Question about Whirlpool Washing Machines
Washer leaves stains on clothing
Hello -
I am a manager of an apartment complex in West Hollywood and we have a Whirlpool washer and dryer. My tenants reported to me that the washer was leaving stains on their clothing. I had a repairman come out twice and look at the problem and he was unable to do anything about it and told me to contact Whirlpool directly. I did an experiment this morning with some clean, whitem unstained gym towels and ran them through the washer and they did come out stained. Some of the stains were small, dark and rust colored and the others were larger, faint stains. It's definitely a problem. It's a top loading washer and just past its warranty.
Thanks for your help.
- Clark Carlton
  • 1 more comment
  • carltonct Aug 11, 2008
    If it's the water supply, how would I know and is this something a plumber can fix?
  • carltonct Aug 12, 2008
    We had the washer washed last week. Is my plumber able to do something if it's the water supply? Thanks for your help.
  • Anonymous Mar 31, 2014
    The machine is leaving white stains on my darks
    Guru:
  • 1,894 Answers
Many times when we cook in the kitchen, we get splattered with oils that aren't easily visible. Very often these oil spots pick up dirt from the wash water. These stains don't usually get noticed until after the clothes have been dried. The best thing to do is to rub detergent or stain remover right on these spots and let them sit about half an hour. Then rewash the clothes in as hot water as the material can take afterwards.
Posted on Aug 11, 2008
  • 1 more comment
  • dewan nafees ahmed Aug 11, 2008
    As washers age, the enamel finish can chip and wear off, and then the drum
    and other parts will start to rust. There is also a build-up of scale
    and mineral deposits in the washer.
    Washer Magic
    will remove lime scale, soap scum, iron, and mineral stains. It also
    reduces abrasive build-up, which can be harmful to the laundry. Use
    Washer Magic
    monthly to prevent lime scale buildup, soap
    scum, iron, and mineral stains. You can also use RoVer
    Rust Remover
    or Yellow
    Out
    to get rid of rust on your clothing.
  • dewan nafees ahmed Aug 12, 2008
    this does not need a plumber to get it done sir.
    you can also purchase these products and you can use them easily.
    just click on the names washer magic and rover rust remover or yellow out
    thank you
    bt your main concern was about the rust.
    and this is not going to end till you use any rust remover.
    this must be done.
    also get your plumber and get the washer checked if he has done that work correctly.
    thank you
    please don't forget to accept the solution.
    Master:
  • 623 Answers
Must be the water supply or your washer needs a wash
Which is better for the dryer and why, dryer sheets or fabric softener in the wash?
Liquid in the washer is better since sheets in the dryer are prone to leaving stains (read back of package about stain warning on every box of softener sheets i have ever seen) also the sheets leave a build up on the thermostats and moisture sensor
While the liquid in the washer softens the clothes and has no build up or staining issues such as the sheets
Oct 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer leaves oil type stain on clothes.what could be cause?
Stains on clothes from this model of washer are usually caused by the door boot or the tub bearing going out. I recommend cleaning off the surface of the door boot and if you still get stained clothes I recommend having the rear tub & basket checked. I am also sending you more troubleshooting tips in the image below.
Dec 31, 2010 | Kenmore 98702 Stacked Washer/Dryer
Washer not washing leaving stains on clothing
It sounds like the silicone apron between your washer drum and the door has deteriorated. If that is the case, no cleaner will help you.
Best solution is to order a new one.
Jul 31, 2010 | LG WM2455 Front Load Washer
Starting to leave brown oily like stain on clothes
The first place that I'd check would be the small metal screens inside the openings on the water inlet valve. They can get really rusted, epecially in areas with hard water, so I would recommend removing the water supply hoses and take a gander at the screens. They can sometimes release the iron oxide into the wash water and cause brown stains or blotches on clothing. Hope this helped and best wishes.
Sep 07, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Duet Washer/Dryer get brown streaks on clothing
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer whining when washing and spinning leaving brown stains on clothes
Turn water off. Remove hoses and clean the rust out of the strainers at hose end. If they are clogged they will sound funny when water goes through them.
May 04, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Stains on clothes
Check the fit of the agitator to the bottom of the drum. After this many years, it may have warped up to make a gap. Run a rag around the joint to see if it marks.
Apr 21, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Leaves
with the exeption of something you mistakenly left in your clothing and wound up in the washer, not likely stains are from there , most of the time they do come from the dryer, try grabbin an old white rag nad runnig it around hte fron of hte dryer drum and then tyr the rear where the drum meets the back bulkhead. usually leavs brownish streks smome what curved 2-3 inches log. its from hte felt hte supposed to seal the drum. its either wearing thin, or a glide has worn away causing the issue
Mar 22, 2008 | Whirlpool LSR7333 Top Load Washer
Oil Like Stains on dark cotton Clothes - Whirlpool duet
Problem Solved !!!
Ok, I had to stop and tell everyone about my latest experience. When we moved here we bought the nice Whirlpool front load washer and dryer set. I Love them....still don't understand how my clothes get clean with so little water, but love them. ..................That is until lately. I was really upset about a total of 4 white blouses that looked to have some kind of light splattered stains on them after washing. I would try to wash them again with a stain remover sprayed or scrubbed on the spots, but they wouldn't come clean. I gave up and considered the blouses ruined. I told William what was happening and he called the repair man out because he thought it might be some kind of part in the machine that was leaking oil onto the clothes when they were washing. The guy came out and told William that there wasn't anything that could go into the washer tub and get onto the clothes. He then looked around in the washer and at the little detergent dispenser drawer. He suggested that we use 1 cup of Clorox and 1/4 cup of dish washer detergent (cascade with dawn degreaser crystals) on a hot to medium water temperature and turn it on a complete wash cycle to make sure that we didn't have mold and mildew setting up in our machine. After he left, I proceeded to do what he told us. I though.....the blouses are probably ruined anyway. I had tried to get out all the spots to no avail, so what the heck......I threw them into the mix too! Would you believe they came out clean, very bright white (instead of yellowed or dingy from continued wear) and the washer smells as sweet as it did when it was new. Why didn't they tell me about this when I bought it ??????????? I plan on putting the detergent mix in the washer every couple of months and throwing in all the whites that I can find to take advantage of the cleaning effect on the whites. (I thought that maybe some of you had gotten stains on white clothes that you would like to get out too)
Dec 06, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
1,322 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
