Question about U-Line Refrigerator Ice Maker
Problem with ice maker
My ice maker wont dispense ice or crush ice at all I can hear the motor when I push the lever to dispence the ice can you please help thank you
  • christy721 Aug 30, 2008
    My U-Line Ice Maker/Refrigerator under the counter bar frig has been a pain the the us know what since the day I moved into my 2 year old house. I have had it worked on while it was still under warranty. This machine is not cheap like someone else on this site mentioned. It costs new 2800 bucks. That is not cheap to me. We can't decide whether it makes more ice when it is on a low cool setting or or when it is freezing the rest of the stuff we are just trying to keep cool. Does anybody else know what number setting for a happy medium for both ice and bev's?
  • runra May 11, 2010
    I need refrigerators controll wiring through box type relay
  • 286 Answers
Christy
Depends on the model. BI models or co29 the setting is warmer to make more ice.co2075 you have 2 tstats. So the icemaker control is seperate.What model do you have
Posted on May 20, 2009
Ice not dispensing through the door and I dont hear a motor
Ice Maker Not Dispensing Ice ' ThriftyFun
www.thriftyfun.com/Ice-Maker-Not-Dispensing-Ice-4.html
Question: Kenmore Refrigerator Will Not Dispense Ice Through the Door. My Kenmore... I don't hear the motor or the crushed ice. What do I do? I have a nearly ...
Ice maker is not dispensing - Checking auger motor & ice ...
? 5:33
https://www.youtube.com/watch?v=Uk83V-fA8Pk
Jul 1, 2013 - Uploaded by ApplianceVideo.com
Ice maker is not dispensing - Checking auger motor & icebucket - Maytag, Whirlpool MSD2550VE502 ... Don't like this video? Sign in to ... The Geek - Maytag French Door IceMaker Replacement - Duration: 25:28.
Ice Dispenser Repair Guide - Appliance Repair Guide
www.appliance-repair-it.com/ice-dispenser.html
Feb 09, 2016 | Refrigerators
FRS6LF7JMO Ice maker making ice. But will not dispense ice . have cleaned out ice container. Nothing jamed in auger. All back in push in lever to dispence ice not even a noise nothing.
It sounds like the motor that turns the auger is either disconnected or fried, it might also be binded elsewhere, but you should at least hear some humming if the motor is getting current. If you can figure out where the motor is connected you can test the windings for a short with a multimeter (set to resistance and a reading of zero means good, infinity means its shot).
Let me know if you need any more help
Jun 07, 2011 | Frigidaire Refrigerators
My ice maker makes ice but will not dispense it
When you push the lever to dispense ice, can you hear the motor running? If not, that motor might be dead and not turning the auger, which would be your problem.
If you can hear the motor and auger turning, the chute or the opening in the ice maker might be clogged up with ice. Clean the entrance to the ice maker and the chute in the freezer door and that should fix your problem.
Dec 13, 2010 | GE Monogram ZDI15C Automatic Icemaker
I have a Kenmore side by side, not sure the model, but it's probably 10 years old or so. It has an ice maker with water, cube and crushed ice dispenser. The ice maker works fine, but it will not dispense...
Most of the time the bin has been removed and not put back in properly. When this happens ice blocks the drive motor. Remove the bin and turn the auger by hand make sure it will turn and is not jammed. Now with the bin out push the light button in that turns the light out and have someone push the button for ice while the door is still open the motor should turn in the back make sure thereis no ice blocking it. If it turns nothing is wrong with the motor. The clicking sound is usually the motor jammed by ice or the auger not engaged on the motor. hope this helps good luck
Aug 15, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker not dispensing ice
If the dispensor light switches to cubed or crushed , the panel is good . Remove the ice bin , and hold the light switch in . Press the arm for CRUSHED ice , and if you hear a buzzing or hum , then the auger motor is frozen . Use a hair dryer directly on the " forks " for a while , ocasionally holding switch and activating arm , until the forks move . Lower the freezer temp slightly and reinstall the ice bin .
Aug 11, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Ice Dispencer is not releasing ice (cubed or crushed)
I would remove the ice bucket in the freezer and make sure that nothing has gotten between the motor and the auger that pushes the ice forward.
Jul 09, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice cube button is lite but the only dipenses crushed ice
We have had this problem on occasion. The lever up in the ice dispencer gets jammed with frost and ice. If you remove the ice bucket/auger and let it thaw or just rinse it with water and dry it. Give it a try. -Matt
Mar 13, 2009 | Frigidaire FRS26R4A Side by Side...
Ice maker not working
The icemakers won't make ice if the temperature is not below a certain set point. Varies between manufacturers. Try making the temp colder.
Feb 01, 2008 | Hotpoint HSS25GFP Side by Side...
Kenmore elite (106.53606202) ice maker will not dispense ice
When you push the ice dispensing lever, you should be able to hear the micro-switch clicking. If no click, the switch is faulty. The auger motor which is activated by the lever could also be faulty. This is the motor that causes the auger in the ice bucket to rotate one way for crushed ice and the other way for cubes. The auger could also be jammed. Try switching between crushed and cubes to unjam the auger. Empty the ice bucket and start again.
Nov 02, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
U-Line Refrigerator Ice Maker Logo
109 people viewed this question
Top U-Line Refrigerators Experts
doug2008
Stephen
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
