Question about Lexmark X4270 All-In-One InkJet Printer
Sendidng a fax
When I try to send a fax it gives me a message that says Remote Fax Error. It will let me recieve faxes but not send them. It was given to me & didnt come with a book. Whta can I do to fix the problem? Its not connected to my computer just my phone line. Thanks Mary!!
  • Anonymous Aug 20, 2008
    I receive faxs fine but on trying to send the other end gets a report sheet but no fax... On my end it says remote fax error try again or use another fax remote machine
  • Anonymous Jan 09, 2009
    It won't receive nor send faxes, instead, it keeps giving me error #1203 all the time. but the telephone is ok.
I have been sending and receiving faxes for over a year on my Lexmark X6100 printer. Now whenever I try to send a fax it will say it is sending the pages but then waits for a redial. After doing the same thing a second time it will print out "remote fax error"
Posted on Oct 08, 2008
I used to be able to send faxes to these same fax machines 2 months ago. Now I cannot.
Posted on Aug 25, 2008
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Well..all new fax machines are NOT compatible with all older fax machines. There's not much you can do about this. Try it with a known good fax number, and see how that goes..
http://tinyurl.com/6qcpgy
Posted on Aug 19, 2008
When ever i recieved fax its gives me fax remote error after 15 20 min it prints
Hi. You may be having a problem with the quality of connection. Check telephone cable for any physical defects. Try to plug printer in a different phone jack in the wall. Try to call your phone company to have the line checked, maybe they can do something to increase the quality of signal. Make sure that you already registered the user information like your fax name and your fax number in the fax by going to Fax mode > press Menu > Fax setup > Dialling and Sending > Your Fax Name or Your Fax Number. You can also decrease the transmission speed of your fax by going to Fax mode > press Menu > Fax setup > Dialling and Sending > Max Send Speed > change the speed to 9600 bps > hit check to save settings. Hope this helps.
Mar 14, 2010 | Lexmark X5470 All-In-One InkJet Printer
Hi my name is lionel whenever i try sending a fax line error message comes up fax does not go what is the problem. thanks
To activate it you should install the fax program. this will require that you register your fax adress.
this is a requirement of utilizing the system of sending and recieving Fax.
Just fill in the information as requested, and it will register your Fax adress.
As soon as you hav ecompleted this,you will be able to send and recieve fax,
and no more error messages, unless ther is a technical problem.
Feb 02, 2010 | Dell 966 All-In-One InkJet Printer
Recieve error 334 when sending fax but i am able to recieve faxes
Error Codes: 332, 333, 334, 335, 336, 337, 338 ECM, 339 ECM, 340 ECM, 341 ECM, 342 ECM, 343 Definition
The remote fax machine might be defective.
Solutions
  • Try to verify this by sending the same fax to other fax machines. If these transmissions are successful, then notify the user of the remote machine to make them aware of the issue.
  • If the fax fails when sending to other machines, turn it off for 10 seconds, turn back on, and then try sending again.
Error Code: 334
Definition
Solutions
Sep 20, 2009 | HP PSC 2210 All-In-One InkJet Printer
Hp 640 cant send or receive fax(NO ANSWER FROM REMOTE FAX
Since the fax machine is about 4 weeks old, why not give it back to HP? Warranty still covers it.
May 22, 2009 | Office Equipment & Supplies
Can't send faxes. Dials Ok but no connection to send fax
If you are unable to send the faxes, please try decreasing the modem speed and disabling the "Error Correction Mode." To decrease the modem speed, please follow the steps given below:
1. Press the "Fax" button.
2. Press the "Options" button 15 times till it reads "Advanced Fax" on the display.
3. Press the "Select" button.
4. Then press the "Options" button 10 times till it reads "Max Send Speed."
5. Now press the "Right Arrow" button and choose "9600 bps."
6. Press the "Select" button.
To disable "Error Correction," please follow the steps given below:
1. Please press the "Fax" button.
4. Then press the "Options" button 11 times till it reads "Error Correction."
5. Now press the "Right Arrow" button and choose "NO."
May 19, 2009 | Lexmark X4270 All-in-One Multifunction...
Hi, Remote Fax Error being displayed
Set the DRPD in the settings to 9600 and then try send a fax ...
Jan 29, 2009 | Dell 924 All-in-One InkJet Printer
Dell 962 printer
Remote fax error means there is something wrong on the receiving end, not with your fax.
It could be that it can't negotiate the handshake with your machine (that static noise it makes when it first connects).
Or it's not set to a receive mode.
Have you tried just calling the remote fax with your phone to see if you can hear that it is in a recieve mode (you'll get the static) or that it's not going to an answering machine by mistake (a common problem)
Aug 01, 2008 | Dell 962 Photo All-In-One InkJet Printer
What happens if you dial the remote fax number as a voice call on another phone? Does that number pick up? Does it give you the modem handshake noise? If not, the remote side has a problem.
Can you fax other numbers? What happens when you dial your own fax line from another phone? If your fax does not pick up and talk to you, your fax may have a problem.
Jul 24, 2008 | Dell 962 Photo All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
281 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
