Question about ABS Computer Technologies Awesome 1300 (1720) PC Desktop
Overheating my ABS (3 years old) keeps overheating - what can I do?
  • ABS Computer... Master
  • 3,051 Answers
Have u checked and cleaned the fan a lot of lint and other debris can get inside a computer and clog up the fan canned air works great for this if fan is not working make sure that the fan's wire is still hooked up if it is and the fan is still not working you may need a new fan please keep me posted ok best regards mike
Posted on Aug 11, 2008
More on Celebrity X motor overheating. Brushes look good. Brake does not seem to be dragging, Batteries are about 5 years old but hold a good charge when not in use for months,
If the motor is overheating, it is drawing far more current out of
the batteries than it is supposed to. Assuming it is 2 x 13v x 33ah
batteries, these are good for about 2 to 3 years on my scooter and 'wheelchair. AGM (absorbent glass mat) lead acid batteries do deteriorate over time due to battery chemistry.
Although the batteries may appear to take a charge
and the voltage 12.6volt x 2 = 25.2 volts nominal, with no load
on them, the motor controller takes a whack of current to get you going.
I have an digital voltmeter/ammeter installed on my Pride XL scooter and I was amazed how much current the motor/motor controller takes from the batteries. 50 to 80amps on startup.
If the battery voltage drops due to the age of the batteries, as the
energy is being used up from them, the current required by the
motor for rotation has to go up, and that will cause overheating of the controller and the motor. It is Ohms law plain and simple
the less voltage available-the more current required to do the
work and current creates the heating effect.
I replace my batteries every two years. Can't take a chance on
being stuck with discharged batteries.
Feb 20, 2015 | Pride Celebrity X 3-Wheel Electric Scooter...
2010 KAWASAKI ZZR 1400 OVERHEATING
Hi, Anonymous and the usual suspects are:
1. Low coolant level.
2. Restricted radiator air flow.
3. Faulty thermostat.
4. Coolant pump or fans inoperative.
5. Vent hose crimped.
6. Air in the coolant and needs bleeding.
7. Engine idling too long or bike moving too slow.
8. Coolant too old needs to be replaced.
9. Faulty temperature sensor, wiring or connector.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
https://www.kawasakiforums.com/forum/ninja-zx-14-74/overheating-traffic-19767
Proper Coolant
Kawasaki ZZR1400 ABS Service Manual
OEM Parts for Kawasaki
Kawasaki ZZR1400 Owner Manual
Oct 02, 2014 | 2010 kawasaki ZZR 1400
Car won't start
old post , no year car, 1989 to 2002
there are 3 engines, 2 up to 1998. all made by toyota
overheating is it,
forget all else. FIND reason for overheating, coolant lost top list.
if loosing coolant that is #1 above all else. find cause.
but
overheating KILLS all ENgines. if not cured fast.
warps heads
is it pinging? that too kills engines.
your engine should never overheat unless it has cooling problems or.
unless the head is warped now, it will overheat, due to coolant loss
is it loosing coolant every hour or day?
CRANKING ALL ENGINES THAT DONT START DRAINS ALL BATTERIES, IT'S NOT a SYMPTOM IT'S NORMAL FOR NOSTARTS. (starter sucks 100 amps from battery every try)
id do a compression test first.
look for coolant in these spots
1: pavement below car.
2: passenger foot wells. (heat core leaks)
3: low radiator at neck cold show no coolant seen there.
4: in the a/t transmission, turns AFT to chocolate milk.
5: water in the engine oil pan, and or the reverse.
oil in the radiator, or side tank.
do all you can to not overheat any engine, and keep the repair bill like 1/3 or less. of BOOM
Apr 09, 2014 | Geo Prizm Cars & Trucks
2005 Ford Tarus. Where is the ABS Module located ? Is it difficult to replace?
Why would you replace an ABS Module
on a vehicle, only 5 years old?
The module !!
The Controller !!
Feb 22, 2011 | 2005 Ford Taurus
On off button keeps going red unit only 2 weeks old
firstly if you get the 3 red lights then Microsoft repair your console for free so long as you purchased it no more than 3 years before you send it back for repair. The 3 red lights are a sign of overheating, and to go into more detail this is what happens:
The 360 had a manufacturing fault or air vents were covered and so the 360 overheated, and got so hot that the solder balls on the cpu or gpu chip melted, and due to the fact the the 360 motherboard is able to flex a little, when the 360 was turned off and cooled down these solder balls solidified again, however they solidified in the wrong place or in two half's etc. and so the 360 shows the 3 red lights to indicate this fault.
Click here to download Microsoft xbox360 repair guide
Jan 04, 2011 | Microsoft Xbox 360 Console
I have a 1994 316i and i can't find the location of the abs controller. My abs light is constantly lit and have had it on the diagnostic but not showing any faults. Can you help?
Most people, when the light comes on, your abs is down, either fix it or not, you still have brakes, but no abs, so most can't afford the $1500 to put into a 12 year old car. They tape over the light and drive away. My light came on 8 years ago, I took out the bulb. Never noticed the difference. The unit in front of the power assist unit is what needs changing,,, I think,, Not sure, It is called, ABS Hydrolic Unit , the ABS Pump Motor ,and the ABS Module could be at fault also. So, if it was the rear only, it would be great, when was the last time you had to stomp on your brakes? Get out the tape, I didn't tell you that, it is what I did. Hope this helps.
Jul 02, 2010 | 1994 BMW 3 Series
Abs light comes after riding a mile or so want go off
you have wheel sensors on all four wheel assemblies,if the light is comming on have your brakes ckecked.
Aug 03, 2009 | 1998 Volvo V70
My HP Pavillion DV100 notebook shuts down whenever it feels like. What could be causing this.It is 3 years old now so off warranty. It will work just fine for a little while and then voila! shut down.
Sounds like classic overheating, check your power supply fan, or the fan of your heat sync that seats over your CPU as well as the heat resistant insulation thermal lubricant that's there to keep it cool.
When fans starts to go the bears or motor starts to stick and will intermittently stop. When when it goes altogether it ceases to turn and can cause serious overheating damage to your circuitry.
Jul 27, 2009 | HP Pavilion dv1000 Notebook
Sharp Actius MC24 PC Notebook overheating and shutting down
If it under warranty I would take it back to them.
If not I would open it up and check for dust build up and make sure the fan is working...
Aug 01, 2008 | Sharp Actius MC24 Notebook
ABS Computer Technologies Awesome 1300 (1720) PC Desktop Logo
Top ABS Computer Technologies Computers & Internet Experts
David Payne
David Payne
Are you an ABS Computer Technologies Computer and Internet Expert? Answer questions, earn points and help others
