Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Refrgerator side gets to cold
The refrigerator side is set at 37degrees and it keeps getting colder. after sitting all night with no use the temp is 28 in the morning.i set the temp to 40 and it does the same thing. Whats wrong?
  • Anonymous Aug 17, 2008
    Same thing, started when new. Mainly freezes vegetables in bottom drawers. Just started to solve problem.
  • kandkrichard Aug 22, 2008
    GE Profile PS123SGMD is 7 years old and not maintaining temperature
  • 93 Answers
Possible bad thermister or temp sensor. Part # wr55x10025. Your unit is a dual evaporator system. So fresh food side is independent from freezer. That would be the most likely cause. It retails for $14.00 from ge parts online. Good luck.
Posted on Aug 11, 2008
SOURCE:
GE monogram refrigerator too cold
There is a balance between the freezer and fridge. Reduce the freezer temp and see what the fridge temp does. By reduce I
mean make the freezer warmer. If it is set too cold the fridge gets colder.
Nov 25, 2013 | GE Monogram ZISS480DRSS Stainless Steel
I have a 22 cu ft. side by side refrigerator with an electronic temp setting. I noticed that the fridge was getting warmer this morning, but we put alot of groceries in it last night so I didn't pay...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 29, 2011 | Maytag Refrigerators
Put in garage now unit will not keep cold or freeze.
Since refrigerators were designed to run in your 72° kitchen, when you put a fridge outside, where its colder than normal operating REFRIGERATOR temperatures, i.e. 35-40°F, because that ambient temp is colder than fridge temp, the thermostat in the fridge section reads it as normal temperature, and does not turn unit on. it does not read what the freezer temp is. You have a couple of choices: bring the unit inside, heat your garage, or only use it for pop and beer in the summer. You can reply here or send me a question from my website: www.FixMyFridge.net
Mar 15, 2010 | Refrigerators
Ge profile Ps27sgra refrigerator and freezef are
Hi, this problem is going to be with the running thermostat2.gif (cold Control). It has gone bad and stays open which in turn will keep the compressor running continually and will cause the fridge2.gif to get colder and freeze food. It can normally be located in the control panel inside the fridge (it is the control that has wires, the other is the damper). Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Oct 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer works great, but fridg. will not get below 50
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 17, 2009 | Maytag MZD2766GES Side by Side...
Freezer and fridge are getting warmer and warmer despite their settingsGE Profie PDS 20 MFS 2005
ONE OF THE MOST COMMON CAUSES FOR A SERVICE CALL IS EXACTLY WHAT YOU STATE, THE MAX SETTINGS ARE SET AND STILL ITS NOT GETTING COOLER, ESPECIALLY IN FRIDGE SECTION RIGHT?
IF YOU ARE MAKING ICE THATS DRY THE FREEZER IS OK,
THE PROBLEM 90% OF THE TIME IS THIS
AS THE FRIDGE SECTION IS RELIANT 100% UPON THE COLD AIR MIGRATING INTO THE FRIDGE COMPARTMENT VIA A LITTLE FLAPPER DOOR THAT OPENS OR CLOSES OR IN BETWEEN AS WELL , THUS ALLOWING MORE OR LESS AIR TO MIGRATE INTO THE REFRIGERATOR SIDE FROM THE FREEZER SIDE
THE STUPIDEST THING IS THE FRIDGE SAYS MAX COLD ON BOTH SETTINGS, ONE ACTUALLY CONTROLS THE COMPRESSOR AND DETERMINES HOW LONG THE COMPRESSOR WILL RUN IT USUALLY IS OFF AND 1-10 , THE ONE THAT TURNS OFF THE COMPRESSOR ISNT THE ONE THAT DETERMINES THE REFRIGERATORS TEMP! THE OTHER SETTING FOR COLDER FREEZER DOES!!!! TAKE THAT SETTING BACK OFF OF MAX FOR COLDER FREEZER AND THE LITTLE FLAPPER WILL OPEN ALL THE WAY , WHEN SET FOR MAX COLD THE FRIDGE SIDE STARVES!, ANY SETTING 1-10 SHOULD STILL KEEP THE FREEZER FREEZING AND MAKING ICE IS THE KEY! IF IT CAN THEN ITS NOT A REFRIGERATION PROBLEM , IT IS A CIRCULATION ISSUE
Aug 23, 2009 | GE Refrigerators
Refrigerator in garage
Yes it is very possible that exactly what you are describing can be happening. Also try a thermometer frozen in a cup of water to get more accurate temps. Also 33 in the fridge is very normal for the cold control set on max and the heater installed. Let me know the temps in the frz with the thermometer sensing product temp not air temp which fluctuates often.
Dec 22, 2007 | Frigidaire FRT21P5A Top Freezer...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
161 people viewed this question
Top Refrigerators Experts
Brad Goodale
Peter Taylor
Tmik
Tmik
Level 1 Expert
