Question about Belkin Computers & Internet
Hello, I just got a Belkin 2 port kvm with cables installed and because it was bulk packed I don't know the hot key to switch between pc's. Does anyone know? TK
  • 37 Answers
There should be a switch, or button on the kvm itself.
Posted on Aug 12, 2008
Hi how can i switch computers using Belkin
Try tapping the scroll lock key twice and then the up or down arrows, or tapping the scroll lock key twice and then the "s" key to auto scan.
Dec 05, 2009 | Belkin F1DK102P 2-port KVM Switch
Belkin Flip PS/2 - KVM switch - 2 ports how do i switch from pc to pc on key board
The instruction below the link is for a 2 port version KVM, and may not apply to your particular model. You can look your model up here:
http://en-us-support.belkin.com/app/product/list/q/kvm/session/L3NpZC9BSk5yVUZKag%3D%3D
You can switch directly to any port by entering the Switch port number you wish
to use. For example, if you press “SCROLL LOCK”, “SCROLL LOCK”, “2”, the
computer on port 2 will be selected.
AutoScan Mode
In AutoScan mode, the Switch remains on one port for eight seconds before
switching to the next. This time interval cannot be changed.
To enable AutoScan mode, press “SCROLL LOCK”, “SCROLL LOCK”, “S”.
Oct 05, 2009 | Belkin Computers & Internet
2-port KVM switch mouse & keyboard connected to wrong display
I have installed several of these KVM switches before... that's not normal. It sounds like there's a manufacturer's defect which is causing the video to link up with the wrong keyboard/mouse cables. If you just bought it, I'd recommend returning it and getting a replacement.
May 16, 2009 | Belkin F1DK102P 2-port KVM Switch
Belkin kvm PS2 Flip switch broken .. Can I use a hot key instead?
Belkin provides software that allows hotkey setup for these KVM's, as well as the USB and DVI FLIPS. see the site, or download here http://www.belkin.com/support/article/?lid=en&pid=f1dg102w&aid=5874&scid=219&fid=2500&fn=flip_10214_82206.exe
Nov 18, 2008 | Belkin 2640-FTUA 2-port KVM Switch
KVM 2 PORT SWITCH
Yes try uninstaling the kvm switch reboot pc's install the kvm again and try another key and see if that works
Jan 29, 2008 | JustCom jc-102cp 2-port KVM Switch
Can's switch without it switching back to first PC
Sadly, it is probably the KVM as this particular model has a string of failures and is only rated 2 out of 5 stars on Amazon due to poor performance. :( http://www.amazon.com/Belkin-F1DK102U-2-Port-Switch-Cables/dp/B0001JXAQ6/ref=sr_1_1/105-6999807-3936431?ie=UTF8&s=electronics&qid=1187826004&sr=8-1 What I would do first is plug in Computer 2 directly to the monitor, keyboard and mouse with no KVM. If those work fine, it is probably not a computer issue; if you don't get video here, then it is a seperate issue with that PC. If Computer 2 is working, plug both computers into the KVM but switch the cables (plug Computer 1 into the KVM using Computer 2's cables). If Computer 2 shows up and can't switch to Computer 1, then it is the KVM messing up.
Aug 21, 2007 | Belkin F1DK102U 2-port KVM Switch
Belkin KVM 2 port switch
Sounds like its not detecting video on the 2nd port. Have you tried switching the computer on port 1 to 2 yet? If the problem moves then I would suspect that computers video card or the cable that connects it to the KVM. Let us know what happens or if you need more assistance.
Jun 26, 2007 | Belkin F1DK102U 2-port KVM Switch
Cannot switch between PC's
Typically, the KVM indicator light will only light up on the connection that is currently active. The indicator light will switch to another connection when that connection becomes active. First I would make sure that all the mouse and keyboard connections are secure. I have seen where these sometimes pop out, and thus some componenty will not work. I would then make sure that all the computers are fully powered on. The KVM will not allow you to switch to a device if it is not powered on. The KVM may indicate that a connection is down by a blinking light if you switch to a port and the connection is not up. It sounds that you have atleast one good set of cables. I would confirm that the other sets of cables are good as well. Do this by swapping the other cables with the one port that you know you have working. Finally, with a set of good working cables, swap them over to the other ports on the KVM switch. Although it may be improbable, you may have a bad KVM. AS always, I would review the product manual here: http://web.belkin.com/support/download/files/P74711ea_F1DJ10x_man.pdf And, since this is a new product, you will also be entitled to free tech support from Belkin: http://web.belkin.com/support/phonenumbers.asp?pge=bro 1-800-2BELKIN x2263
Sep 03, 2006 | Belkin (F1DJ104P-B) 4-port KVM Switch
Problem with Belkin OmniView KVM F1DS102P
Is the LED for position 1 and 2 always on? If the switch doesn't detect power on the PS2 keyboard connector it won't let you switch to to that position. If you are using a USB mouse with an adaptor or a wireless mouse try a conventional PS2. I have a MS wireless mouse one of my switches does not like and have to resort to that sometimes. Another issue could be excessive cable length or PS2 extension cables. Let us know if you have any more questions on this topic and please don?t forget to rate the post.
Aug 31, 2006 | Belkin OmniView¿ SOHO Series 2-Port...
Computers & Internet Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
