Question about Refrigerators
My Hotpoint refrigerator HTS18GBRERWW seems to be thawing things in the freezer. The only temperature control is in the refrigerator section (which I turned up). Is there a separate freezer control--if, where?
  • Anonymous Sep 30, 2008
    The freezer seems to defrost things on the top shelf. I might have had a stuck fan. I took the cover off and moved the fan and it started up. Not sure if it was just time. I think it was sticking. Getting temps of 44F in the freezer with with the setting set on 9. Driving me nuts.
Rotu
  • 175 Answers
SOURCE: Refrigerator not cooling properly
You may have a low freon condition in the fridge section. Look to see if you have an ice block building up on the rear wall towards the lower left side. If so, you are low on freon and the ost likely culprit is a leaking evaporater. The best way to tell if you are low on freon for sure is to take out all the shelves, remove the light cover, then the 2 screws holding the fan cover, and then remove the back wall. You wont be able to pull it all the way out cause the cold control is attached to it for the freezer and fridge so be careful. Turn the fridge control all the way up to 10 and wait till the compressor is running. you can tell if the compressor is running by pushing in the little switch on the top of the door frame and seeing if the fan runs(one switch is for lights, the other for fan) if it runs the compressor is on. anyway watch the coils and see if they develop frost all the way from top to bottom. If they dont you are low on freon and are ooking at about a $600 repair. if it does frost all the way you may have a bad cold control or a stalling fan motor up by the condensor on top. The best way to tell this is the next time the fridge feels warm, sheck the frame around the door seal and see if it is hot to the touch. If it is you almost surley have a bad condensor fan motor. Hope you can wade through all tis to find the answers. Good Luck!
Posted on Feb 24, 2007
  • 1314 Answers
you need to locate the defrost timer should be in the same box the temp control is some have little knobs some have funky little screw heads like the screws in bathroom stalls should be a hole in the housing where the thermostat is turn it slowley clockwise till you hear thu unit come on if it before you do that smack the temp control first a couple of times make sure its not sticking then let me know
Posted on Feb 16, 2008
  • 1073 Answers
SOURCE: odor like gas coming from freezer section of elecric refrigerator (Hotpoint)
wou ld unplug the machine and ventalate the room and call for a&e factory service ( sears) 800-805-9505 to be sure
Posted on May 05, 2008
SOURCE: MZD 2766GE refrigerator: freezer side is cold but refrigerator side gradually warms after a week and then freezer side warms.
fan won't start by itself.
Posted on Aug 10, 2008
mrfixit64857
  • 9 Answers
SOURCE: Power is on but nothing is working, not cold ,no water, no ice
Sounds like the unit needs a reset of sorts, Get your food into another refrigerator or ice chests and unplug the unit. let it stand open for several hours (just in case the vents are iced) and then plug it back in.
Posted on Jan 01, 2009
Adora freezer on the bottom not making ice
It could be a couple of things. Check to see if the bar that controls turning the ice maker on and off is in the down position. Up is off. My ice makes water line froze in the refrigerator section; no ice and no clod water. Check to see if the cold water is working in the refrigerator section. If not, turn the refrigerator section temperature to 42, keep the door open until it drops to that temp, and wait 24 hours for the water line to thaw. The water and ice maker should start working.
Jul 12, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridgidaire refrigerator flashing error code 4
From what I remember a flashing 4 means "damper error". Send your model number found inside or on the outside of the fresh food section, The air damper is found between the freezer and fresh food section and regulates temperature in the fresh food section by opening wide for things that warm up your fresh food section example would be opening the door and letting warm air inside . The damper then closes to keep the right temperature. If you have questions please ask, Thanks Sea Breeze
Sep 07, 2012 | Frigidaire Refrigerators
Frigidaire refrigerator/freezer side by side--compressor keeps running
Most problems with side by sides frosting up is due to failure of the defrost heater in the bottom of the freezer section behind the panel inside.
Jun 16, 2012 | Refrigerators
Model 596.73502203 Making intermittant buzzing sound. Moisture on inside of fridge and freezer. Food in freezer is thawing out.
I believe that your refrigerator may need a new 12002495 or 1184282 Adaptive Defrost Control You can find it inside the fresh food section and behind the controls for temperature. Not sure about the buzzing sound yet but the moisture and thawing of the frozen food points to a defrost problem. Need you to unplug and have a look at the adaptive defrost control. Would not hurt to open the back panel in the rear of freezer and defrost if needed and need someone to check the defrost heater and defrost thermostat. Sea Breeze
Aug 21, 2009 | Kenmore Refrigerators
Hotpoint HTS22GBMARWW refrigerator w top freezer - not cooling
This seems to be a model with an automatic defrost cycle.
The good news - is that everything major is working.
The bad news - it doesn't know when it needs to defrost or cool.
The reset is simply to turn it off for 10 minutes as there is no memory storage on these.
Hotpoint have a little get-out-phrase that they use sometimes - location.
If the room is too cold - it can sometimes affect the temperature difference between inside and outside the unit enough to make it think it needs to defrost. I think it's 15 degrees C that things start going wrong.
If the room is fine, then it is probably the freezer sensor that is strapped to the cooling coil at the back inside the freezer compartment. This tells the control when it's frozen solid - and needs defrosting. If it is not sending the correct resistance to the control, it can either defrost too much - or not at all.
If you can turn it off, and get to it to check it, check the contacts first, clean them if possible, replace covers and try again. If no change you will need a replacement. Some models you cannot even get to it, so if this is the case, a replacement control board is needed, or the wires from it need terminating together - dependent on model.
Jan 10, 2009 | Refrigerators
Refrigerator not cooling--has thawed/ but top freezer is cooling
Their is a fan that blows the cold air from the freezer to the refrigerator section, on some models. If thsi fan is  frozen or bad what you havwe discribed wil bew the result.
Nov 26, 2008 | Whirlpool Refrigerators
Hotpoint CTF15ELD top freezer refrigerator - freezer O.K. refrig too warm
hi thanks for the question you problem could be a no defrost problem remove the floor of the freezer 4 screws lift from back to front remove foam if its all frosted up you have a defrost problem a bad fan motor also can cause this it could also be stuck in ice if so use hair blower and thaw dry it real good re assemble and try again thanks the appliance doc
Sep 22, 2008 | Hotpoint HSS25GFP Side by Side...
Refrig/freezer problems
Could be due to a bad temperature control in the refrigerator section allowing the temperature to vary to much between the on and off cycles. This would also cause things to partially melt in the freezer and refreeze.
Jul 10, 2008 | Whirlpool ET8GTKXKQ Top Freezer...
Ffa70 hotpoint fridge freezer
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
May 18, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Refrigerators Logo
71 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
