Question about Hoover Self-Propelled WindTunnel Bagless Upright VacuumVacuum
Self-propelled Broken? Vacuum very hard to push. Self -propelled doesn't seem too be working. What can I do?
  • Anonymous Nov 29, 2008
    same problem... self -propel is broken
I have the same problem, found out there is a cable that is broken, I'm trying to figure out how to fix it.
Posted on Sep 08, 2008
I have the Hoover, self propelled vacuum. I have only used the self propel function a few times, but our babysitter used the feature and now the vacuum only works on the highest carpet setting. The middle...
Move the carpet height control switch to a higher position if the vacuum is difficult to push. If the setting is too low for the carpet being cleaned, the brushes press against the floor preventing the vacuum from moving easily.Set to a medium-high height setting then check.Slide the "Self-Propel" button to the "ON" position if the cleaner does not self-propel. -----------
The self-propel feature operates only when the cleaner switch and the self propel button are both ON. ---------- Try this settings and check.This should help.Thanks.Helpmech.
Jun 24, 2011 | Hoover Self-Propelled WindTunnel Bagless...
The vacuum is not rolling easily. It "drags" on the rug.
Hi There,
When a Hoover Windtunnel becomes hard to push, this usually indicates that self-propelled has stopped working.
When this stops working, it can be caused by several things. The first, most common problem is that the belts have either broken, or stretched to a point where they no longer engage the self-propelled mechanism. In order to verify this, simply make sure that the machine is set to the Carpet setting, turn the machine on, and turn it over on it's side with the handle release pedal reclined (make sure it's not in the upright position). Is the brush at the bottom of the vacuum spinning? If no, this definitely indicates that your belts have gone bad and need to be replaced. There are two belts on your machine, one controls the brush, the other controls the self-propelled mechanism. We've shot a helpful video that walks you through step by step on how to replace the belts.
This is by far the most common problem that we see on your particular model:
The other problem if the belts are installed properly that would cause the self-propelled wouldn't work would be the self-propelled actuator arm. There is a cable that starts at the handle of the vacuum, and runs all the way down to the floor head of the vacuum that controls the transmission. As you pull backwards on the handle of the vacuum, the cable pulls this actuator arm backwards, which then turns the wheels backwards, and when you push forward it turns the wheels forward.
The problem with the way it's designed however, is that if you pick up the vacuum cleaner by the handle of the machine rather then using the carrying handle on the back of the vacuum, it causes too much tension on the actuator arm, and will cause the cable to rip right out of the arm.
This is a VERY common problem on this model. To check and see if this part is broken on your vacuum, step on the handle release pedal so that the handle is in the vacuuming position, push the pedal a second time so the machine lays flat on the floor.
Now if you look right behind the height adjustment switch, and the rug / floor switch where the floor part meets the upright part, you should see a cable that connects into the actuator arm. Pull up and down on the handle and look for movement. Is the cable loose with only a nut attached to it, or is it resting in the actuator arm?
Here's a very helpful link that shows you exactly how to replace the actuator arm:
How to Replace the Actuator Arm on Hoover Self-Propelled Windtunnel
If this didn't help you, and the problem is still happening, please just use the add a comment form here on Fixya and let me know that you're still having problems. I'd be honored to go through and do some more advanced diagnosing with you.
I hope this we helpful to you. If you did find this helpful, please be so kind and leave feedback for me. This is why repair professionals like myself continue to come back and give free repair advice, to get the recognition of a job well done.
Thanks so much,
Chris Jones
GoVacuum.com
May 06, 2010 | Hoover Self-Propelled WindTunnel Bagless...
Hoover wind tunnel won't self propel
There are really two reasons why the self-propelled wouldn't work. It could either be the belts on the vacuum cleaner are stretched or broken. The belts on this model control both the self-propelled transmission, as well as the brush roller. Here's a video that shows you how to inspect the roller brush and belts to make sure that they are installed properly and working. Try this repair first, as this is the easier one to fix.
Thanks so much,
Chris Jones
GoVacuum.com
Apr 17, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
Self propel unit broken
This is a farily common repair on this model. What ends up happening is that when someone picks up the vacuum cleaner2_bing.gif by the handle of the machine, which on this model also is the controller for the self-propelled transmission, it places too much strain on the actuator arm of the vacuum2_bing.gif cleaner.
You can do the best to try and not pick up the machine by the handle, but instead using the carrying handle on the back of the vacuum cleaner, this is distribute the weight much better, and even make the machine seem less heavy, and this will also prevent the actuator arm from breaking again in the future.
Now for fixing your vacuum, Please click the link below for an excellent tutorial on how to replace this part;
How To Replace The Actuator Arm On a Self-Propelled Hoover Windtunnel Upright Vacuum
Feb 23, 2010 | Hoover Self-Propelled WindTunnel Bagless...
On my hover U6616-900 the self propell work fine on the med setting on med height carpet, but when I go to low height carpet and height set on med the self propell does not pull the vacuum and it is hard...
This is a typical problem you are describing. I would recommend you change the belts, this will resolve the "hard to push" and most likely resove your issues. based on the s/n given you maching was made on sept 2004.
Oct 24, 2009 | Hoover U6616-900 WindTunnel Bagless...
Self Propel doesn't work on Hoover Wind Tunnel
Your self propel wire could be broken. Lean the vacuum back like you were using it. If you stand in front of the vacuum look down and to your left. When you move the selp propel button you should see a wire move. If not then it's broken.
Oct 06, 2009 | Hoover Self-Propelled WindTunnel Bagless...
G-4 Kirby self propel unit works in reverse but not foward
Jon,
Here is a helpful link to use to adjust the tranny. About a 7 on the difficulty level.
http://www.greatvacs.com/Kirby%20Transmission%20Adj.shtml
Marci
Dec 10, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Self propelled function
There are few things that may have gone wrong:
First thing to check is if when pushing pedal it moves gears located on the rear axle (you will have to take cover shell off to see that)
If that works fine then primary belt may be broken (see it here). Then just replace entire set to make sure that belt type matches gears
Last - the most expensive problem - the main transmission belt within transmission is broken (then I would recommend replacing entire transmission)
Sep 10, 2008 | Kirby G4 Bagged Upright Vacuum
Vacuum too hard to push
If it is new, you can take it in for warranty repair. Is the self propelled turned on? Cable may have broke, or have a bad drive belt.
May 30, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Hoover Self-Propelled WindTunnel Bagless Upright VacuumVacuum Logo
386 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
