Question about Ericsson Lands Phones
Ericson DECT 260 - 1999 Loud intermittent crackling
    Genius:
  • 1,689 Answers
If it sound like a loud warning sound, you may remove or diable that, refer to page 27 of the manual.
but if it sound like a really loud noise when on the phone or just on page / intercom, then i suggest you get a new phone.
Ericson DECT 260 U-ser Manual
http://www.ericsson.com/ericsson/support/dectphones/pdf/260_us.pdf
Posted on Aug 11, 2008
  • 515 Answers
Try to change the battery. I had the same on my phone and change the battery and after that the phone is working fine.
    Master:
  • 623 Answers
Time to buy a new phone
SOURCE:
Sub Speaker giving intermittent loud crackling and sharp loud popping sounds even with main volume control turned off. Crackling sound can be reduced by turning sub volume control off.
It may be the control itself too. In time, these controls can get dust build up inside it. There are volume control spray cleaners available from Radio Shack or other electronic parts stores. The cheat on cleaning the control is to just rotate it from stop to stop as many times as it takes to clear the noise.
Mar 17, 2016 | Altec Lansing Acs295 Subwoofer
Crackle noise at loud volume
We will need more info to help you. Make and model of the problem gear, etc. Most noise problems are caused by dirty contacts in the jacks or intermittant solder joits in the circuit.
Feb 01, 2016 | Music
Rh750 - intermittent loud crackling noise even a few seconds after the unit is turned off. Is this a volume control switch problem?
No,it is not. Apparently, your speaker relay is not opening, as it should when you kill the power. If you'd like more assistance, or would like to inquire about a repair, please visit my website at audioserviceclinic.com. Thank you.
Aug 24, 2014 | Audio Players & Recorders
LGTV 42LCD - LOUD CRACKLING SOUND ON START UP -
Either your main pcb has a defective auido circuit or speakers are bad. Doubt it is the speakers or it would do it all the time.
Mar 20, 2013 | LG 42LC2D 42 in. LCD HDTV
My Bose Cinemate series ii is making very loud intermittent crackling sounds
Usually made from interference of some sort. Make sure that all wire connecting from both the input on the receiver and the output devices are properly secured and have no rips or tears in them. Also make sure there is nothing close the receivers with a powerful magnet (big subwoofers, powerful speakers, computers, etc) those can also cause interference. Hopefully this helps.
Sep 25, 2012 | Bose 318842-1100 - Cinemate Series Ii...
Vox ac30cc2x fault finding
Check valve you replaced has made proper contact in socket. Plug it in and out a few times to clean pins. Is inteference/crackling noise there when volume is turned down to minimum. This should tell you whether the problem lies before or after the volume control. A good clean can solve many faults. Servisol on pots works wonders.
Ian
Jul 24, 2012 | Radio Communications
TV makes very loud crackling noise
crackling in the speakers of 42"flat screen tv
Jul 20, 2010 | LG 42LC2D 42 in. LCD HDTV
Slight crackle on left speaker if turn volume up
the speaker is bad when you set the loud button on, you're putting more pressure on the speaker beacuse its bad it wll make that crackle sound. My advice change it.
Mar 03, 2009 | Panasonic CT-27G7 27" TV
Tv making a loud crackling
The set should be under warranty, call the company or go on line and get a servicer out asap. good Luck
Mar 19, 2007 | Polaroid FLM-3232 Television
Lands Phones Logo
217 people viewed this question
Top Ericsson Lands Phones Experts
Ekse
Marvin
Marvin
Are you an Ericsson Lands Phone Expert? Answer questions, earn points and help others
