Question about HP Officejet 5610 All-In-One InkJet Printer
Cartridge Error Hello, A small piece popped off of my printer from the inside where the printing actually takes place. I replaced the piece and everything appears to be where it should be but I continue to get an error message stating "Cartridge Error: Refer to device documentation to troubleshooting" My device documentation doesn't include anything helpful. I've removed and replaced the print cartriges and I've tried to do the hard reset as you described by holding down 3 and # while unplugging and replugging in the power cord but the error message persists. Please let me know if you have any other suggestions. Thanks.
  • Anonymous Nov 28, 2008
    cartridge error refer to device documentation to troubleshoot
    Problem Solver:
  • 15 Answers
There might be a part inside the printer that is broken. The carriage might have been damage also. You've already done the hard reset and also replace the cartridges, then the only solution for this is to replace the printer since there is a broken part on it.
Jiffy Epe
HP Technical Support Representative
Posted on Aug 28, 2008
HP DeskJet F380 All-In-One Printer catridge problem
Try with another cartridge, If the same error, the printer head is bad.
Jul 04, 2012 | HP DeskJet F380 All-In-One Printer
How do i fix a cartridge jam?
Hi andmary,
While using the HP Photosmart C4180, the printer may display error messages. These messages alert you, as the printer's user, to any problems affecting the printer's performance. The printer can display the message "Carriage Blocked" on the printer's display screen, stopping any current print jobs and preventing you from printing anything until you resolve the problem. The error message can be caused by an actual obstruction, such as a stuck piece of paper, keeping the cartridge carriage from moving freely inside the printer. Sometimes the error is a result of a software error.
Instructions:
1. Turn off the printer, wait 15 seconds, then turn it back on. Press the "Setup" button on the control panel, then use the arrows to highlight "Print Report" and press the "Ok" button to print a self-test page.
2. Remove all the loose paper from the printer's input tray. Turn off the printer and open the back door by depressing the tab on the left side.
3. Pull out any stuck paper, being sure to turn the rollers to check for small pieces of paper. Close the back door and open the printer's front door.
4. Remove any stuck paper from the printer. Move the cartridge carriage from the left to the right side of the machine, removing anything that stops the carriage's movement.
5. Push down on each cartridge, then pull each one out of its slot. Replace the cartridges in their slots, then push forward on them until they each click into place.
6. Plug the printer back in and turn it on, then unplug the printer's power cord from the back of the machine and the electrical outlet. After at least 15 seconds, plug the power cord back in and turn the printer back on. If the problem persists, take the printer to a repair shop.
Hope this helps.
Thank you for using Fixya!
Sep 24, 2011 | HP Photosmart C4280 Aio Printer
Unable to print or delete a document
  • 1
    Remove the cartridges from the F380 printer.
  • 2
    Position the cartridges so they are right side up and the gold leads are facing you.
  • 3
    Place a small piece of tape over the gold contact in the top left corner of each cartridge.
  • 4
    Place the cartridge back in the F380 printer. The printer automatically prints an alignment page.
  • 5
    Remove the cartridges. Place a piece of tape over the gold contact in the top right corner of each cartridge.
  • 6
    Place the cartridges back into the F380 printer. The F380 prints another alignment page.
  • 7
    Remove the cartridges from the printer. Remove both pieces of tape from each cartridge.
  • 8
    Insert the cartridges into the F380 printer. The printer prints a cartridge alignment page. Each cartridge is now recognized as a full ink cartridge.
  • Jun 16, 2011 | HP DeskJet F380 All-In-One Printer
    Whenever I try to print something it says "unable to print 36". Ive restarted the printer and tryed to print something and for a couple of minutes it says cleaning then a few minutes later it...
    Remove the printer cartridge and check for any jams. If you don't see any large pieces of paper jammed in the printer, they may be smaller pieces so take care to notice anything small that shouldn't be there.
    Place the cartridge back into the printer.
    You may also want to unplug the power, wait a moment and plug it back in to clear the error and see if the issue corrects itself.
    Mar 02, 2011 | Brother MFC 490cw Color Inkjet...
    Error coming up that there is a paper jam at the cartridge but we have opened it all up and their is no jam
    First, verify that there is actually no paper jam (open all the doors, take out the paper tray, take out the toner/drum unit and visually inspect), if none, chances are there is a little plastic piece inside the printer that has popped out. The little piece allows the printer to detect when a sheet is exiting the printer. When it pops out, its gives the printer a false reading which makes the printer think there is a paper jam.
    Turn printer off and unplug the printer from all cables (power, USB, phone, RJ45, etc). Secondly, take out the drum/toner unit and place in a dark spot like a closet. Next, with the back of the printer facing you, turn the printer over so that it is resting on its front. The bottom should be facing you, and the back of the unit should be pointing towards the ceiling. I will use this orientation when describing the following steps.
