Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hotpoint wd440 heating but not drying
Please help, my wd440 is not drying properly. the cycles are all running correctly, there is no blockage and the dryer is getting hot. when the cycle finishes we get get very hot steamy clothes, all still wet! any ideas???
Yes, the dryer is pants im afraid. weve had ours going on 4 years & it has broke down every 6-10months - seriously! the dryer will leave clothes hot & steamy but when hung up for 1/4hr they r dry! _ Hotpoint advised us that he machine is esigned his way - but dont believe a word from their corporate b***hit mouths!
Posted on Aug 24, 2008
Hi i have a hotpoint aquarius wd440 14000 spin i have flashing lights on the on off and on the drying heat. It is a washer dryer .but I never use the dryer. can somebody please tell me what's
I believe your issue is a blocked/clogged water drain. If your unit appears to drain all of the water at the end of the cycle, you may just need to clean your filter. The machine can sense when it takes too long to drain and it flashes those particular lights to let you know what the problem is.
Dec 22, 2014 | Hotpoint Washing Machines
Hotpoint WD440 creases clothes badly & takes ages to dry
This sounds like excess steam in the drum. Check that the drain filter is clean as washer driers rely on cold water being taken in to cool the condenser tank during the drying cycle. If the filter is clear, the tank may be blocked with fluff. You have to open the machine a look for a big plastic tank, usually down the right hand side.
Dec 11, 2009 | Hotpoint Ariston WD440G Front Load...
Hotpoint aquarius wd440. Flashing lights
press and hold on off button till the display panel lights up.Then press and hold the on/off button and the start /cancel button together.You will now reset the washing machine settings.And just pick your cycle again
Oct 04, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint washer dryer lights flashing
Check first the thermal fuse.
Test heating element to ensure is not grounded, and staying always on. Test the fan and ventilation system.
If you find no fault in there , then test the timer control board.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 23, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint WD440 Drawer overflowing
Hi.
I would check the inlet hose from the bottom of the soap dispenser where it goes into the drum for a soap blockage.
undesolved powder can build up here and prevent the water entering the drum
You can access this hose by removing top cover.
the hose is on the left side front.
This should solve your problem.
Please leave feed back.
Thanks.
Nov 25, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wd440 flashing dryer heat button and onoff button !
I had to have a tech come out for the same problem two weeks ago. They had to clean the lint collector which you cannot get to on your own. He said now that this has been done everytime I use the machine, take the clothes out and then run a rinse spin cycle.
Aug 04, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD440
u might have a blockage in the drainpipe. hope it helps. good luck!
Jun 16, 2008 | Hotpoint Aquarius WD640 Front Load...
WD440 drying high heat and 0n/off light flashing
Just had the exact same problem and think I may have solved it. even turning power off didn't solve it. I think what happened was that the programme had been interupted while drying. I tried everything to get machine to work afterwards but only the following worked - while lights are flashing put back to the same time I had set to dry (60) in my case and turned the dial to M for dry high heat light goes off after a short while - leave for 5 mins then press off. machine will make a noise for a short while then stop.
If this happens then machine should be back to normal.
this is same for both posts I guess.
Feb 03, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius wd440
Find the pipe that comes out of the bottom of the drum, this may contain coin, muck, etc. Clean. This pipe leads to the small pump that draws the water out. If your clean of the pipe does not work the machine.......there could be a fault with your pump..........which you can/cannot clean.
Dec 29, 2006 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
911 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
