Question about Sewing Machines
Baby Lock Serger Thread keeps breaking
I can not seem to get the thread to stop breaking or serging - th ethreads just feed straight through the machine. I have double checked the thread passes but still nothing. Baby Lock BL4-736. I have a Baby Lock serger model EA-605. When trying to sew a straight (double chain) stitch, the thread keeps coming out of the top needle. (the looper stays threaded. I have double checked the threading and tension. I can't seem to find the problem. Any help would be appreciated.
  • 4 more comments
  • Jo Gay Aug 29, 2008
    I have the same problem. My EA605 makes the serged edge but will not sew the seam. I have rethreaded and turned the needle around thinking that it might be in backwards. I have no idea what is causing this.
  • dandmb Mar 09, 2009
    I need a manual for the baby lock BL4-736. My serger won't sew at all.
  • Anonymous Mar 10, 2009
    Can I also get a copy of the EA-605 Manual in english please?
  • glisten Mar 20, 2009
    I was wondering if you could send the instruction booklet for the EA-605 to my email address?? [email protected]
    Thankyou,
  • bobi55 Mar 22, 2009
    Do you have an electronic copy of the manual that you could send me? My mother inherited this serger from my aunt and we don't have the manual.
  • gjeanlou_fr May 09, 2009
    Hello, could you send me the booklet for this machine Baby lock EA-605 in french or english. thank you. [email protected]
Mmmm...., maybe NOT the solution, maybe, just a key.
I have a copy of theBaby LKock EA-605 instruction booklet in English, Germann, French and Spanish. NO ideas how it casme into my orbit, but happy to pass it on.
Posted on Mar 06, 2009
    New Friend:
I could not get my Babylock BL4-736 to make a chain. The most important suggestion I can give anyone with this problem is to make sure you have the DCx1F needles (not 1SP needles) installed correctly. The next suggestion is to make sure when you thread the loopers to have them in the highest position possible. No where in a manual will you find the next bit of important information: WHEN YOU THREAD YOUR UPPER LOOPER MAKE SURE YOUR THREAD FROM THE LAST STAY TO THE UPPER LOOPER IS BEHIND THE LOWER LOOPER. This worked for me and I know it will work for you.
Posted on Apr 25, 2012
  • Mucevher Mullinax
    Mucevher Mullinax Feb 25, 2015
    Iam going to trying this tomarrow thank you very much . I hope works for me to.
  • Anna Clyne
    Anna Clyne Jan 25, 2019
    This was a long time ago... but did you have success? I am having exactly the same problem, and can't solve it.
Need manual for ea650 juki babylock also thread keeps coming out of the needle any tips? [email protected]
Posted on Jul 03, 2010
Can you please send me the manual too!!! [email protected], thank you soooo much :-)
Posted on May 31, 2009
SOURCE:
SERGER HAS BEEN RETHREADED AND HAS A NEW NEEDLE BUT WILL ONLY SERGE FOR ABOUT 1.5 " and THE THREAD BREAKS AND LOWER LOOPER COMES UNTHREADED.
Serger thread breaks
1. Is the serger threaded correctly?
2. Is the needles inserted correctly?
3. Is one of the needles bent or damaged?
4. Is the tension adjusted too tightly?
5. Is the tension adjusted to accommodate thickness of thread being used?
6. Are you using inferior quality thread?
7. Is the thread feeding off the cone/spool freely?
8. Is the needle size correct for the type of fabric being used?
9. Are the needles being used the correct one for the serger?
10. If all of the above suggestions don't help then the serger needs to be checked for a timing problem at a sewing machine repair shop.
Aug 21, 2013 | Singer 14SH654
Kenmore serger thread keeps breaking
7. Is the thread feeding of the cone/spool freely?
Mar 26, 2013 | Sewing Machines
Thread tension on a Baby Lock BL90
I suggest changing both needles
and rethreading the machine
use a can of air that is used for computer keyboards on the inside
here's a link for parts to the machine and also has a manual
the manual should have information about the thread tension
http://www.sewingpartsonline.com/babylock-BL90-serger-machine-parts.aspx
Oct 29, 2012 | Baby Lock Sewing Machines
Sewing serge it wont sew after i thread it it just keeps breaking the bottom thread I dont have the manual i lost it
change the needle--flat side to the back of the machine
check to see if
1. bobbin is inserted correctly
2. are there any burrs on the needle plate or bobbin area
3. change thread--use every thread guide
name of machine & model number is not shown
if this is a baby lock machine then go to the website & contact customer service about a manual
Mar 28, 2012 | Baby Lock Sewing Machines
I don't have a manual for my Baby lock Pro line model # BL4-738 NS. It was given to me and I have threaded it accordingly to the diagram on the machine but it won't pick up the stitch.
You will have to order the manual from a Baby Lock dealer.
This model may have to be threaded in a certain order.
Try raising the presser foot and setting the tensions to zero.
Turn the handwheel so the upper looper (the curved one) is at it's highest position - there may be a mark on the side of the serger where you align the handwheel for this.
Thread the upper looper and then the lower looper and then the needles.
Pull the threads under the presser foot and toward the side of the serger.
Set the tensions back to 4 - 6, lower the presser foot.
Hold onto the thread tails and gently press the power pedal to begin a thread chain before serging fabric.
Feb 16, 2010 | Baby Lock Eclipse Serger
BabyLock Proline upper looper thread keeps breaking
I ended up switching the spools of thread around. Apparently, even though I had purchased good quality threads, one of the spools was wound in a way that made the thread loop and twist around. So I put the offending spool of thread through one of the needles and put the needle thread on the upper looper. That seems to be working. By the way, BabyLoc was very unhelpful dealing with this problem.  Thank you!
Aug 26, 2008 | Baby Lock Eclipse Serger
Babylock Eclipse SX won't catch the overlock stitch
  • the factory default settings are 4,4,4,4 and M
  • Change the needles
  • use a can of air spray ( compressed air can sold in computer stores) to ensure there is no fabric or dust under the needle plate
Jun 28, 2008 | Baby Lock Eclipse Serger
Left thread needle
change the knife blades
Mar 12, 2008 | Baby Lock Eclipse Serger
Threading elna lock pro 4 DE green knob
My lower looper thread keep breaking, what is the problem.
Feb 17, 2008 | Baby Lock Eclipse Serger
Baby Lock Protege BL5370Ed Serger
I was in a similar position (but had the manual). The manual isn't as complete as I'd like. Anyway, what finally got mine working were the following:
1. turn all tensions to zero before putting thread through them
2. thread the upper looper, then lower looper, then needles.
3. when threading the lower looper (mine kept pulling out), after passing the thread through the looper eye, it needs to go pretty much straight up, not wrapping around anything else - other thread, for example. Mine was at one point trying to wrap itself around a post.
4.when everything is all threaded up, make sure all threads are under the foot *and* pulled to the left (even though the manual says pull to the back). Then chain off without fabric, turning the handwheel by hand to make sure loops are forming. If so, adjust tensions to where you think they should be (mine are currently all between 2 and 5), and add fabric. Then tweak as needed.
For me, this was a lot of trial & error, hair-pulling, and getting tips 1, 2, and 4. I figured out #3 on my own, with much swearing along the way. Good luck!
LF
Sep 24, 2007 | Baby Lock Eclipse Serger
Sewing Machines Logo
1,363 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
