Question about Sony FD Trinitron WEGA KV-20FS120 20" TV
Tv, takes 30 minutes to open after switch on
My tv, takes 30 minutes before it open, need help what should i do, no money for a new one
    Genius:
  • Sony Master
  • 1,691 Answers
There are many things in the set that can cause this. Some components have become thermo sensitive with age, and are drifting back in to specs as their temperature increases from having power applied.
To troubleshoot for this type of fault can take a fair number of hours of work for an experienced tech. Then there will be the cost of the parts involved.
Eventually there will be a total failure. With age the CRT also becomes weak, and this contributes to the problem.
There is a point where the set will have to be changed. Your set will be sort of expensive to service.
Jerry G.
Posted on Jan 17, 2009
SOURCE:
My 56 Gateway rearprojection tv takes about 10 minutes to turn on. When you hit the power button I can hear a loud humming sound and in about 10-15 minutes the tv turns on. After watching tv for about 30...
take to a shop for 29,95 to check. vise 150.00 to check in home. call around some charge more. Its better to know , than guess on that kind a money. age is a factier in repairs.
Jan 03, 2018 | Gateway DLP56TV 56" Rear Projection...
RCA 27R411T 30" TV - purchased 2004
yes i think the tv is on its way out
could be in the jasks the main board
your picture tube could be on the way out also its most cheaper on you to purchase a new set
Jul 29, 2008 | RCA 27R411T 27" TV
My 32LD30UA LCD TV is 16 months old, when you switch TV on the picture has a band of reds and greens running down screen for about 30 minutes then returns to normal.Help?
My HITACH 32LD30UA LCD TV when you switch TV on the picture has a band of reds and greens running down screen for about 30 minutes then returns to normal.
Dec 12, 2010 | Hitachi 32LD8700 32 in. LCD Television
I've had this TV for several years. Lately it started to show ''invalid input'' whenever I turn the TV on. It would go away after a few minutes but not before switching inputs on its own. Same kind of...
Unplug it ,take the back off, look at the fuse,if open,replace it with same amperage,check the IC,s. To do this you will need a ohm meter, depending on the age of the tv, I might look into geting a replacement,also check all capacitors for swolen or puffed up,leaking parts,when replaceing certain parts,take note of how they came out - + hope this helps...
Mar 15, 2010 | Televison & Video
2003 saturn ion will not start somtimes
The security interlock on the ignition switch goes bad. The ignition switch needs replaced. (about $35 from the dealer) It takes about 30 minutes to replace and another 30 minutes to "learn" your key. The car locks out for 10 minutes when it fails so if you look in th emanual there is a procedure to override the lockout but it won't work for 10 minutes. Google the problem there are procedures for the switch replacement and learning the key with the new ignition switch.
Mar 06, 2009 | 2003 Saturn ION
Mitsubishi WT-42313 42 in. rear projection tv
I guess I have to pay money for a solution, which is not what this website says. The only answer I got was pay money and we'll tell you. Is that true/
Sep 16, 2008 | Mitsubishi WT-42313 42" Rear Projection...
resolder all cracked solders on the jungle ic.do you have any experience in electronics?
Aug 13, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Broken on/0ff switch
as you are not a technical person get it fixed by a skilled man. it is a simple job of hardly 30 minutes. new switch is available at low cost. it can be connected directly if you do not want to change switch. caution please do not not open back cover unless plug is out as high voltage is input to switch
Sep 18, 2007 | Bush 2871NTX 28" TV
Power on problem
Many of the later model Sony TV?s have a built in self-diagnosis function. AKB circuit (automatic kine bias), the timer/standby indicator blinks 5 times for about 30 seconds then goes to the self-diagnosis function. In other words, the IC chips on the Cboard are burned out. This repair is not one that should be attempted by the end user. This repair will need special test equipment. You will need to take it in for repair. It shouldn't cost more than $170-$200. This is cheaper than a new TV set.
Jun 23, 2007 | Sony FD Trinitron WEGA KD-27FS170 TV
Sony FD Trinitron WEGA KV-20FS120 20" TV Logo
26 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
