Question about Philips Magnavox 27MS343S 27" TV
Closed caption I have a Philips Magnavox 20MS2331/17 the closed Caption is always on and we do not have the original remote. It is making an annoying buzzing sound when the words scroll across the screen. Any ideas
  • Anonymous Sep 28, 2008
    this volume button solution does not work
  • Anonymous Nov 27, 2008
    nope
  • 138 Answers
The set is in demo mode press the volume upand the volume down button at the same time on the set.
Posted on Aug 19, 2008
How to turn off the close caption on tv
Hello
Not all TV programs and product
commercials are made with
Closed Caption (CC) information
included. Neither are all Closed
Caption modes (CC1, or CC2) necessarily
being used during the transmission
of a closed caption program.
Refer to your area's TV program listings
for the stations and times of
Closed Caption shows.
To close the close caption display from screen; press "CC" button on the remote control.
Jul 08, 2011 | Philips Magnavox 20MT133S 20" TV
How do I turn off closed captioning
If you have the original remote control, there's normally a single button that controls captioning. You press it to cycle through the captioning choices until you reach "off". If you don't have the original control, you may have caption control available through the on-screen menus. Not all makes and models provide it, though.
If you're using this TV with a cable converter, satellite receiver or another set-top box, the captions you're seeing may be coming from that device and not from the TV's caption decoder. Make sure you check that captioning is shut off on those devices as well.
Oct 01, 2010 | Philips Magnavox 27MS343S 27" TV
Lost remote, somehow child turned on closed caption without remote,how do I disable closed caption without remote?
Find a button on the tv manual control said Menu,press it. Goto tv menu find and turn off all CC1,2,3 and text 1,2,3.U should have no more closed caption.
Sep 12, 2010 | Philips Magnavox 20MS233S 20" TV
I have problem with our Magnavox TR2510C101. My toddler press everything and now it turns out there is black screen (square) cover the image. Do you know how to fix it? thanks!
You have accidentally gotten the Closed Caption turned on....
Here is how to turn it off....
1) Press the MENU button either on the front of the TV or on the original TV remote.
2) Use the Volume + or Volume - to highlight "SET"
3) Use Channel - or Channel + to highlight "CLOSED CAPTION"
4) Press Volume + to access the CLOSED CAPTION menu.
5) Press Channel - or Channel + until OFF is highlighted.
6) Press Volume + or Volume - to confirm selection.
7) Press the TV/AV/EXIT button on the remote to exit or the MENU button on the front of the TV.
GOOD LUCK and please rate this solution...
Jan 14, 2010 | Philips Magnavox 27MS343S 27" TV
How to remove closed captioning on tv screen
Press the Caption button on the remote control to cycle through the caption options until OFF appears. If there is no Caption button on the remote, go to the system menu and turn captions off in the caption submenu.
Jan 08, 2010 | Philips Magnavox 20MT133S 20" TV
Magnavox energy saver projection tv-cannot remove closed caption
If you can bring up the FEATURES menu and can navigate with the Harmony remote scroll down the the CAPTIONS options. If you can turn display OFF then you should be all set.
If you do not have the manual for this set you can see it at:
http://www.p4c.philips.com/files/5/55pp9401/55pp9401_dfu_aen.pdf
Feb 27, 2009 | Philips 55PP9401 55" Rear Projection...
HOW TO REMOVE CLOSE CAPTION FROM SMART SERIES TV
on your remote go to cc push that until it sayes closed caption off not positive but pretty sure
Jan 11, 2009 | Philips Magnavox 20MS233S 20" TV
Cannot get 27" magnavox closed caption
I called the Magnavox tech support - put the TV on channel 2,
hit the cc button repeatedly and problem solved.
thanks for contacting me.
Jun 25, 2008 | Philips Magnavox 27MS343S 27" TV
Close caption turns on and off by itself problem
Check the cable box to make sure the captions aren't truned on in the cable box.
If not -if it really is the Magnavox caption service- then -
This is assuming you have the original remote:
1 Press MENU to show the on-screen
menu.
2 Press VOL+ or VOL- until SET is highlighted.
3 Press CH+ or CH- repeatedly to
highlight CLOSED CAPTION.
4 Press VOL+ or VOL-
to display the
5 Press CH+ or CH- to select the
closed caption you want (OFF, CC-1,
CC-2, or CC-MUTE).
CC-MUTE sets
the TV to show closed captions when
you press MUTE. The TV volume will be
disabled until you press MUTE again to
restore the sound.
6 Press VOL+ or VOL-
to confirm your
selection.
7 Press TV/AV/EXIT to remove the
menu.
Feb 25, 2008 | Philips Magnavox 27MS343S 27" TV
Closed Caption
If you dont have the original remote, its going to be kinda hard, as universals wont work on this funtion on this set. The original remote has a button marked "CC" toward the bottom of the remote. Maybe you can borrowe on from a friend or a local sales store just so you can turn off the closed caption.. You can purchae a replace remote that is exactly the same as the original at http://www.remotes.com and enter your model number.
Sep 14, 2006 | Philips Magnavox MT1905B 19" TV
Philips Magnavox 27MS343S 27" TV Logo
427 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