    Most of the back of the printer is actually a removable piece held in place by 4 silver cross head screws. Two are near the bottom of the printer in fairly deep recesses. The top two are easily accessible. Using a regular cross head (not flat head) screw driver, remove the 4 screws.
    Once removed, the entire back panel should lift right off. You will then see the inside of the printer. You are looking for a small, gray plastic piece with a spring attached to it. It will probably be loose in the back of the printer. Its approximately 1.5" long and is roughly S-shaped. One end is different then the other, with one end being relatively skinny and the other end having a sort of paddle shape.
    This is the piece that has popped out and makes the printer think there is always a paper jam. If this piece is not loose and is properly secured in place then you have a different problem. Reassemble the printer and call Dell for a replacement printer.
    If the piece is loose, pick it up but ground yourself to the printer by touching any metal in the printer. Try not to touch the various electronics inside the printer unnecessarily.
    Looking at the back of the printer, roughly in the middle where the paper exits is a black bar with various rollers on it. Below this should be a piece of sheet metal, gray in color, running from once side to the other (left to right) of the printer.
    Visually follow this sheet metal piece. Roughly in the middle (left to right again) should be a small rectangular opening. Immediately below this should be a little black plastic piece with two little arms sticking out towards you, with a third arm perpendicular to the first two. This piece will be mounted on a small beige/brown PCB.
    This is the actual sensor that the gray S-piece popped out of. If you look at the gray S-piece, you will notice that it has two little round knobs, one sticking out on each side. These knobs snap into the small semi-circular feature on the top of the two arms. The third arm is where the spring on the S-piece pushes against.
    So, take the gray S-piece and hold it so that the spring is on the left, the thick paddle part is pointing towards the bottom of the printer, and the skinny part is pointing towards the top of the printer (towards the scanner section).
    The skinny curved section of the gray S-Piece actually hooks behind the black roller. Thread the skinny curved section of the S-piece through the rectangular opening in the sheet metal piece and hook it behind the black roller.
    Next, locate the two knobs on gray s-piece with the arms on the sensor so that they align with the top of the arms. Ensure that the spring's free arm is also lined up with the third arm on the sensor. When lined up, push down with a a small amount of force. You feel/hear a faint snap as the piece clips onto place.
    Check that the spring is properly located in its arm by pushing against S-piece to make it rotate. When you let go, it should spring back to its default position.
    That's it! Reassemble the back cover using the 4 screws. Go finger-tight only. These screws are only tapping into the plastic so if you over-torque them you will strip the holes.
    Apr 12, 2010 | Dell 1815dn All-In-One Laser Printer
    Small paper jam
    Unplug the power cord and open the cover and remove all the cartridge and try to look I inside around the roller and try to manually roll the roller and if you can see the paper try to pull is slowly.
    Have a nice day and do not forget to rate please...!
    Feb 04, 2010 | Canon PIXMA MP190 All-In-One InkJet...
    My printer is not recognizing my black cartridge
    We actually couldn't find a better solution than taking the printer apart to look inside. One of the plastic pieces that holds the print cartridge in place was broken, so we crazy glued it back into place.
    Jan 30, 2010 | HP PSC 2410 All-In-One InkJet Printer
    Error says color ink not installed.
    dear,
    u have to clean the are with a soft, a little bit wet cotton, where the cartridge is installed. its not sensing that one. also clean the area inside the printer where catridges go for cleaning. there is a foam type material inside that. clean that dirty part.
    regards,
    Jul 29, 2008 | Canon PIXMA iP90 Mobile Printer
    ALPS MD1000 Won't print
    Please ignore courtdate & creamgetmonE. Here's why:
    creamgetmonE - If you're using the XP driver, you are using something so crippled, it should have been aborted. USE THE ALPS DRIVER!!!!!!!!
    courtdate, oiling the carriage rail will not change a thing, apart from gunking up the printer, and ENSURING it will fail sometime in the future.
    TO FIX YOUR PROBLEM:
    There is a sensor under the anti-curl veil. Clean it.
    Jan 18, 2008 | Alps MD 1000 Thermal Printer
    Dell 1600 paper jam 1 or no cartridge
    Your unit is actually manufactured by Samsung. Most probably you have a bad paper sensor. As a technician, you will find these sensors on the power supply board (SMPS)or main board. If your are receiving tech support from Dell, please illustrate those guys on how to do their job.
    Sep 26, 2007 | Dell 1600n All-In-One Laser Printer
    HP Officejet 5610 All-In-One InkJet Printer Logo
    703 people viewed this question
    Ben Johnson
