Question about Sony BRAVIA DAV-HDX267W Theater System with Wireless Speaker Kit System
Codes for DAV-HDX275 BRAVIA
Hello, do you now what I have to do to make my home T. system (DAV-HDX275 BRAVIA) working for all regions? I bought it in the USA (region 1) and live in Brazil (region 4). Are there any protection code/password?
Thanks
  • 6 more comments
  • rferra Aug 20, 2008
    Até o momento, nada!
  • robertamarti Aug 28, 2008
    Oi ! estou com o mesmo problema, preciso muito tb de uma solução. Se puder me ajudar: leleka@ig.com.br
    Abraços
    Roberta
  • davidgj Oct 06, 2008
    I bought this unit in USA but I need to unlock to watch region 4 DVDs... The unit itself is very good and working fine just this inconvenient...
  • Camilla Hoffmann
    Camilla Hoffmann Nov 06, 2008
    Eu também precisoooo!
  • Tcezar Jan 04, 2009
    Eu também, por favor se algum de vcs já conseguiram, favor me informar.
    Grato, Túlio
  • Jeijack Feb 25, 2009
    need to get it region free ! it seems that nobody could hack it up to now ?!?!
  • DAV_HDX279W Mar 25, 2009
    Alguem sabe se existe algum lugar em SP ou Campinas que faça essa mudança?
  • Anonymous Mar 31, 2009
    I am still looking for the region code hack for the Sony DAV-HDX275. If someone got it, please post it here.
Amigo conseguiste resposta para trocar a regiao do home theather de 1 para 4? No aguardo, em.maciel@ibest.com.br
Posted on Aug 16, 2008
Hi I am unable to program my COMCAST remote to control my DAV-HDX275. I have tried all codes suggested by comcast in vain. Help please
These directions also work for Sony DAV-IS10
It seems like most (maybe all) Sony HTIB do not work with the Comcast Custom Remote. I've found a work around that fixes the volume control and power button though. Hope it helpsicon1.png you all. I have a DAVHDX275 but I think this will work for most Sony HTIB systems.
What you need to do is steal some codes from a like product and then hardcode in the changesicon1.png you need to the comcast remote. Set your AUX to 21232 (a sony code for TV/VCRs).
Then do the following:
1. While still on AUX, press and hold SETUP again until the remote blinks twice
2. Type 994
3. Press and release SETUP
4. Type 32975
5. Press and release VOL+
The remote should blink twice. That should reprogram the VOL+ to work with your Sony HT device. For each of the following function codes, follow the same steps and use the codes listed below:
Vol+ = 32975
Vol- = 31951
Powericon1.png = 32719
Good luck. Let me know if it works.
Aug 14, 2011 | Sony BRAVIA DAV-HDX267W Theater System...
I have a Sony DAV-HDX275 Theater System that I'm trying to connect to an old 17 LCD Dell Monitor. The cable I have is a HDMI to DVI connector. My monitor will pick to the digital signal but nothing appears...
This is because it is transmitting an compressed encrypted signal and the monitor is made to recieve uncompressed signals,You can sometime get around this by changing the output to vga or analog on the theater system.
Aug 25, 2010 | Sony BRAVIA DAVHDX275 Theater System
Problems with hearing sound from bravia LCD tv through bravia DAV-HDX275 theatre system
The fiber optic port on back on your bravia tv is only for when your using a over the air antenna and watching local atsc channels in your local market. You need to run the fiber optic from your hd cablebox if it has one or your hd sat box if it has one. If you don't have a set top box with the fiberoptic port on it you can use a digital coax cable from the cable or sat box to sound system. The only other way to get sound if you don't have a cable or sat box is to run the red and white rca audio cable from the tv to the sound system and got to the audio setup on tv and turn the tv speakers off and you might have to adjust the audio to fixed instead of variable.
Nov 05, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Sony DAV-HDX275
Region Free DVD can be playback on all Sony DVD Players.
Jul 24, 2008 | Audio Players & Recorders
Sony Trinirton TV and DAV-HDX 275 System
Here are a couple of the most common reasons for your problem:
Make sure you have selected the right input source on the DAV-HDX275 that your TV station source (cable, satellite, direct TV or whatever you get TV stations from) is connected to on the DAV-HDX275.
Also make sure that if you are using a digital input (HDMI, optical, or coaxial) from the TV station source, that the DAV-HDX275 in set for a digital input and on the right source.
If you are using an analog source (red and white RCA jacks) for the TV stations , make sure you do not have the digital input activated for that source on the DAV-HD275. You need to select the analog option.
You must also be sure that you have a cable, whether it is analog or digital, connected from the cable box to the DAV-HD275.
I hope this was helpful to you, it is always very important to double check all the connections and make sure the stereo is set to the right type of input (digital or analog).
If you have found this to be helpful, a good rating is always appreciated. Thanks and let me know if you need any more help.
Jun 22, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Sony BRAVIA DAV-HDX267W Theater System with Wireless Speaker Kit System Logo
973 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
