, 2009 | Toshiba Satellite M35X-S349 Notebook
Satellite laptop turn off
Hello maurice. Looks like you have an over-heating problem. The CPU has more chance of overheating when you use graphic intensive applications like Games etc., Clogged heatsink is one of the reasons for over heating. It would require you to get to the heatsink and clean any dust or any other stuff that may have got clogged in the heatsink. Another Idea will be to buy some kind of laptop cooler like the one below.
http://www.circuitcity.com/ccd/productDetail.do?oid=89840&om_keycode=3
Sep 28, 2008 | Toshiba Satellite M35X-S349 Notebook
Won't boot up.
anilkpa, I don't know if your tech ran a diagnostic or was able to.
It doesn't hurt to take it somewhere else for a 2nd opinion. If the mobo is dead I'd do what the tech advised.
Question by FJDM,
"SO WHAT DO YOU DO THROW IT OUT?"
Definately not. Did you buy this new ? As is ? What does your warranty state ? Usually a store will offer a limited warranty and extra avail thru the manufacturer or if you pay more, right thru the store. 15 days seems a little short in any case and you reported the problem to them BEFORE that period.
It sounds like what you're dealing with is a customer service issue, bypass that technician and ask for the Customer Service Manager.
Jul 09, 2008 | Toshiba Satellite M35X-S349 Notebook
Open Questions:
See all Toshiba Satellite M35X-S349 Notebook Questions
Toshiba Satellite M35X-S349 Notebook Logo
142 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
