Question about Sony VGPPRSZ1.CEL Docking Station for VAIO SZ Series
Laptop is not recognizing the docking station
Hi
I have a sony vaio sz 75, I recently purchased a a docking station however the laptop is not recognising this docking station and there is no connection - no power etc
Kindly advice
Thanks
mgj1954
SOURCE: sony vaio r505jl docking station
I googled this and found that both the notebook itself and the docking station have ethernet connections, the docking station ethernet connection seems to be between the usb and monitor connection, The notebook itself has a ethernet connection on the right side of the notebook near the back under a rubber cover. Let me know if that was correct or not.
Posted on Feb 29, 2008
vincent721
  • 240 Answers
SOURCE: Sony Vaio laptop with docking station
Use the USB Hub...to have additional USB port..
Posted on Mar 16, 2009
skidoorev
  • 11 Answers
SOURCE: Kindly tell me currently which laptop gives better performance. ?
The internet speed depends on your internet connection along side with your downloading speed, and the processor is fast enough for casual play but not extreme gaming or streaming, although you can upgrade the processor. Buy a pre-built computer and get basic cheap parts, if you want a extreme computer, you will need to special order it or rebuild it yourself with top of the line after market modules.
Posted on Mar 22, 2009
Nic61
  • 1073 Answers
SOURCE: Sony VAIO VGN-NS10E - Booting Problem
Hi!
Yepp, its easy to solve that problem. Get in the bios and change the boot up seqvence, ist probly set to look for all kinds of bootble divices, change that to only boot from the hdd in your laptop, disable all other boot devices, when you done that, hit F10 to save the settings and restart your laptop.
Good luck
Nic
Posted on Mar 31, 2009
  • 59 Answers
SOURCE: Can I run a Sony Vaio VGN-FS980 laptop closed?
You should be able to go into power management utility whether it be sony or Windows and change the "when lid is closed" option from hibernate/shutdown to "do nothing"
on XP
CP>Power Options>Power Schemes
Posted on Jun 10, 2009
Looking for proper docking station/port replicator model for Sony VAIO laptop
If you don't give us the model reference of your VAIO, we can't help you...
Sep 22, 2014 | Computers & Internet
Will a kensington universal docking station work with my sony vaio pcg-7d2l
Yes it should if you are running Windows XP, Vista, 7 or 8. You just connect to the unit using a spare USB port on your laptop and a plug-plug USB cable. It has it's own power so you'll need a mains socket. This means you can unplug your laptop and leave any devices charging on the docking station USBs. Your laptop should auto-instal the station. I believe there is a table/support available which combines with this unit. There a varying prices for this unit so look around.
Good Luck
Feb 27, 2014 | Kensington SD400V USB Docking Station with...
How can i update dell dock?
A docking station is an extension or addition of ports for a laptop computer. Once the portable computer is docked, you can access the docking station's ports, such as PS/2 or USB 2.0 ports, through your computer. Some docking stations have monitors that you can connect your computer to, placing your video on an external screen so you can turn off your computer's monitor and conserve some of your computer's energy. All Dell docking stations will have the same general troubleshooting steps.
Plug your laptop's power adapter into the docking station and dock your laptop onto/into the docking station. If there is no power going to your laptop from the docking station but it works when the power adapter is plugged into the wall, the docking station is bad and needs to be replaced. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power goes on but your computer doesn't recognizes accessories such as a USB mouse--plugged into the docking station, try a different port on the station. If it works in a different port, the previous USB port is burned out. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized, you might have a corrupted docking profile. Undock the computer and dock it again once it has fully started up to reset the docking profile. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If you have an external monitor and it is not working, completely close the lid on the laptop so the image will move to the external monitor. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized and resetting the docking profile fails, update all drivers through Dell's support website and then re-dock the computer. Some of the software that runs the hardware may have become corrupted. Hope this helps
b>
Jan 16, 2013 | Dell Inspiron 1545 Notebook
Vaio pcg671l lost external power (no problem for the power supply cord, work well wit battery). I am looking for a compatible docking station as external power instead.
hi
hi. I would like to suggest you get these parts are offline, because it's easy for you to test before buying {make sure you match the parts before buying}
regards
May 15, 2011 | Sony VAIO PCG-505 PCG-671L PCG-700...
I need sony laptop drivers model PCG-6P9P
to the one who needs a sony vaio laptop driver,
i hav a sony vaio laptop model PCG-6P9P. evrything is in good condition except the battery and keyboard. how much do you want to pay for my laptop?
09228929023
Sep 13, 2010 | Acer EZDock (LC.D0303.005) Docking...
I have a Latitude D630 laptop and I recently purchased a docking station to use with it. I tried my laptop's PA12 Power adapter When I initially connected everything and placed the laptop on the dock an...
Try updating to BIOS to version A16 from http://support.dell.com Ensure you are not attached to the docking station when flashing the BIOS. Once updated, connect the 90W adapter to the docking station, connect your laptop to the dock, and power on using the docking station power button.
Nov 13, 2009 | Dell Docking Station for Latitude D600
Sony vaio vgn sz 460n Problem
your hard drive has failed as far as i can tell you will need to replace it take it to a sony store for verification
Aug 07, 2009 | Sony VAIO VGN-SZ460N/C Notebook
on XP
Jun 10, 2009 | Sony VAIO VGN-FS980 Notebook
Mar 16, 2009 | Sony Computers & Internet
Sony vaio r505jl docking station
Oct 16, 2007 | Sony VAIO R505JL Notebook
Sony VGPPRSZ1.CEL Docking Station for VAIO SZ Series Logo
160 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
