I would say that it probably is a bad capacitor on the power supply board of the tv. What you want to look for is any round cylinders with the tops pushed up at all. The replacements are usually really cheap, it might also be the lamp, but usually when lamps go they go completely while a bad capacitor is known to cause intermittent problems that escalate into a tv only working for about 5-10 seconds.
Testimonial: "thank you for the help. I will attempt to locate and identify the capacitors you mentionedto see if this is the culprit."
I have a Mitsubishi WD-52528 52". When plugged in, it flashes it's normal green blinking light and stops after about a min. you press power and nothing happens. After about 2 min the green light starts flashing again and it goes off after about a minute and so on and so forth(continous)
What could it be?
