Question about Maxtor 300GB ONE TOUCH 2 USB2- 7200RPM 16MB (E01E300) Hard Drive
Maxtor one touch 3 external hard drive 300 gb
I backed up my hard drive onto this external hard drive without a problem. I went away camping for a week to find that the computer no longer recognized the maxtor external. I tried it on 2 other computers with the same problem. The lilght is on, I hear teh hd humming as it should, but it is not recognizable.
  • 6,831 Answers
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
My pc cannot detect my maxtor one touch external hard disk
Please try connecting it to another computer. That way we'll know if the problem is with the computer or with the actual device itself ;) Let us know what happens or doesn't happen :(
Feb 20, 2011 | Maxtor OneTouch III 300 GB Hard Drive
I lost my CD. How can I download the files for my Maxtor AO1B120
Find your product hare and download drivers
http://www.seagate.com/www/en-us/support/downloads/
Feb 11, 2010 | Maxtor OneTouch II external hard drive...
My computer cannot dectect my maxtor one touch III 320GB
well, 2 options, your hard drive is not working in that case, just get a internal hard drive which is serial and open the case for the maxtor and plug the drive inside the case. its cheaper to buy the inter hard drive, then to replace the external hard drive.
Oct 29, 2009 | Maxtor OneTouch III 300 GB Hard Drive
I need to buy one used 300gb maxtor external hard disk
I have it right here; I returned my cable box. What do you want to do? dan_caldwell@yahoo.com.
Mar 25, 2009 | Maxtor OneTouch II 300 GB Hard Drive
Maxtor One Touch II - installation Software
I have a disk that worked for me and I am running windows xp. I also have the website address that is supposed to have the 98 drivers which could work perhaps. http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=Maxtor_OneTouch_Drive_USB/Win98SE_Driver&vgnextoid=b07d8b9c4a8ff010VgnVCM100000dd04090aRCRD
Guess you could try them first and if that doesnt work I could perhaps make a backup of the disk/package/mail/ worth anything?
Feb 05, 2009 | Maxtor One Touch II E01H300 (EO1H300) 300...
Hi, I lost user manual, need to restore files back to computer.
Provided that you can find your external drive using My Computer feature, double click on that drive icon and search the drive for the files you wish to put on the computer drive (C drive). If you right click the file or folder on the Maxtor external drive and then choose copy, you can go to the folder on the C drive that you want to paste them into, select it and then right click the folder icon and choose paste to put them into the folder. To make the process quicker, you might choose to paste all files and/or files from the Maxtor drive onto the computer desktop and then move them around later.
Dec 27, 2008 | Maxtor OneTouch III Mini Edition 120GB...
Maxtor One-Touch 4 750gb power light flashes and goes out straight away.
Try to remove the drive and connect it directly to another computer.
If still doesn't spin up then most likely the board has failed.
Nov 03, 2008 | Maxtor One-touch III Mini 40 GB USB 2.0...
How to retrieve data from external drive
I had similar problem. See FAQs on this site. My 300 GB One Touch II drive was not found in the XP machine either as USB or IEEE. When I remounted the drive in an external cabinet from Deltaco ( MAP-KC) is is running since. The Maxtor chassi was the trouble not the 3,5 " drive. All data is recovered. // Regards AH2FOTO
Sep 24, 2008 | Maxtor OneTouch II external hard drive...
Hello
Kind Regards
Andrea
Sep 10, 2008 | Maxtor OneTouch III Mini Edition (R01E100)...
Computers & Internet Logo
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
