Question about Panasonic Panafax UF-780 Plain Paper Laser Fax
We have a Panasonic UF-4000 faxmachine. Faxes that we send are received very dark. We have changed teh Contract to Lighter, but that doesn't seem to help. Not all sent faxes have problems.
    Sergeant:
  • 284 Answers
There is no computer adjustment for this..
what you need to do is lift up the front pannel and you will see to green handles , pull them towards the center and lift, it wont come out it will just come up a bit. if you see the toner cartridge you've gone to far. if you lifted it properly you will be able to tilt the white plastic and see a strip of glass. wipe that down with a cloth and try again. if its still doesnt work the cis might be broken
Posted on Sep 10, 2008
    Genius:
  • 2,120 Answers
Fuction 7
monitor key 4 times slowly
5
scroll down to shading adjustment
set
send through a blank white sheet
Posted on Aug 31, 2008
How can I change/decrease the baud rate?
The Modem speed or baud selection from highest to lowest is done automatically.
? Modem speed*1: 33,600 / 31,200 / 28,800 / 26,400 / 24,000 / 21,600 / 19,200 / 16,800 / 14,400 / 12,000 / 9,600 / 7,200 / 4,800 / 2,400 bps; Automatic Fallback
see page 84 of 96
ftp://ftp.panasonic.com/faxmachine/om/kx-mb271_en_om.pdf
or click on
5 in 1 Multifunction Office Machine
You should consider .....
2.10 Configuring the unit to access the LAN (KX-MB781 only) You can print documents, scan documents, receive faxes or send faxes using a computer on the LAN. To enable these features, you need to set the IP address,
Mar 22, 2016 | Panasonic KX-MB781 All-In-One Laser...
Panasonic Panafax UF-550 not receivng faxes
Check your line for static, should sound a clear tone. 95% of communication problems are related to line quality (phone company fix this). The other 5% is the modem PCB of the fax machine
Feb 12, 2009 | Panasonic Panafax UF-550 Plain Paper Laser...
Turning off receive on UF-490
Press these buttons.
Function
74
set
15
set
1 for tel
set
stop
Jan 06, 2009 | Panasonic PanaFax UF-490 All-In-One Laser...
Panafax UF 770
What happens when you try to send?
Nov 07, 2008 | Panasonic Panafax UF-333 Plain Paper...
Change setting to not receive faxes at this station
Function 64 set
look for manual mode on the print out
set to manual through sim Function 74 set
Aug 11, 2008 | Panasonic Panafax UF-550 Plain Paper Laser...
Blank pages
sounds like the contacts on you toner cartridge are not making contact. on the left side you will see 2 wire sticking out clean thoes and clean the metal contacts on the side of the toner cartridge
Jul 31, 2008 | Panasonic UF-4000 Printer
Sending Faxes
there is no need to change the setting.just feed the document to be sent and dial the number of the recipient.after hearing the fax tone press enter key
May 29, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Faxes receipt
Set fax to MANUAL Mode.
print out a Fax parameter sheet...Function 64 set
change the parameter in 74 set
May 13, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Can not send faxes, but can receive them
this is for the uf 7000 you need to do an all job clear on the machine to try and fix your problem, sounds like a memory lockup
Oct 02, 2007 | Panasonic PanaFax UF-7000 All-In-One Laser...
Panasonic Panafax UF-780 Plain Paper Laser Fax Logo
77 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
